Carlston
Everything posted by Carlston
  1. Non-standard 215/70R16 will fit the Kodiaq if the front discs are 312x25mm or 314x30mm. 340x30mm front discs do need at least 17" rims to clear the front brake calipers. Only Kodiaqs with more than 150HP use the biggest 340x30mm front disc size. Vredestein Quatrac 215/70R16 100H https://www.blackcircles.com/catalogue/vredestein/quatrac/215/70/R16/H/100/m?tyre=41007506 6.5Jx16 ET33 5/112 57.1 steel rims (from the VW Tiguan MK1) https://www.mytyres.co.uk/rims/details?vehicleId=62269191771657328&rimCode=ALCAR9922 The VW Tiguan MK1 uses a 215/65R16 tyres for its 16" wheel size.
  2. Have you tried the Osram lamp finder? https://www.osram.com/apps/gvlrg/en_COM
  3. It's that time of year again when it gets cold. UHP summer tyres turn into ULP winter tyres below about 7 degrees Centigrade. Vredestein Quatrac tyres are one of the best tyres for use in cold, wet weather. Just read the reviews. In cold rain, the Michelin CrossClimate 2 took over 5% longer to stop than the Vredestein Quatrac Pro. 2022 All Season Tyre Review https://www.tyrereviews.com/Article/2022-Tyre-Reviews-All-Season-Tyre-Test.htm Vredestein Quatrac Pro 205/55R17 95V XL https://www.camskill.co.uk/m140b0s8838p193509/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_Pro_-_205_55_R17_95V_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_72dB
  4. You could try hooking the end of the metal tape measure to the edge of the rim near the road, then deduct the radius (half the diameter) of the rim.
  5. You can see in the charts below, that the Karoq (Front Wheel Drive) has 225/40R19 tyres when the 19" option is specified. For someone with a back problem, these are completely unsuitable. Changing to 215/60R16 tyres fitted to 6Jx16 ET43 5/112 57.1 rims (this is a standard tyre and rim combination on the Karoq (front wheel drive) will make the ride a lot softer and more comfortable. Make sure you choose tyres with soft and flexible sidewalls to get the maximum improvement. Skoda Karoq 2018 1.5TSI (Front Wheel Drive) – Generation: NU7 [2017 .. 2022] – Market: EUDM – Power: 148 hp | 110 kW | 150 PS – Engine: 1.5L, DADA, I4, Petrol – Options: SE, SE L, Ambition, Executive, Style, SportLine, Premium – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 140 Nm – Thread Size: M14 x 1.5 – Trim Production: [2017 .. 2021] Tire Rim 215/60R16 95V 6Jx16 ET43 2.2 215/55R17 94V 7Jx17 ET45 2.2 215/50R18 92V 7Jx18 ET45 2.4 225/40R19 93W 8Jx19 ET45 2.4 235/40R19 96W 8Jx19 ET45 2.4 Skoda Karoq 2018 1.5TSI (Four Wheel Drive) – Generation: NU7 [2017 .. 2022] – Market: EUDM – Power: 148 hp | 110 kW | 150 PS – Engine: 1.5L, DADA, I4, Petrol – Options: SE, SE L, Ambition, Executive, Style, Scout, SportLine – Center Bore: 57.1 mm – PCD: 5x112 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 140 Nm – Thread Size: M14 x 1.5 – Trim Production: [2018 .. 2021] Tire Rim 225/55R17 97V 7Jx17 ET45 2.4 225/60R16 98V 6Jx16 ET43 2.3 225/50R18 95V 7Jx18 ET45 2.4 225/45R19 92W 8Jx19 ET45 2.4 https://www.wheel-size.com/size/skoda/karoq/2018/#trim-15tsi-eudm-148
  6. VAG springs can vary by more than 5mm even when they are new. Different batches, different OEM suppliers, different factories, etc. It's better to measure the ride height from the centre of the wheel to the top of the wheel arch, rather than from the road. The road isn't completely flat and tyres wear and the tyre pressures change over time. Some people might even fit different tyre sizes over time. The official ride height measurements will also be taken from the centre of the wheel/hub.
