bmbmdmb
Everything posted by bmbmdmb
  1. I think you are probably correct Pete. I already bought one to fit in the meantime whilst I wrestled with my options. Interestingly, the ASZ EGR is double the price. I had a taste of the better mpg (unless trip computer is reading differently with EGR hose disconnected) and the hesitation has gone.
  2. The N75 vacuum box - it sounds like it's coming from there. Happens mid revs every so often, 5 to 10mins. I'm limiting the car's use as it can't be good.
  3. I think leaving EML on and blocking vacuum pipe might work, but I can hear a tyre like drumming noise mid revs - sounds like the vacuum pump trying to open the EGR. Might damage something? Also, I read this about testing for NOx on future MOT s published Jan 2023 https://www.gov.uk/government/news/proposed-changes-to-make-mots-fit-for-the-future Specifically, "The consultation also seeks views on the frequency of MOTs and how to improve monitoring of emissions to tackle pollution to bolster the environmental efficiency of vehicles. Potential new measures include introducing testing of pollutants such as particulate number (PN) and NOx to ensure diesel, petrol and hybrid cars always meet emissions requirements throughout their lifespan." Food for thought...
  4. The blank does nothing that the EGR does not do itself basically? Thanks
  5. It's definitely the EGR at fault. First time out with EGR disconnected. All the symptoms disappeared. Mpg improved with EGR disconnected, no smoke, not even a puff on starting. Got 65mpg on computer when I'd normally get 58 to 60mpg like for like driving. No smoke on flooring vehicle. I usually get some smoke near full throttle. Car warms up in the same with EGR disconnected as connected and seems to drive better. The EML took 2miles to illuminate and I cleared p3130 but same occurred on way home. I was only considering changing vacuum hoses as the mechanic has oversized the hole with a caliper banjo bolt! I guess he doesn't play golf! Ie no golf tees about...which was a good idea Breezy Pete. Good point Lofty about the tailored shape of the original vacuum hoses. I read the silicone hoses can stick to hot surfaces too, like in the engine bay! I'll give the silicone a miss. The brakes are definitely better with the vacuum hose to EGR blocked off. Less spongy. Any suggestions on why? A new EGR is £42 without gaskets, o rings or £60 with all bits which I'm going to buy. Is the EML able to be mapped out completely for an EGR blank? The EGR delete kit I've seen would be an obvious modification. What blanking plate would you suggest out of interest? What about the EGR cooler? Leave in place?
  6. Yes, I'm going to keep bolt in place, mechanic said same thing as an experiment. Pete, will the disconnected EGR simulate an EGR delete. I'm interested in how the car differs to EGR connected eg warm up time, mpg, etc. Is it worth replacing the 16yr old vacuum hoses with silicone ones? Any benefit? Eg less pliable material when vacuum applied? Vacuum hoses The inner diameter is 6mm Outer diameter is 9mm The ones behind expansion tank and above EGR running under windscreen. If yes, any suggested total length to purchase?
  7. Ok The EGR is disconnected currently. I have driven it home and the car boosts as it did do. Mechanic said it smoked badly. When EGR disconnected and bolt in vacuum hose no smoke, driver is thrown back in seat when accelerating (been 10miles). I didn't want to whip car as it was on cold start coming home, but I could tell it felt much better. Looks like the EGR. Garage said if the symptoms return then turbo , vnt, actuator is next on the list. EGR has been tested using vacuum and gauge and although diaphragm holds vacuum the plunger/valve is sticking and opens/closes at different time to the vacuum being applied. The turbo could be heard healthily boosting, no siren noises etc. On way home. Brakes seem to bite slightly better with vacuum hose blocked to EGR, but hard to say.
  8. Ok. Personally, I've not had these symptoms when EGR last played up. Last time the EGR blocked up the car coolant took longer to warm up and the engine shook on idle. When at temperature after a commute and idling the cooling fans came on ( never had these on). Different symptoms this time. But the EGR previously stuck one way. Should it open and close only depending on coolant temperature? Both mechanics are experienced on VAG cars and one owns Skoda's. I trust them. If the turbo needed changing they wouldn't turn that work down. Vnt - the turbo blades I have heard the turbo noise (as usual on tick over), nothing unusual, so the turbo blades seem free to spin, whether the blades are adjusting pitch, I don't know. Actuator - Again I'm not knowledgeable enough. I've read that can fail (it has a vacuum line). Does this spin up the turbo on accelerating? If turbo, is it a new turbo or individual parts. I read it might be a KKK turbo, this one? https://www.darksidedevelopments.co.uk/products/kkk-bv39-turbocharger-for-1-9-tdi-blt-pd130-ibiza-polo-fabia.html Actuator appears to be available as a separate item https://www.darksidedevelopments.co.uk/products/kkk-vacuum-actuator-1-9-8v-tdi-engines-for-pd100-pd105-pd130.html What do you recommend is my next step? I'm about to collect car so any questions I should ask feel free to pose so I can ask. Thanks
  9. Garage said the EGR is sticking between open and closed. I disconnected vacuum from EGR and checked with more vacuum tube that it held a vacuum and it did, before taking to garage. Garage said at low speeds it is more pronounced. They blocked the vacuum tube with a bolt and took it for a drive. It was as it should be, performance returned. This EGR has been on car 40k miles and cleaned every 8k miles. It was cleaned last November and just before taking to garage. I have my original one that blocked up and I cleaned, or I buy a new one. I'm sick of cleaning it to be honest and it seems that cleaning is not effective. Those rubber o rings between asr and egr are nearly £10 each which expand if cleaning solvent comes in contact. Is blanking and map out EML effective? I read up and it seems opinion is divided. Where is best place to get a new EGR if I go that route again? I bought from Skoda dealer the last one that failed. I read on here that the hole in newer EGR valves is larger - don't know if this is true, ie a superceded part? Thanks Ps at least it is not the turbo
