Everything posted by DogBook
All Season tyres - a new recommendation (225/50/17)
I use these on ours, very good all round even cold and wet or hot wet and on some snow. Still great in hot dry etc etc All round very good. https://www.camskill.co.uk/m138b8684s7991p207137/Maxxis_Tyres_All_Season_Car_Maxxis_Premitra_All_Season_AP3_195_50_R15_86V_XL_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB/RS_GB
Very wet carpets
TPS sell genuine parts or LLL.
What are they?
3rd agree, should be attached to the exhaust as they look like dampers to me. Also there is no tray, they go into a cross member between the subframe. Thats without looking at a parts list.
- What are they?
Amundsen update
That interesting as I read it exactly as the OP said, will they loose the Apple CarPlay? So going by what you say thats a simple yes then. Your reply says new patch, but what new patch? Is there an update with the clock fix that comes with Apple CarPlay or did you mean another patch?
Amundsen update
That isnt what they were asking.
Air Quality Sensor testing
Try buying a genuine one from TPS, they usually deliver as well when you set up an account.
Paint Protective FIlm
Don't TPS or the online seller LLL supply them?
Digital Clock and Dashboard Clock
I can't see your location in your profile as if you were close I'd say pop over and use mine. Also its FAT32 you have to format it to. As this isnt car related I'd ask on a MAC forum or similar unless your lucky and someone sees the post and knows all about MACS. Although having reread it it tell you what the issue is, it says its your permissions so give yourself permissions to do it then it will work.
- Skoda Yeti Head unit clock 00:00
1.2 TSI drive shaft heat shield loose
Just done a full service, and found this heat shield over the inner cv loose even though the bolts were tight. 5Q0407721 My thoughts that over time the metal washer inserts have become loose, refitted it with repair washers to nip it up. No rasping sound now on over run, so must have been that. Did sound quite good to be honest 🤣 Anyone else had any experience or fitted a brand new one before?
Skoda Yeti - Dashboard Warning Lights
Exactly, because each of the 5 faults relate to the speed sensor. Due to the location on the 2WD I had to move the UCA up and away just to unplug it. But since it was seized in and was due for MOT I let Sunset in Derby do it as I do not have ramps or multispline tools for the wheel bearing bolt. One new speed sensor in with a little glue as the cap head had sheared when I undid it and the cars back home. I did check the battery at first but when you read up if it was then there would other faults coming up as well, not just the 5 pertaining to a speed sensor fault 🤨
I already suggested this and was ignored 🙄
- Skoda Yeti First Car Buy — Sense check
2016 Petrol 4x4
Make sure the haldex has had its services then 👍
- 2016 Petrol 4x4
Removing panels in the boot
😂 I cant fully remember when I did mine, you’ve got to have a look around really. Firstly you can see the rear quarter panels fit over the black, so they need to come off. Take all the boot floor things out as they might hide fixings and there’s some near the sides of the seats, the hook rails you can see have an insert. Pull them off and I think theres screw behind them. Give panels a little pull and you can start to feel where its fixed, these cars are very well put together.
1.2 tsi cyvb oil leak from manifold
Cheers, Google just brought me back here to my own post 😂 I always search first before posting, I got fed up after over a week of trying.
Yeah Ive had the obligatory look on overtime at work during the day 🤣 Couldn’t find anything and the cam cover breather none return worked perfectly. I may change it as its not expensive anyway and the cars done nearly 150k so whats to lose.
Yeah im not reporting them, theres a fair few on the last 2 pages quickly looking under the title so if they can take the time to move mine which didn’t even mention Yeti in the title Im sure they can spot the ones that do mention models 🙄 The thing is, I didn’t even mention it being model specific because it is not. Its engine specific, theres got to be more VAG cars with the same engine. And I have reported my issue to mod but have had no response, so theres no point in reporting others to clearly ignoring the forum instructions.
Can a battery fail this fast?
😂 Dont worry about it, I think I'm the same. Its hard not to think about it and just see what can be found instead.
Unfortunately someone has moved it out of the general maintenance area where I was hoping to get more exposure of this engine. No idea why, when you look there a lot of posted about specific cars instead of in the relative section yet they still stay there 🤨
Yes I know, I asking if anyone has any dealings with this manifold and issue.
Can anyone help with this engine type at all please here? https://www.briskoda.net/forums/topic/538501-12-tsi-cyvb-oil-leak-from-manifold/
Bump