  7. Being an Octavia MK3 pre-facelift diesel VRS it's likely to have 340x30mm front discs and 272x10mm rear discs. It's probably best to measure the diameter of the discs to be sure. The Octavia MK3 facelift diesel VRS has 312x25mm front brake discs which allow for 16" wheels, whereas the 340x30mm front discs need at least 17" wheels to clear the front brake calipers. 340x30mm front brake discs with red brake calipers have build code 1LG https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/615/615040 272x10mm rear brake discs with red brake calipers have build code 1KT https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/615/615062
  8. 225/50R18 fitted to a 7J rim is about 233mm wide when inflated. That's about 18mm wider than a 215/65R16 fitted to 6J rim. Before purchasing a full size spare, I suggest you try the 225/50R18 tyre/rim before making any purchase decision. The 225/50R18 might only fit with the carpet flush when there's no air in the tyre. The 125/70R18 space saver tyre is a bad idea on the Karoq 4x4 (or even the Karoq 2x4) because the outside diameter is much smaller than the full sized tyres. It would be better to change to 135/80R18. The 135/80R18 space saver tyre could be fitted to the same rim that the 125/70R18 uses. A 135/80R18 has an outside diameter 1.3% smaller than 225/50R18, whereas the 125/70R18 has an outside diameter 7.3% smaller than 225/50R18. Outside diameter of tyres 125/70R18 632.2mm (7.3% smaller than 225/50R18) 135/80R18 673.2mm (1.3% smaller than 225/50R18) 225/50R18 682.2mm 215/65R16 685.9mm (0.5% bigger than 225/50R180 135/80R18 space saver tyres https://www.camskill.co.uk/m129b0s7672p0/Temporary_Spare_Tyres_-_Space_Saver_Tyres_-_18_inch_R18_inch_-_135_80_18_135_80R18_R18_inch_-_135_18_135R18
  9. The below information is taken from the 31/8/2020 Octavia MK4 owner's manual. However, 16" rims won't fit over the front brake calipers on 340x30mm front brake discs. However, owner's manuals from 14/6/2021 state that snow chains can be used with links and locks no larger than 13mm with the 205/55R17 6.5Jx17 ET46 tyre/rim combination, and they don't mention the 16" tyre/rim combination at all. Snow chains (from the 31/8/2020 Octavia MK4 owner's manual) The snow chains improve driving in wintry road conditions. Risk of accident as well as tyre damage. Do not use chains on routes that are free from snow and ice. Before fitting the snow chains, remove the full wheel trims. Only mount the snow chains on the front wheels. Permitted rim/tyre combinations for mounting of snow chains. 205/60R16 6.5Jx16 ET46 205/55R17 6.5Jx17 ET46 Only fit snow chains with links and locks that are no larger than 9mm. https://digital-manual.skoda-auto.com/w/en_GB/show/910deba671a3412ad565664dc8a32a82_7_en_GB?ct=910deba671a3412ad565664dc8a32a82_7_en_GB#titled20479122e115149
  10. Kilen lists 3Q0511115AK standard ride height rear springs for the Superb MK3 2.0TDI 140kW FWD hatchback/estate. Kilen lists 3Q0511115AL standard ride height rear springs for the Superb MK3 2.0TDI 140kW 4x4 hatchback. Kilen lists 3Q0511115M standard ride height rear springs for the Superb MK3 2.0TDI 140kW 4x4 estate. If you get hold of your car's build codes, you will be able to see what was fitted when the car left the factory. There's an ebay seller who can supply the build codes for about 3 Euros. Search "skoda vin decoder" on ebay. search "skoda vin decoder" on ebay https://www.ebay.co.uk/itm/224631127243 For example, build codes 1JA+0YC would mean that you have 3Q0511115AK rear springs as shown in the chart below. You might find that your car has around 180 build codes, but the exact number varies from car to car. Once you have your build codes, you can input them into the "vw codes decoder" to find out what they all mean. "vw codes decoder" http://igorweb.org/equidec.aspx Superb MK3 standard ride height rear springs 1 3Q0511115AH Coil spring 2 PR-1JA+0YA 1 3Q0511115AJ Coil spring 2 PR-1JA+0YB 1 3Q0511115AK Coil spring 2 PR-1JA+0YC 1 3Q0511115AL Coil spring 2 PR-1JA+0YD 1 3Q0511115M Coil spring 2 PR-1JA+0YE 1 3Q0511115N Coil spring 2 PR-1JA+0YF 1 3Q0511115P Coil spring 2 PR-1JA+0YG 1 3Q0511115Q Coil spring 2 PR-1JA+0YH 1 3Q0511115R Coil spring 2 PR-1JA+0YJ 1 3Q0511115BC Coil spring 2 PR-1JA+0YK https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/511/511000