  10. What about the tandem fuel and vacuum regulator? It seems I'm getting lack of air though not insufficient fuel?
  11. Thanks. I'll just change the shocks at 45k miles. The springs are easy to change on rear so if they go I'll do it then. I changed rear springs and shocks on my other car, a Fabia, at different times. The new like for like springs made little difference, slightly firmer in corners perhaps. The shocks made a big difference, but they were knackered and seized (the car really wanted to go in a straight line on roundabouts for instance).
  12. I have checked the vacuum pipes more thoroughly, feeling underside for splits. There were none. Had a look at intercooler through gaps in bumper, again no damage evident. Boost pipes double checked and felt for holes. Unions secure and tight. Could oil,soot gunk obstruct the turbo fan blades/vanes and it is not spinning as it should? A lot of folks on here who have had a turbo failure have had a loud noise or sudden failure. Or can a turbo fail gradually? Would boost values from computer be worthwhile reading? Cheers
  13. Thanks Sep 'Log boost in VCDS' - Is this a basic or an advanced measuring value? I went through the tickboxes and I could only find the MAF actual and requested values. How are the boost values named? Do I need the car under load (at speed) to measure accurately or can I increase revs with car stationary? I had a look at the vacuum pipes and felt around them for splits. Nothing obvious. Anywhere in particular to look in the engine bay? Thanks
  14. Lower and upper boost pipes are in place, check. EGR looks ok, but coated in very dry soot, never seen it like that before. Usually, it is oily. Matches what is coming out my exhaust, a puff of black soot on acceleration. Dry soot left on tailpipe. Turbo you think? I'm going to take to garage but wanted as much info as possible to save them time and reduce bills. Engine idles and starts smoothly. If turbo what's my options. Standard turbo had plenty of power. I heard that you reuse the cassette or something similar. Reconditioned calipers were a waste of £. Same true of turbos? Is there any test I can do to diagnose this? Thanks
  15. VCDS - no fault codes. I'd be surprised if turbo at fault. Engine oil changed to specification and annually or less. Every 5k miles. Mileage is almost 100k though. I have no siren noises or other noises from turbo. It makes the same tick over growl noise at idle it has always has since ownership began. There is some very subtle intermittent noise though that is coming from engine bay at idle that was not there previously, nothing obvious though . Would a turbo failure be obvious? Fuel filter changed a few thousand miles ago. Air filter looks ok. I'm changing it, but unlikely the culprit. I'm going to look underneath at the boost pipes and EGR through ASV on top. The fuel temperature sensor area , nearby there is what looks like a fuel pipe (metal aluminium tube) connected to rubber hose - looks damp, but could be oil from a previous change - between engine block and air box, or diesel? The sponge under engine cover has powdered (probably age and heat) so it got removed last night. Some of this stuck to said oil or diesel. Is the aluminium block the fuel pump? My finger pointing to it. This is the leak, nothing to write home about though. Is this the FTS? Centre right of photo?
  16. It is all new pipes and jubilees 5 years old. They been off for timing belt last November though but were secure. Only one or two horseshoe VAG clip,ie to turbo and maybe intercooler. I had one pop off 1cm and it was obvious. The car stuttered and it was undriveable. I'll check though when it gets home.
  17. MAF giving live data that mirrors predicted MAF values I got from live scan last night MAF sensor was replaced when car had 50 to 60 k miles. Live / actual data was zero when it should have given higher values (this is when it failed previously) , so I have ruled out MAF sensor on this occasion. Fuel temperature sensor looks likely - smoke, hotter than normal engine, injectors blocking. Car is over fueling. Car near 100k miles which is their lifespan. Will vcds pick up this fault? I'm scanning tonight. Ps anyone with Green Flag - make sure you insist on quoting the older car. I told them at time of renewing, but today because the car is over 16 years mid policy they said it is not covered. Manager authorized tow in the end. I only been with them for 25 yrs
  18. Hello Wife's Fabia vrs MK1 07 (all standard) has been losing power and getting worse. I'm considering a tow home from work as I write. I drove it last night and it was ok but lacking in its usual power. There seemed a delay in turbo boost , then a puff of black smoke at mid revs. This morning she had a queue behind her up a hill as the car struggled to get her to work. Reading up on internet it seems it could be MAP sensor Temperature sensor (fuel?) The rolling resistance is fine. No unusual noises (not loud). EGR was cleaned back in November so probably not this. Engine is not shaking etc. The boost pipes seem fine (they were replaced a few years ago). If they detach then the car is undrivable I have found btw. ICarSoft scan revealed nothing last night, no engine check light etc.
