JohnMack
Everything posted by JohnMack
  1. The shocker doesn't impact the ride height, would be worth taking a look at the spring as maybe it's broken. Check the disc backplate is still secure too.
  2. Being a bit old school, I'd go with a volts drop test under load to check continuity on both supply and earth circuits . I'd be looking for under 0.5 volts . As above , 12.2v is a 50% charge so that(95%) must be battery health ?
  3. You get through them !!
  4. Like ME !! 👍
  5. No thanks, whilst I really like the end result I find cleaning and polishing a bit of a chore these days. I used to quite enjoy it but it's one of those things that's dropped down my "favourite things to do list" !! I'm assuming you're driving a VRS of some type Mr Rocky ?
  6. Like you I'm back for a wee look after replacing our Octavia with a newer model. The forum is a bit quieter but ticking over. Job for the weekend....polish the car !
  7. If it's like the older cars then if you can see the exhaust exposed then that is the exhaust ! If you see an under-tray then there is no exhaust !
  8. We've just bought a 2017 VRS (CUNA) and I'm curious to see what oil it uses between services, our old VRS (CEGA engine code) used no oil and was at about <270k when sold last weekend. Seems like previous servicing will play an important part from what I understand? Our new VRS had a new heater matrix prior to us getting it and the expansion tank was apparently relieved of the Silica bag which was the cause of the matrix being blocked. Good cars but like everything, they'll have issues ! Skoda Octavia VRS 2.0TDI (CUPA EA288) high oil consumption - Skoda Octavia Mk3 (2013 - 2020) - BRISKODA Expansion bottle replacement - Skoda Octavia Mk3 (2013 - 2020) - BRISKODA
  9. I think so. I probably over serviced it but it wasn't a bad car to work on. In all those miles it was still on the original clutch and flywheel, never had a starter motor or alternator and both front wheel bearings were original !! The replacement car has had the clutch and flywheel replaced recently, showing 97k on the clock.
  10. Ah yes, we met when you and your good lady were passing the Edinburgh area after a trip up north I think? ... it's Chris yes ?? I still have my 7A CQ Tornado Red. John.
  11. Audi 90 I assume.....great cars !!
  12. Be careful, if the dust cover has stuck to the piston then there's a chance you'll rip it when you start to wind in the piston. Use a small electrical screwdriver to prise the dust cover out from the groove in the piston and then move it(the screwdriver) around the circumference of the piston to ensure it's free, be careful doing this. Squirting a bit of lube into the piston groove wouldn't do it any harm. That £8.99 ebay kit should do the job.
  13. So, after going to view a 2017 VRS estate we came away with it and so “old faithful” has now passed into new hands. With almost 270,000 miles under her belt and still going as well as when we bought it….Sold. The new car has big boots to fill, I doubt it’ll be as good as the old one??…. time will tell.
  14. There's no cable from what I remember? I only replaced the switch.
  15. I agree, but I'd like it to be a minimal amount 👍
  16. Thanks, I did ask the seller if he was topping up between services. His answer was yes....towards the service being due ? Have decided to stop looking for the time being, will plough on with "old faithful" ! ( Turned 240k today )
  17. Read through most of those threads, my head's bursting! So........ would a CUPA engined VRS with 92k miles and history showing oil changes every 10k miles be a good car ? I'm thinking it's been looked after ? If it's not using oil and I continue with the 10k mile oil change intervals, will it be ok?......... or is it likely to develop a thirst regardless ?!
  18. Maybe the battery only just managing to do it's job could be the reason for the warning lights ? ...... did the clock reset when starting or was it actually 12:05 AM !!?? Regarding being stuck in park, try a new brake pedal switch....cheap enough and easy to fit.
  19. That's not much at all, i could cope with that !
  20. Thanks for that, will need to check engine code and service history when viewing any potential cars. I service the car we've got myself every 10k miles and I can't recall ever having to add oil between changes. I check it probably once avery 2 weeks.
  21. That's interesting about the CUPA engines.
  22. Hello folks, long term lurker here, but looking for anyone's experiences of mk3 VRS ? We have a 59 plate VRS diesel (CEGA engine, CR) which now has 230k on it, still drives great and has never needed anything out of the ordinary. But the time will come when it gets a bit scabby looking and we'll look for a newer one......so !? Pretty set on another diesel due to the present car being so reliable and easy to work on ...are the later diesels just as good? Thanks in advance. John.
  23. Thanks toot, we've had the car about 7 years now. I'll likely just check the wiring to the ABS pump and it's earthing wire.....not too keen to take it to the dealer. Strange that they've just sent this letter now?....got the emissions recall letter about 6 years ago....never got that done either !
  24. Hello all, I'm not on here much as our Octavia VRS (CR) causes no bother whatsoever ! (touches wood!)........ but got a recall letter in the post about the above recall. Tried a search on this here forum and was surprised I couldn't find any info ? Reading the letter I'm thinking it could maybe be just a simple earth-wire check as they quote a time of "about 30 minutes" ? Can anyone enlighten me please ? Thanks in advance. John.
  25. New switch fitted and boot now opens every time.