  11. wheel-size.com lists 17" wheels for the Cupra R which uses the 323x28mm front brake discs. However, the Seat parts catalogue shows two different types of front brake calipers that are used with these size discs. The Brembo front brake calipers are listed as 18" on the Skoda parts catalogue, so they would appear to need at least 18" rims. Seat Leon 2002 1.8i Cupra R – Generation: 1M [1999 .. 2005] – Power: 221 hp | 165 kW | 224 PS – Engine: BAM, I4, Petrol – Center Bore: 57.1 mm – PCD: 5x100 – Wheel Fasteners: Lug bolts – Wheel Tightening Torque: 120 Nm – Thread Size: M14 x 1.5 – Trim Production: [2002 .. 2005] Tire Rim 225/45R17 91H 7Jx17 ET38 2.3 225/45ZR17 91W 7.5Jx17 ET38 2.3 225/40ZR18 92Y 7.5Jx18 ET38 2.3 225/40R18 91H 7.5Jx18 ET38 2.3 https://www.wheel-size.com/size/seat/leon/2002/#trim-18i-cupra-r-eudm-221 The Seat parts catalogue lists 7.5Jx17 ET38 5/100 rims and 7.5Jx18 ET38 rims for the Cupra R https://www.lllparts.co.uk/catalogs/seat/E/LE/268/6/601/601051
  12. Just to add to the above information: A 215/65R16 tyre fitted to a 6J rim is about 215mm when inflated. A Superb MK3 only accepts a 215mm wide tyre (when inflated) in the spare wheel well without raising the carpet, so maybe that's also the limit for the Karoq. Although it could be that the Karoq 4x4 and Karoq 2x4 are different. As you can see in the chart below the 225/45R19 and 215/65R16 tyre sizes have almost identical outside diameters. If the inflated 225/45R19 fitted to an 8J rim is raising the carpet, then the 215/65R16 fitted to a 6J rim would lower the carpet by about 16mm. So if 215/65R16 fits in the spare wheel well without raising the carpet, then that would be a better size to use as a spare rather than 205/65R16. Outside diameter of tyre 225/45R19 685.1mm 215/65R16 685.9mm 6Jx16 ET43 5/112 57.1 steel rim https://www.mytyres.co.uk/rims/details?vehicleId=1302234084152546416&rimCode=ALCAR6665 https://eshop.skoda-auto.cz/cs_CZ/plechovy-disk-16-/p/5Q0601027CJ03C
  13. There's no need to remove the lip with a file before measuring with digital calipers. Just use something like a couple of magnets to measure the thickness of the disc including the thickness of the magnets. Then deduct the thickness of the magnets to get the thickness of the disc. Or if you haven't got magnets, use something else such as a couple of coins. That way, the digital calipers will be able to reach over the lip without the lip affecting the measurement.
  14. Yes, the OP does appear to have purchased a Karoq 4x4 kit instead of a Karoq 4x2 kit for his Karoq 4x2...at least going by the OEM part number. If you purchase the kit, I suggest you try one of your 225/45R19 wheels to see if its a good fit...including whether the carpet sits flush with the wheel in the spare wheel well. A 225/60R16 tyre fitted to a 6J rim is about 222mm wide when inflated. A 225/45R19 tyre fitted to an 8J rim is about 231mm wide when inflated. Therefore, if the carpet is a little raised with the 225/45R19 wheel in place, it might be better to use a 9mm (ie. 231mm-222mm=9mm) narrower 225/60R16 spare wheel. Many people incorrectly think that the 225 marked on the tyre's sidewall means that the tyre is 225mm wide. This is incorrect, because the 225 that is marked on the tyre's sidewall is only the nominal width. The actual width (when the tyre is inflated) varies depending on what rim width the tyre is fitted to. If the 225/60R16 tyre fitted to a 6J rim is still raising the carpet, then using a narrower non-standard 205/65R16 tyre but fitted to the same 6Jx16 ET43 5/112 57.1 rim could be used. A 205/65R16 tyre fitted to a 6J rim is about 209mm wide when inflated.
