Everything posted by Bingodalton
Superb FL with Golf 8R engine
I checked with one guy in my country and it is Gen4 DNFE engine and by picture (of low res) it has Continental turbo. I have checked in specs and this turbo is among parts. As well as engine. Tuners anounced that Stage 1 goes to 400, while Stage 2 goes to 455. At least.
Guys, is there somebody having new Superb 280 2021/2022 and check which engine is in the car? Is it Golf 8R engine? As I can see it could be, as well as new turbo charger.
Hard to get out of P when parked on a sleep slope?
It does not matter if it is before or after moving to P, just apply handbrake before releasing footbreak. Even if you have already turned off the car.
Skoda Superb Mk3 206 4x4 exhaust downpipe
@tmg there is just one video, you wanted to upload two? I am interested also in setup with just downpipe, how it sounds in normal and sport.
Activate parking brake before puting dsg to P. Only way to avoid this.
Really, a tow? Anybody to push a little bit, it does not look so serious.
Amundsen SD card compatibility, map upgrade & hidden slots
Original or clone, yes.
That is helpful tnx
@mcdaniels you could make some pictures with the bumper removed, how those clips look like, their code, price,... It could be helpful.
Copy Amundsen Satnav Skoda 16Gb SD card to 32Gb
SD clone has arrived and working flawlessly. For 12.22 Euro delivered it is great deal.
Buy a bigger SD card, you can go cheaper way doing this or less cheap.
Amundsen MIB2 Firmware Update
AUS - 206kw injection type
It is easier to take a picture of the engine, to know if there is MPI or not. I think, but I am not sure, that CJX does not mean it is with MPI.
MY21 even 206 maybe do not have MPI, even in Aus. Here in Serbia I see it in the pricelist, it is not 272 anymore, it is 280, but I think they did not included MPI again. 272 did not had MPI.
So you agree that you should buy new sd card next time when update size exceeds size of current sd card? And next time, and next time,... They could offer sd cards with some kind of discount when you bring old one. Let them think what to do with old one. Suppying 16gb sd card instead of 32gb at the beginning is silly. Just to sparr few euros. Basically its the same, no reason to be happy. Maps are free, but you pay for sd card.
To support what? Maps are free.
Since new map is bigger than 14.8gb of old card size, I have ordered new 32gb sd card from china and supplied them CID of my 16gb card so they can set it up. So, waiting the card to arrive. This should work, or at least is worth trying for 12 euro.
Skoda Superb III 4x4 280 - A sleeper’s journey – 280ps to 560ps
You have digital one, just select it on central display. But question is more for @superbtte as he was driving mora than that speed.
No action here, but I have a question. Have you managed to make speedo show more than 260km/h? My speedo stops at 260km/h, but car keep pulling (limiter is removed by tuner). I am not sure if I can change digital speedo max value with VCDS or some other way.
Tyre Pressure Monitoring System Fault
There are two different TPMS so messages are different. First one is direct one and you can see which tire is deflated, second message is related to indirect (ABS) TPMS, so it just brings error that something is wrong. If you have problem with ABS sensor, it would be shown as error and you would have a problem with stability control. You said you have replaced the tire. So you have a new one and 3 used ones? On the other side, maybe you really have problem with the pressure this time. Have you checked it on all 4?
It is original spare wheel, I suppose they know what they are doing. It is on the front axle, it is open diff. Still back one works differently.
9You need some more distance in order to get warning. I was driving with spare for few days, got error. It was inflated to 3.5 bar, max and recvomended is 4.2. At 4th day I even got esp intervention, braking the car on straight will driving 60km/h. Diameter difference 3.6cm, radius 11.5cm difference. Maybe on direct TPMS it is possible to have different pressures, but on the simple one probably not. Msybe between axles, but on the same one, it is hard to beleive. My new tire is now 1.5cm in diameter bigger, error come and go, but esp does not intervene.
Old thread. But let me solve your issue. You have replaced old tyre with new one. There is difference in circumference, so system thinks other tires are deflated. How old is your tire on other side of axle, what is threat depth and depth on the new one? I get this warning due to same reason. Old one is 7.2mm, new one 8.6mm, but I hope it will decrease fast, the first protective layer at least.
Superb 280 mpg realistic
Not possible that much. Mine is at 29. Maybe others are lower.
