Everything posted by nicknorman
280 4x4 suspension (DCC) and brakes...
Before I sold my car the front shocks were an advisory for several years. After a couple of years, one gave way. A year later I sold the car and the other feont shocker was still ok more or less. So several years of “light misting” can happen before failure. I would get replacements from eg Autodoc BEFORE they fail an MOT, because then you will have to get from TPS and that will be £500 a side. As to brakes, almost anything is better than OEM. I fitted Delphi, much better despite being a budget product
Fault code questions please
Pretty sure that a code reader like that only looks at the engine module. The other modules are manufacturer-specific and you need something like VCDS or ODB11 to read them. The NoX sensor is probably duplicated and it is using the fallback one (or the fallback one is faulty) and so probably no impact in how the engine runs. Unrelated to the other faults you mention
Škoda Superb III 2020 2.0 TSI SportLine DSG oil change
I read your posts. Nowhere do you say it is a 7 speed.
About to embark on Skoda ownership, Superb L&K Estate
I can see from the MOT history that the front shocker was replaced in Feb 2022 at 75,800 miles, ie it has done less than 30,000 miles. They cost around £500 each so I would have thought it had some second hand value. I was a bit surprised that the garage didn't suggest replacing both, but on the other hand I had not noticed a significant problem with the handling etc even though the duff one had zero fluid or damping - and most of my driving is on twisty Scottish roads where I don't tend to hang about. The antiroll bar seemed to transfer sufficient damping from the other side. So a slight mismatch between a worn and new one isn't going to be detectable especially with the DCC system individually modifying the damping on each shocker "on the fly".
Been there and very nearly done that with the “virtual pedal” several times. One time in the garage with a lot of junk behind the car, I sidled past it must have had a foot slightly underneath, boot opened and knocked me over onto the pile of stuff. Still, that was better than putting a dent in it. And very nearly put a dent in it on my new one when I had just disconnected a glider trailer. It is also very easy to accidentally press the boot open button if you have the fob in your pocket. I use a small leather key fob holder to reduce the instances of that happening. If you need any scans from VCDS on my FL 2023 L&K with heated steering wheel, just ask. It does have predictive ACC so the setting for that will be different and I suppose the modules may be later versions.
Sorry to bang on about it but pretty sure the DSG oil level is higher with engine off than with it on. So if you set the level with the engine off, it will be low. The manual says that with the engine running, every 30 secs there will be a squirt of oil out of the overflow but this is not to be taken into account. Could it be that this is what you saw coming out of the overflow, when in fact the actual level is low?
Please check the manual re. DSG oil level - it sounds like you checked the oil level with the engine stopped, but the oil level should be checked with the engine running at idle in P. It makes a big difference!
I traded it in for a new one on Dec 8th. It was sold again by a different dealer, presumably having been via auction, I think early Feb (so actually more like 2 months). And the car has done 102,000 miles in Scotland, mostly in the Highlands.
Well no, the car was always garaged (garage with good ventilation). There has been a lot of deterioration in the 3 months or so it was parked after I dropped it off at the dealers in early December, having driven 100 miles on wet salty roads to get there. The salt was obviously never washed off during those 3 months. This is not something I had really thought about before, although it has to be said that all my previous cars were bought second hand (with relatively high mileages) from as far south as I could manage, where there is less salt on the roads. Modern cars really should be salt-proof, but clearly they are not!
Tarnished L&K exterior trim and unstable infotainment (automatically reboots)
No experience of it myself, but mr Google turns up stuff like this which suggests that it depends on exactly which product… Regular snow foam is slightly alkaline. This helps it break down dirt more effectively, but it can also slightly affect the sealants on your car’s paintwork, too. While some professional-grade cleaning products are quite caustic, most of the ones you’ll find in shops are only very slightly alkaline and won’t affect your paintwork in any noticeable way. However, if you have a valuable or vintage car, you might not want to risk it. That’s why pH neutral snow foam is so popular – it’s chemically neutral, so it’s safe to use on even the most sensitive and valuable car
When I picked up my new L&K last year, the dealer branch manager mentioned that if I used the snow foam stuff to clean the car, it would tarnish the chrome strips as it is very caustic. Because this would be due to use of aggressive cleaning chemicals, it would not be covered by warranty. No problem for me because I never use that stuff. But even if that is the problem, it’s something that the dealer should sort out before you buy it, regardless of being a warranty issue or not.