  15. There are two kits shown on "skoda eshop cz". One is for the Karoq 4x2 and one for the Karoq 4x4. The OEM part number for the Karoq 2x4 kit is 57A093860 The OEM part number for the Karoq 4x4 kit is 57A093860A https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/57A093860 You could probably order either of them through a UK Skoda dealer.
  16. An 80% of the tyre width rule wouldn't take into account the aspect ratio. As you can see in the chart below, the ETRTO approved rim widths vary depending not only on the width of the tyre but also the aspect ratio. As the aspect ratio goes down, the range of approved rim widths tends to go up for any given tyre width. ETRTO approved rim widths for passenger car tyres 205/80 5.0-5.5-7.0 205/70 5.0-6.0-7.0 205/65 5.5-6.0-7.5 205/60 5.5-6.0-7.5 205/55 5.5-6.5-7.5 205/50 5.5-6.5-7.5 205/45 6.5-7.0-7.5 205/40 7.0-7.5-8.0
  17. For the Octavia MK3 Scout, you could use 215/60R16 tyres and 6Jx16 ET43 rims from the Karoq. AT (All-Terrain) tyres are available in the 215/60R16 tyres size. AT tyres work better in the mud than normal tyres, but don't work as well in other conditions. However, tyres are always a compromise. If normal tyres are going to leave you stuck in the mud, then AT tyres could be a good idea. 6Jx16 ET43 5/112 57.1 steel rims (from the Karoq) https://www.mytyres.co.uk/rims/details?vehicleId=1302234084152546416&rimCode=ALCAR6665 Yokohama G015 Geolander AT 215/60R16 95H https://www.camskill.co.uk/m62b0s111p164244/Yokohama_Tyres_Car_Yokohama_G015_Geolander_AT_Yokohama_G_015_-_215_60_R16_95H_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_71dB Another tyre and rim size option could be 205/70R15 tyres fitted to 6Jx15 ET43 rims. 15" tyres and rims will only clear the front brake calipers if the front discs aren't bigger than 288mm diameter. The Octavia MK3 might not use front discs bigger than 288mm if the engine power is no more than 150HP, but it's worth checking or measuring the diameter of the front brake discs to be sure. 6Jx15 ET43 5/112 57.1 steel rims (from the Octavia MK3) https://www.mytyres.co.uk/rims/details?vehicleId=502374559312254064&rimCode=ALCAR7755 Yokohama G015 Geolander AT 205/70R15 96H https://www.camskill.co.uk/m53b0s2481p148166/Yokohama_Tyres_Car_Yokohama_G015_Geolander_AT_Yokohama_G_015_-_205_70_R15_96H_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_70dB
  18. Some Octavia MK3 VRS owners have fitted 235/35R19 tyres to their 7.5Jx19 ET51 X-TREM rims, instead of the standard 225/35R19 size. 235/35R19 is a more common tyre size. However, ETRTO recommends at least an 8J rim for the 235/35R19 tyre size as shown in the chart below. ETRTO approved rim widths for passenger car tyres 225/35 7.5-8.0-9.0 235/35 8.0-8.5-9.5 Michelin CrossClimate 2 235/35R19 91Y XL https://www.blackcircles.com/catalogue/michelin/crossclimate-2/235/35/R19/Y/91/m?tyre=42847916 225/35R19 or 235/35R19 don't have much sidewall height, so there's a much greater risk of tyre and rim damage when driving over potholes. In the winter when there is snow and flooding, you might not see a pothole. Even in the summer, when driving at speed and in the dark you might not see a pothole soon enough to avoid it. If you want cheap but good winter wheels, maybe consider 6.5Jx17 ET38 steel rims from the Kodiaq fitted with 205/50R17 winter tyres. The Continental WinterContact TS870P have done really well in the latest tyre reviews. Good winter tyres don't just work well below freezing, but below about 7 degrees Centigrade they will start to outperform summer tyres. 6.5Jx17 ET38 5/112 57.1 steel rims (from the Kodiaq) https://www.mytyres.co.uk/rims/details?vehicleId=672860434273997936&rimCode=ALCAR9021 Continental WinterContact TS870P 205/50R17 93V XL https://www.camskill.co.uk/m97b0s635p214354/Continental_Tyres_Winter_Snow_Car_Continental_Conti_Winter_Contact_TS_870P_-_205_50_R17_93V_XL_FR_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB
  19. If the thickness of the front discs is actually more like 28.5mm then just change the brake pads. If they really are 28.0mm (to the nearest 0.1mm) then change the discs as well. Most digital calipers can measure to one-hundedth of a millimetre, so there really shouldn't be any problem measuring to the nearest tenth of a millimetre.