  19. Car is a 2016 model with solid rear beam. It has probably seen mainly town driving although I try to use it for longer journeys as DPF doesn't like short less than 10 miles runs esp on standard diesel, cold weather. Relatively speaking, the new shocks extend faster than the old, but both are similar so I didn't think the old were knackered (this is the Astra) - that car has Whiteline rear axle bushes that are too harsh and getting removed and going back to rubber because despite fast road use designation they are too compliant. Yeti yeti - what brand did you get from Demon tweaks? That is a good price. I paid £84 off eBay for a pair for the Astra. CP4l wanted £130 even with discounts. Demon tweaks - £200 per pair. The solid rear axle is double the price of the multilink suspension it seems for the B4 Bilstein shocks. Halfords quoted £101 per pair for Bilstein, but it also listed two other shocks. When I checked with staff I got told this is the one that is compatible Sachs Shock Absorber Rear VW Golf VII 12 635443800 747998. £150 per pair. CP4l want £168 per pair.
  20. Octavia 3 2l TDI 150 l@k The car has developed a subtle wobble side to side, only noticeable at low speeds (20 - 30mph). I have checked all wheel bolts and they were torqued up to 120Nm. No untoward incidents with potholes or speed bumps etc. Doesn't seem related to engine. Even my wife noticed it so it isn't just me. Car has done 45k miles, so a tad early to be changing the rear shock absorbers? However, from experience I've found that the rear shocks fail first then the front unless a pothole or speed bump is hit etc. The car is still running on original parts. No recent tyre changes. No vibrations through steering. The rear tyres are old and down to 4mm but at speed 60 to 70mph the car is smooth (roads are good) unlike local undulating ones here. Is there a way of checking? The stiffer springs hide a knackered shock on the bounce test. I disconnected the lower shock bolt on another car when changing a broken spring and was confident the rear shocks were good (no oil leaks, non jerky compression and release through entire compression and fairly fast movement). It turned out to be at fault and the noise disappeared on fitting two new rear shock absorbers. I'm looking at £150 for Sachs parts. Any other brand to consider. I ask because the local motor factor sold me ,'oem ' Vorstadt for the Astra and it is these that failed after 15k miles. I opted for Bilstein B4 for that car. Opinions on brands, what else to check? Etc
  21. I have quite liked Brembo pads and discs, they have a quicker initial bite. Just fitted a whole new set on a non Skoda car and was looking to buy for my Fabia. The Apec front disks on my Fabia have done nearly 50k miles and the only judder I had was when the carrier bolt became loose due to rusted threads. After a few thousand miles after a new hub fitted the slight judder disappeared as the pads bedded back in. Maybe check the carrier bolts?
  22. Mcgard brand is good. Replaced some on a land rover whose wheel nuts are 2 piece welded together and start to sheer and round. Eventually they separate and you have nothing to grab your hex socket or locking key with. The jaguar nuts are the same and even worse, even when torqued correctly.
  23. A bit late reply, but try a socket set for rounded bolts, loads out there. Can't recommend a brand as once I bought a set I've never rounded a nut since. They are a hex socket but the hex is offset to 'bite' the now rounded bolt, obviously they won't fit the unrounded correct size bolt. Always spray PTFE containing penetrating oil at least 10 mins before tackling the job. I wouldn't use a spanner. If access tight try 3/8" drive breaker bar and slim socket. Hope this helps.
  24. Have a look above gearbox you will find a bleed nipple on a black hose going above gearbox area. It shares brake fluid in brake fluid reservoir. You will need a pressure bleeder something like sealey vs820 bleeder. When Fabia clutch release bearing leaked brake fluid the clutch pedal wouldn't come back up. The low brake fluid due to leak allowed brakes to function but the clutch pedal acted up first (for safety). Check your brake fluid level. If low look under car. If no leak, then bleed clutch. Same nipple as on the brake calipers.
  25. I took it to garage for £45. I don't have a vice, so it would have meant me going to parents and use theirs, then either use the hammer or the larger CV joint puller. Got the inner CV boot changed as this one has more angle / Flexi due to driveshaft being shorter on front left and I noticed it often splits. For £12 saves fath in a few years when it would have gone. Apparently, the gearbox doesn't leak oil when driveshaft taken off on this model. Garage did say the plastic specific fit outer CV boot was a pain to fit (that is all I could buy, although they said universal rubber might be better). I had to take it back down as the smaller crimp over driveshaft 3cm diameter was wandering over driveshafts between the two boots! There is a notch/depression in the driveshaft for it to seat.
