Everything posted by ords
Amundsen, lost postcode option for nav search.
Which unit do you have?
Unknown substance in engine bay?
I'm surprised the garages haven't picked it up.
Replacing rear discs and pads.
My rear pads & discs are original from 2013 and on 62K. Front pads only replaced at 45K.
Steering wheel covering view of the top of the tachometer & speedometer
Not as issue for me on this car or any other car I've driven.
Warning lights after puncture repair
Could have disturbed a wire going to the ABS sensor on the wheel they changed, altho the ABS light should have come on.
COOLANT TANK
I'd forgotten that
VRS 2019 Sat Nav problem
What unit do you have?
Clutch pedal
Well, Skoda's motto is "simply clever".
COOLANT TANK
It makes some sense to change the pump at the same time as the belt due to its relationship with the belt even if its given no trouble There's no guarantee that the new pump won't fail prematurely.
COOLANT TANK
In the UK, Skoda recommend a belt change every 5 years, so the water is changed then. I believe that if the car has the silikat bag it extends the working life of the water way beyond 5 years.
COOLANT TANK
For the TDI's it would be until the timing belt was changed.
Clutch pedal
Seems like engine oil as you have to top up more often. Oil is thinner after a run making it easier to leak from somewhere.
- COOLANT TANK
A Dingling Cable, What is it and where it is supposed to go???HELP!
Do these components work?
Clutch pedal
When you wipe it, what colour is it?
Clutch pedal
The steering is electric, no fluid reservoir.
Mk 3 Octavia - alternator low output
Well, it wouldn't work at all first thing but at the end of my trip it did work and read 80%
Octavia mk4 1.5 tsi manual transmision
Get it back to the garage under warranty.
Out of interest, would a smart charger only charge to around 80%?
The odd times I've checked the SOC using the trip set button, I've never seen more than about 70%. I'll check it in a few days time before starting the engine (not used for about 2 wks) and again after a 250 mile trip I'm planning.
My viewpoint. You've done that trip with no heavy consumers running, apart from maybe headlights and a/c. If the alternator gives you that reading under heavy load I'd expect it to be more than capable of charging the battery under a light load. As mentioned above the battery is probably on its way out.
- P001600 Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor A
Coolant level dropping & no heat
What engine?
Boot unlocked rest of car locked
If you have the 3 button remote, the middle button unlocks the boot only. Don't leave the key in the boot as the lid locks as soon as you close it.
2015 1.6 tdi - to DMF or not to DMF
