Everything posted by nr26410
Park assist - what am I doing wrong
Digital certificate can't be trusted. I have factory options and some are listed and some aren't listed.
Touchscreen Cracked
Appreciate its a bit of a distance but it might be worth you speaking to the guys at https://eastyorkshireretrofits.co.uk/ or https://www.vw-retrofit.co.uk I know both have done installations with customer supplied parts. I can't say for certain, but you might find you need to code the new unit once its installed.
Delivery times?
You probably know anyway but in the hope it might help. Do you have the heated windscreen icon in the clima screen? They don’t use wires in the screen anymore. Confused me when I changed from my 67 plate to the MK4. In the right light my screen has a bronze tinge that is the give away.
vRS Engine Cover Recall
@TheWanderer I asked my dealer a similar question and they said they referred it to Skoda UK as they weren't sure what the situation was for those who's cars didn't come with one. I'll update here when I hear, but I would be interested to hear what others folks find out.
Sound deadening project
Is this what you were looking for? https://www.skoda-parts.com/spare-part/5e3863831-bonnet-silencer-skoda-40332.html
I checked mine too and no recall, 6 months old and was supplied without one so I guess that is why. I had hoped Skoda would install covers on the ones that came without but not holding out too much hope.
Dealer Central Console Damage
I had damage to my paint work following a dealer visit and they kept denying they had done it. I contacted their MD and Skoda UK along with leaving truthful but accurate reviews on the web. They wouldn't admit liablity and said it was goodwill but they paid to sort it. Don't give up!
Hi @BNB90 what page / location did you get that info please? Cheers
Traffic Awareness in Mirrors.
No
Try https://eastyorkshireretrofits.co.uk I'm sure they posted pictures of a MK4 retrofitted on FB.
Octavia iV reversing camera retrofit service!
Not local but maybe closer than Bridlington, https://www.facebook.com/vwretrofit do them. Found https://www.hazzydayz.com in St Albans too. Not used these guys so can't give any recommendation.
Octavia VRS TSI clunking sound.
Literally 5 mins if that. Once on the ramp they lift the gaiter and pull it out.
When I had my first MK4 the dealer had not removed the shipping blocks from the front suspension under the rubber gaiters. When I went over a pothole one of them broke and that made a sound similar to what you describe. Dealer removed them from both sides and all was good. I appreciate its a long shot since you covered 35K kms but maybe worth checking.
Has Laura overdosed on the steroids?
From memory its tucked away under Settings... Language ... I think its the last option.
Yellow cap found under bonnet
Hi all I found a yellow cap under the bonnet of my 2023 petrol VRS. It's about an inch long and 1/2 inch across. I can't see anywhere obvious its come from, and didn't notice last time I cleaned the car or topped up the washer water. Any thoughts? Cheers
Infotainment System Restarting endlessly
I was a little worried about warranty so as my dealership is a few minutes from my house I decided to call and ask for the update. Assuming all goes to plan there agreed to install it after I quoted the TPI number. Only thing they mentioned was that the TPI was now /11. Not sure if that helps anybody.
@varooom I would like to update too, could you share the link when you get a chance please. Thank you so much for helping us all.
Skoda Octavia IV pictures thread
Thanks!
I'm planning to swap mine too. Was it difficult to do, what was the procedure? Thanks
Lost Key Replacement
You could try https://www.vw-retrofit.co.uk/product-category/car-keys/ https://www.facebook.com/vwretrofit He has a good reputation.
At long last... SW Version 1896
Car was in yesterday having the update and although I haven't done any real driving or testing, initial signs are good. Screen response is much quicker imo, lights now set to drive on left and can be changed without having to first select the already selected option. I'll test the cruise control at the weekend. At the same time they did the boot damping recall, sounded fine on the way home but I never really had that issue as I greased the wedges when I first got the car. Car was in for a day but only worked on for a few hours according to dashcam footage. For reference I requested the update, dealer did not contact me to say it was available. I had cases open with VWFS and Skoda Customer Services but no contact from them either so thanks to all on this forum.
Reversing camera retro fit?
AFAIK they lost access to be able to unlock SFD!
I just wanted to add an update to this. In my case, I'm not saying it will happen to anybody else, since the last dealer visit for numerous s/w issues and a subsequent s/w update - I've lost the use of the retrofitted camera completely!! I believe, although it is practically impossible to get the full story, all s/w on the car was removed/reloaded hence why I lost the retrofit coding as its gone to factory default. It's a real pain b/c the servicing dealer won't acknowledge an issue and the installer appears to be having issues unlocking for recoding. I'm being compensated by the supplying dealer but a pain none the less after getting used to having it.
I have a camera on my 21 Octavia VRS that was retrofitted because the dealer messed up my factory order. Cutting a long story short the camera was fine until my local dealership updated the camera s/w and subsequently I lost the contrast settings although the camera still works. Although I'm sure the company that fitted the camera could re-instate the contrast settings I'm taking a different route with the dealership due to all the other s/w issues so decided not to persue that. Vagtec fitted he camera so might be worth calling them to see if they have a permanent fix.
ACC Braking when overtaking
How did you get on? I'm in a similar situation and have been told by the dealership pretty much the same, although I have a case open with Skoda UK too.