Hot air on passenger side. Only cold air on drivers side.
Is there actually a different matrix for LH and RH sides? I wouldn't have thought so. I would expect there to be one source of hot air that is then mixed with cold air with valves to get the right temperatures in the various zones. Could it not be the temperature control flap sticking on that side, or the motor defunct?
Certainly an astonishing amount of rust underneath. As I said before, I think it must be due to being left for 4 months covered in salt spray. Pretty sure it was only beginning of last year I replaced the rear NS spring, which I did without a compressor - ie disconnected the lower arm from the damper, the level sensor, the drop link and the hub. I wasn't particularly dificult. And I did put grease on the bolts when reassembling, though probably just ordinary grease. And of course the OS spring was replaced by the MOT garage in Feb 2023. Which was annoying because when I checked it at the same time as doing the NS spring (a few weeks before the MOT), it wasnt broken! As to the level sensors, they are different according to the fitting position but the actual clever bit is the same, only the bracketry is different. So if you can't find the one you need on ebay, you can get the one that is on ebay and transplant it to the old bracketry. Somewhere it says to do the bolts up on the suspension when the springs are compressed to normal unladen weight position (to avoid twisting the rubber bushes too much) but you probably knew that already. Thinking about the pedals, I did have a racechip throttle box on it which did make a big difference - really dead without it until it goes woosh - but I suppose the need for that depends on what your plans are for the tune state.
I’d recommend undoing the engine oil filter first - at which point oil drains back into the sump, before undoing the sump plug. That way the oil all comes out at once, rather than a bit dribbling out afterwards and blowing everywhere! Oil filter goes in either way up. You can get to the DSG oil filter without removing the battery, contrary to the workshop manual instructions. i would avoid draining the DSG until you can run the engine, because you need to have the engine running to refill the DSG and it’s probably not ideal to leave it empty for a while. Battery is original so it can’t have much life left, although I did tend to turn off auto-start-stop most of the time. That said it never exhibited any signs of being low on capacity.
Yes I agree. I’ve had Saabs and Subarus much older that didn’t have as much rust. To be fair I do a lot of driving on the A939 but even so … did the same thing with the Subarus and Saabs, all of which were well over 10 years old when I sold them, and not in bad condition. Not sure if it is a “bad car” or if it’s par for the course for VW group cars. I need to work out how to make my new Skoda last better!
I think the huge amount of rust is in part due to the fact that I dropped the car off 8th December having driven 100 miles on very salty roads, lots of salt spray on the motorway etc. The car then sat there, or elsewhere, for several months caked in salt. Normally after a brief salty road spell there would be lots of rain and thus cleanish water spray to get rid of the salt. The worst bit was having to drive my gleaming shiny new car the other way in the salt spray. By the time I got home it was filthy! On the wheel bolts, as far as I know one is not supposed to put grease on VW wheel bolts? Someone please correct me if I’m wrong? I had a huge amount of hassle with one locking wheel bolt that refused to come off, in the end I had to take it to a small local garage who were prepared to use obscene force to get it off. After that replaced all the locking wheel bolts with ordinary ones. I always put lots of grease on the wheel centre hole and face, but the wheels do seem prone to sticking on due I think to corrosion of the wheel centre hole. There should be the plastic wheel bolt cover removing tool in the toolkit under the boot floor. Re. The damage to the front left bumper, this was no kerb, that was a big fat badger that ran in front of me at a range of about 5 metres, I was doing about 50. Behind that area is a plastic duct that takes cooling air to an aux radiator further back. Shards from the plastic duct punctured the radiator, so 10 seconds later I got the “coolant low” warning. Fortunately I was close to destination and with one stop to beg water from a house, I got there with no overheating. I bought a new radiator and a new duct, but I just patched up the front bumper with hot staples.
