Everything posted by Snapper1725
Mk1 Fabia Vrs front brake disc shield
Thanks for reply, looks like it to come to bits again 🙄 Spent about a hour looking on google for images, part numbers etc and couldn’t find anything. sure the part numbers of top of my head end in 311 and 312
Just been doing wife’s Vrs ( all standard) and just put this side back together with a new disc shield fitted also. question, should it be bigger than the disc and slightly visible ( old ones missing so can’t compare) Starting to think TPS may have given me the wrong ones Any ideas cheers
Trouble replacing scuttle panel under windscreen
Just make sure it’s all cleaned out really well, line it up at one end and start working your way along do this bit 1st before fitting clips, bonnet seal etc its the best way I’ve found
Black smoke! Why? :)
Wife’s had hers since it was 2 months back in 2005 Used to chuck black smoke out when accelerating. Used to fill it up at super markets etc. when I got my new car 5years ago starting putting Bp in and then starting filling Fabia Vrs up with Bp. Over time it cleared up and nowhere near as bad
Daylight Driving Lights
Does give you a warning if a bulb has failed, I kept getting a warning check right front day time running light. Not 100% sure but do you not have to have the lights switched to auto. Sure I’ve read something but could be totally wrong
Skoda Superb Elegance TSI 1.8 2010 Oil Usage!!!!!
Basically what the guy was saying
Watched a clip on YouTube, a guy going on about Audi oil usage and how they get round it by stating in the handbook that 1ltr usage per 1000km or miles ( can’t remember) is normal. Which to me is a joke
Odd problem with tyres
I had tyre sawing on the back thinking it was wheels bearings. so I thought I’d put them on front thinking I’d scrub the high spots off. But 1st drive was horrendous, the noise/vibration it was making. Ended up two new tyres
Back seat cushions removal 2011 Suberb Estate
Yes you can, you need to have them at a certain angle for them to slide out. the round bar as a bit sticking out and that bit needs lined up for it to slide out
Skoda Superb ABS light, TCS light and Brake system light went on
I had Abs light on, pic of steering wheel, tyre pressure and another fault came back right rear abs fault, so I got a new sensor and broke the old one getting it out so ended up stripping the brakes off etc so I could knock it out. That’s when I found the hub Abs thingy had fell apart 😤 so most likely had been hub in 1st place and not sensor
DPF/turbo gasket, garage can't fix it. What next?
I struggled to reconnect mine when I done the egr valve. I had the two bolts removed from the support bracket to the block and also further back to the sub frame but ended up having to loosen the two bolts on the dpf to that bracket before I could get the dpf to line up with the turbo correctly without having a fight or forcing it. once it was clamped back up then went back and refitted/tightened the support bolts
New Superb owner..
Mines a 2013 with 6 speed, 70k and egr valve packed in. Don’t know if it’s with some short journeys I do or not reviving it enough but who knows. Lately been driving it and keeping it in 5th on the roads round where I live as I noticed like you that 5th is 2000rpm and 6th knocks it down to 17000rpm. Don’t know if it’s my imagination but the fuel consumption also seems better
EGR valve on way out, again!
https://www.briskoda.net/forums/topic/441688-glow-plug-light-flashing/ I posted this a while back with some pictures of the egr valve (new one) I always fill up with premium fuel (Esso) and have done since I bought the car with 26k on clock but mine packed in at approx 70k. I took the old one apart but it wasn’t no where as bad as I was expecting after seeing some on YouTube. Mine cost £420, egr valve ( genuine) gaskets etc and coolant from Tps plus my time fitting. Don’t think am doing my car any good really with some of the short runs I do
Does anyone know what this wire is for
Hi thanks for that, had been trying to find some info. the wire is white/yellow with grey specs on. This is a better picture of the wire, I tried to add this pic to my original post but couldn’t for some reason
Hi all A while back when changing front pads the plastic connector for the pad sensor broke where it slides in a bracket, I covered it with tape and all was done ok. Yesterday 4 warning lights came on. Abs, traction control, tyre pressure and a pic of steering wheel. So wondering if I could change that wiring section that goes through wheel arch into engine compartment I removed battery etc and found a large harness that was rubbing on the battery tray, one wire look as though it was worn through but luckily not, it’s taped up now along with harness and moved slightly with some protection on it ( see pics ) So wondering if anyone knows what this wire is for ? Also may be worth checking your own for same issue Also still have fault and can’t change that cable as it goes into a large harness but checked out its ok So going to get it scanned Cheers, I know I may be asking the impossible
