Dann2707
Everything posted by Dann2707
  1. Does anyone know if you can fit those to a car without the electric struts as standard? So a retrofit.
  2. Not a bad idea at all that. My issue is (and solely my problem) is that I need the car daily and it's winter so would need it now. I may have a gander in summer time perhaps.
  3. No I haven't mate. I daren't risk it with it being such a big task. If it was a simple swap it wouldn't be so bad.
  4. Think I have a thermostat issue, I changed my DSG stat last year so don't think its that. I'm not even getting to operating temperature in November on A, B and motorway roads after a 30 minute / 17 mile drive. How long roughly does yours get to bang in the middle doing average driving at this time of year? in terms of time and/or mileage Thanks
  5. Think i'd still be wanting a validation check of that the coolant temperature sensor is working though. There's not much else to change and not having 100% confidence in the sensor wouldn't sit right with me. Thermostats are pretty basic pieces of equipment so if that's working, nothing else should really be effecting operating temp.
  6. Where did you order the badges from? or are going to?
  7. I ended up flattening my curved badges somehow, probably with a hammer. They're still on a few years later, although the paint has flaked away.. probably from the hammer
  8. At least i'm not doing something wrong then! Cheers for that. It does seem a rather strange way to go about it!
  9. A bit of a weird one. My heated mirrors only come on when the dial is selected on the drivers door, which is annoying as I expected it to come on when I press the heated rear screen. I usually have it on the L position as it helps with reversing dipping the mirrors so having to move it to heated each time is a pain, on other cars the heated mirrors come on when the rear screen heater is on. Am I missing a setting or is this how it is ? On a 2012 superb estate Thanks
  10. Hi, My Mk2 has the common fault where the heated seats aren't working, i've changed the module with no luck and put it down to the wiring in the seats. A replacement set is looking at £180+ for one seat... which i'm not paying. Has anyone had any luck with any others from Aliexpress or anywhere else? The parts in question are: https://www.skoda-parts.com/spare-part/3t0963555af-insert-for-the-heater-seat-leather-skoda-26837.html https://www.skoda-parts.com/spare-part/3t0963557q-insert-for-the-heat-up-backrest-leather-skoda-29544.html I wondered if something like this could be retrofitted https://www.aliexpress.com/item/1005006482145381.html?spm=a2g0o.tesla.0.0.2b91YxnhYxnhdk&pdp_npi=5%40dis%21GBP%21%EF%BF%A159.38%21%EF%BF%A129.69%21%21%21%21%21%40210385a817558600276202665e2404%2112000037367679053%21btf%21%21%21%211%210&afTraceInfo=1005006482145381__pc__c_ppc_item_bridge_pc_main__1aLhYdp__1755860027733 Thanks Daniel
  11. Well aware i'm talking to myself but it may help people in the future... there's nothing worse when people complain about an issue but never update the final result on a forum. More wires have failed in the left hand side tailgate wiring which is what is presumably causing my issue!
  12. As per the above comment, check the windscreen seal too. Mine has failed and lets water in at the top
  13. Now i'm wondering if it's the boot wiring again (in a different place perhaps) as the rear wiper isn't working now, and i'm fairly certain the heated screen isn't functioning so perhaps a bad earth within the loom in the tailgate.
  14. Hi, i'm having an issue on my 2012 estate where the boot mechanism isn't activating properly when pressing the button. It's: Making a very weak sound compared to normal when pressing the button Takes a few presses for it to actually release the boot and feels like it's catching something Locking the car again after 60 seconds (the standard auto lock) if I unlock the car and just release the boot so it's clearly not registering the boot is opening. How does this mechanism work? Has anyone had a similar issue before please? I sprayed some GT-85 in the mechanism and that helped slightly but it's still doing the above. I have repaired the tailgate wiring a while ago and can't see it being that because the mechanism is clearly registering the button press and trying, it's just weak. Many thanks, Daniel
  15. Do you have any pics? Did mine recently so might be able to help
  16. Hi all, Bit of a weird issue and it looks like it's probably an earth? Basically when i'm indicating right the right arrow on the cluster doesn't appear or flash but the red coolant icon pops up at the time when the indicator light should. The indicators are all working absolutely spot on and there's no issues there. To me it sounds like there's probably an earth thats got corrosion on it etc, does anyone know of any common issues here? I've had a search but nothing obvious at all Many thanks in advance
  17. Hi, Has anyone heard of an issue where the glow plug light doesn't come on when you switch ignition on? Mine is doing that and in this cold weather it obviously won't start. I don't understand why they aren't coming on though? If I put the ignition on about 5 time the glow plug light does eventually switch on and it starts Coolant temp is working fine when it's driving. Mk2 2.0 tdi 170 Many thanks
  18. Hi all, Really not happy with auto wipers so wanting to use the little wiper lever on the stalk as per the intermittent wipers. I've gone into one of the settings on OBD11 and disabled "rain/autolight sensor" expecting the stalk to go back to intermittent wipers as i've read online but it's still using the rain sensor I believe as they are completely random now on the stalk. Has anyone coded them back to a lesser spec model before? If so am I missing a step? Thank you
  19. I'm not sure if he's active so much anymore mate. He was last online last year The drive is still giving me an error The disc is spinning up but it's like it's not connected to the radio It's all since I've installed and enabled the rear view camera and when I did the hard reset
  20. Thanks I've put the CD in and now can't eject it 😞 THis is so frustrating Tried disconnecting the battery etc, i can hear it spinning the disk but won't eject it.
  21. Do I burn it to the CD as an .Iso file? Then plug it straight into the radio? Thanks again for your support
  22. Also I saw another post where someone has updated via SD card? I have the slot in my head unit. Could I maybe do that as I currently don't have a CD drive in my laptop, or any CD's
  23. Thank you, i've logged in with OBD11 and found out its "3974". and hardware is H06 Please can you let me know where I might be able to download the latest software from? Many thanks for your support
  24. Cheers mate, I will go find it. Is it something I can look in the settings on the unit without taking the covers off for now? Sometimes it does allow me to go on the menu which is rather weird! so can check there if so I have OBDeleven and wondered if i could do a software update through that too?