Just on the sump drain plug thing, you are supposed to replace the plastic sump plug each time. Not a big deal as they are about £3.50 from TPS. Recently I made a stupid mistake. I’d run out of the pukka drain plugs and didn’t want to go to TPS so I ordered a couple from eBay. They were much the same price as the TPS ones, but would come through the letter box. I drained the oil and put a new sump plug in. Ran the engine in the garage a bit to check the oil level. Everything fine… Next morning I came down to about 5 litres of oil all over the garage floor. This definitely spoiled my day! Still, could have been worse, I might have run out of oil when driving! Turned out the O ring on the plug was the wrong size - just slightly too thin - and this allowed the oil to drip out over night. Needless to say I then made the trip to TPS. So the moral is don’t use anything except the pukka sump plug from TPS unless you are CERTAIN it is the exact right size!
Just FYI, when I was going to buy the car there was the retracting tow ball that I needed, but no reversing camera. All that great expanse of white plastic bumper... asking for trouble! So I got them to retrofit the factory camera system before I bought it. I think it was just the early (2016) L&K 280 tsi that didn't have the camera as standard. Never mind, it is there now! If you do any towing, bear in mind that as soon as you plug in the trailer electrics, the side assist and rear traffic alert are automatically disabled. When you unplug the trailer electrics, these two systems do not automatically re-arm! (They do on my new car) So it can be a bit misleading if you are expecting the rear traffic alert or side assist to work as normal, but in fact they are disabled without any obvious indication. You need to remember to re-activate them once the trailer is unplugged. Also with the camera, there is a useful "look down" mode that looks down onto the tow ball and a line to tell you where to put the steering wheel to hit the tow hitch directly. And of course when to stop!
MIB3 Update OTA 0330
For me the best fix is the Apple Carplay that doesn't disconnect 30 secs or so after starting, then reconnect.
The car already has the "virtual pedal" which is what I think you are talking about? Wave your foot just under the rear bumper area to open the boot? It seems to work well when the car is locked, much more reluctant when the car is not locked. No idea why, but the new car seems to be much the same. Maybe it relates to having the folding tow ball (both the cars have that). And the key fob has to be close but not too close.
Wow huge amount of work there! I’ll just mention that the Haldex fill screw has a very small hex socket that is made of cheese. I wasn’t quite clear from the above whether you have one, but I’d get a new fill hole bolt before changing the Haldex fluid. It will be interesting to see how much gunge there is on the Haldex filter and in the oil. It was horrendous the first time, better but still fairly grotty the second time. Maybe it will be less grotty this time if the wear has settled down. Hopefully we’ll see.
Some great work there, at least you didn’t find anything else too embarrassing under the seats! When I replaced the rear LH spring my spring compressor didn’t fit - the manual shows kind of blade things that engage with the spring, while the screw bit is off to the side. But I discovered that it was easier to drop the lower suspension arm right down - this involved disconnecting the drop link and the position sensor as well as the damper of course. But dropping the arm right down enabled the spring to be inserted un-tensioned, then I jacked up the lower arm to tension the spring until the damper could be reconnected. The droplinks etc do look rusty, but there was no play in them when I did this job a year or so ago. Mind you with shiny new dampers, maybe rusty drop links will offend!
I’ll check that. I think it has also fixed the annoying issue with Apple CarPlay where on startup it would be connected, then it would disconnect after 30 secs or so, then eventually reconnect. This morning it seemed to remain connected.
Mine just did this update. As said, a few scary messages and it took it a few days, but I am now on 330. I have yet to notice any differences though!
It does sound like the pipe has come undone again. I fixed it after the MOT last March and it was still working fine in December. You should be able to access it easily by removing the wheel arch.