  20. The 340x30mm front discs have a minimum thickness of 27mm. The 310x22mm rear discs have a minimum thickness of 20mm. To say 1mm off the minimum thickness is really sloppy. I would take measurements to the nearest 0.1mm not the nearest 1mm. For example, what were the measurements taken on the front discs. There's a big difference between 27.5mm and 28.5mm. 28.5mm and you would probably just fit new brake pads. 27.5mm and you would probably change the discs. Bear in mind that changing pads and discs is easy and profitable work for a mechanic, and there's a lot of overselling going on.
  21. 215/50R17 tyres have the same standard load index as 205/55R16 and 225/45R17, so use the same tyre pressures that you would use with those tyre sizes.
  22. 215/65R16 isn't a standard Octavia tyre size.
  23. On the Superb MK2, you could use 6.5Jx17 ET38 steel rims from the Kodiaq with 205/50R17 tyres. 6.5Jx17 ET38 5/112 57.1 steel rims from the Kodiaq https://www.mytyres.co.uk/rims/rim-selector?type=steel&vehicle_ids=1087544543219315824%3A%3A0002 205/55R16 tyres are a much cheaper and slightly more comfortable size than 205/50R17. Fitting a 205/55R16 tyre to a 6J rim will be more comfortable than fitting this size tyre to a wider 6.5J or 7J rim. 6Jx16 ET43 5/112 57.1 steel rim from the Karoq https://www.mytyres.co.uk/rims/rim-selector?type=steel&vehicle_ids=1285990449114256496%3A%3A0002 Other 6Jx16 options include 6Jx16 ET40 from the Superb MK1 6Jx16 ET40 5/112 57.1 steel rim from the Superb MK1 https://www.mytyres.co.uk/rims/details?vehicleId=180498027838968944&rimCode=ALCAR9490 6.5Jx16 options include 6.5Jx16 ET46 from the Octavia MK3 and the Octavia MK4 6.5Jx16 ET46 5/112 57.1 steel rim from the Octavia MK3 https://www.mytyres.co.uk/rims/details?vehicleId=1192953623500182640&rimCode=ALCAR8667 6.5Jx16 ET46 5/112 57.1 steel rim from the Octavia MK4 https://www.mytyres.co.uk/rims/rim-selector?type=steel&vehicle_ids=1275564879859717232%3A%3A0008
  24. I would like to drive a Skoda hybrid that hasn't been invented yet. It would have a 650cc 2 cylinder turbo petrol engine with 75PS and maximum torque produced from 1,600rpm. The electric motor would also have 75PS making a total power of 150PS. 0-100km/h in 8 seconds. The battery pack on its own would give a range of 500 kilometers. On petrol power alone its fuel consumption wouldn't be more than 4l/km at a constant 80km/h.
  25. A GTI has wider tyres, bigger brakes, and stiffer suspension than the plain vanilla version so it can go round corners quicker and stop quicker. However, the actuary who works out the risk for the insurance company will tell you that the GTI is a higher risk even though it has higher performance. Clearly, in general the person driving the GTI isn't using the extra performance to give him a bigger safety margin but is often driving faster and with reduced safety margins...and hence more accidents and the corresponding higher insurance premiums.
