bspman
Everything posted by bspman
  1. If your headunit supports remotes - then you'll likely need a harness from the likes of connects2 or something. I had some trouble with mine as due to it being a later model - I had to get a newer harness installed by a professional since they didn't have a version specific for my vehicle.
  2. Welcome to the forums. That's a FL so make sure your cam chain tensioner (and associated bits e.g. chains, guides) have been replaced in the last few years with the updated revision It's pricey, but a new car more so.
  3. Mp4 video "show controls" gone now too 😞
  4. I personally found my mk2 costing an arm and a leg compared to my mk1. I am hating myself for ditching the mk1 as all the money spent could've gotten me a nice mk3!
  5. I came, I saw, I regretted updating.
  6. Sure it's not that bad? What happened to it? Edit: fixed the toolbar position but not a fan of single column for tabs, much preferred the dual column layout. Haven't checked performance whilst browsing yet.
  7. @Solly I know how you feel. My mk2 has cost so much more than the mk1 to look after. So much stuff as gone wrong and I deeply regret ditching my mk1!
  8. Had a neighbour hydrolock his sharan when he tried cleaning it too. I took my dad's off and put a new gasket on (ordered 2 when I did mine). Cut open a 4L milk carton, and cleaned in there to capture all the petrol/carb cleaner. Big chunks of tar off the EGR and the MPG was SO much better.
  9. Hey
    bspman replied to Bashbarnard's topic in Hellos and Goodbyes
    I still have my mk1 fabia (1.2 petrol) and sorely miss my 1.9tdi octavia. Brilliant engines.
  10. bspman replied to Fireball's topic in Hellos and Goodbyes
    Welcome and I hope you enjoy it!
  11. Hey
    Welcome. Forums aren't crazily busy, but are decently so (given that I hang about in older model threads). The newer vehicle forums here are much more active!
  12. Octavia vrs mk2 fl tsi (2010). Driving along I got the ABS, ESP and TPMS lights up at once :( Scanned and saw the below (VCDS autoscan error sections below). I had a look around and apparently the teves ABS pumps are known to fail. Would mine be impacted or would it just be the sensor/ring? If it is the sensor/ring - am I correct in understanding that: - the hub and bearing need replacement? - the sensor would need replacement too? Monday,20,July,2020,19:52:16:42399 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 20.4.1.0 (x64) Data version: 20200331 DS317.0 www.Ross-Tech.com VIN: [redacted] License Plate: Mileage: 193680km-120347mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1Z-SK35 (1K0) Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 VIN: [redacted] Mileage: 193680km-120347miles 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb Part No SW: 1Z0 907 115 AF HW: 1Z0 907 115 F Component: 2.0l R4/4V TFSI 0010 Revision: AAH16--- Serial number: Coding: 0203000C1C070160 Shop #: WSC 73430 790 00999 VCID: 79FE6174307CCD4E4C-802C 1 Fault Found: 053271 - Please Check Fault Codes in Control Module for ABS Brakes U1017 - 007 - - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 0 Fault Frequency: 5 Reset counter: 255 Mileage: 193576 km Time Indication: 0 Date: 2014.12.10 Time: 19:58:18 Freeze Frame: RPM: 2753 /min Load: 27.0 % Speed: 104.0 km/h Temperature: 95.0°C Temperature: 30.0°C Absolute Pres.: 1010.0 mbar Voltage: 13.970 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH Component: ESP MK60EC1 H30 0107 Revision: 00H30001 Coding: 163B601C092300FA681106E790210081340800 Shop #: WSC 73430 790 00999 VCID: 78F86470CB76D44633-802C 1 Fault Found: 00290 - ABS Wheel Speed Sensor; Rear Left (G46) 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 1 Fault Frequency: 5 Reset counter: 189 Mileage: 193443 km Time Indication: 0 Date: 2014.12.10 Time: 10:27:09 Freeze Frame: Count: 0 Count: 0 Count: 4608 Count: 69 Count: 50519 Count: 0 Count: 64768 Count: 0 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb Part No SW: 1K0 937 087 D HW: 1K0 937 087 D Component: BCM PQ35 H 103 0575 Revision: 00103 AG Coding: 44180A98B05BB1C040080081050001E4432800AE424D8960800440040000 Shop #: WSC 73430 790 00999 VCID: 326C96586D8AFE16CD-8066 Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB Component: Wischer 17031 22 0601 Coding: 00D7B7 Subsystem 2 - Part No: 1Z0 951 171 Component: Innenraumuebe 008 5101 Subsystem 3 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb Part No SW: 1T0 959 701 T HW: 1T0 959 701 T Component: Tuer-SG 009 2114 Coding: 0000756 Shop #: WSC 73430 790 00999 VCID: 4898D4B03B1664C683-801C 1 Fault Found: 00109 - Left Mirror Turn Signal Lamp (L131) 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 J Component: EPS_ZFLS Kl. 74 3001 Revision: 00H17000 Shop #: WSC 73430 790 00999 VCID: 316E9954A88CC50EB4-8064 1 Fault Found: 01316 - ABS Control Module 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 3 Fault Frequency: 6 Reset counter: 229 Mileage: 193605 km Time Indication: 0 Date: 2014.12.10 Time: 20:15:12 Freeze Frame: Voltage: 13.88 V DU Temperature: 60.0°C RPM: 3264 /min Speed: 111.0 km/h Speed: 111.0 km/h Count: 0
  13. Hi, so I've got a 2010 VRS (petrol) with misfire issues (engine code CCZA). Breakdown: I've checked engine blocks whilst driving. Cyl 2 misfires under gentle accelleration when cold (as in - engine not at operating temp). NO EML I've swapped 2 and 3 coilpacks - still misfiring cyl 2 as above. New spark plugs were fitted a while back by an indie, but original coilpacks An injector (not sure which one) had a new seal applied to it whilst at the indie for my chain/turbo issues. Have been told compression looks fine on all cyclinders by above indie I've fitted new coilpacks (r8s) but the problem still persists. VCDS scan showed below error around evap. Address 01: Engine Labels: 06J-907-115-CCZ.clb Control Module Part Number: 1Z0 907 115 AF HW: 1Z0 907 115 F Component and/or Version: 2.0l R4/4V TFSI 0010 Software Coding: 0203000C1C070160 Work Shop Code: WSC 73430 790 00999 VCID: 79FE6174307CCD87E0-802C 1 Fault Found: 001089 - EVAP Emission Control Sys P0441 - 000 - Incorrect Flow - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 190354 km Time Indication: 0 Date: 2044.14.06 Time: 21:58:08 Freeze Frame: RPM: 835 /min Load: 20.4 % Speed: 0.0 km/h Temperature: 89.0°C Temperature: 18.0°C Absolute Pres.: 1010.0 mbar Voltage: 14.224 V Readiness: 0000 0000 Fuel cap seals look like they're cracked so maybe a new fuel cap needed. Thoughts on where to go from here?
