Everything posted by UndertheRadar
Extended crank when cold 2.0tsi GPF
Adding this for anyone that comes across the same issue. Noticed a slightly extended crank a day or so ago, along with a few seconds worth of poor idle and then ran as normal. Checked for codes, and none showing. Checked plugs when I got home again and all ok. Checked the lpfp count and was at or around 50% at idle. No hesitation or misfires and none detected on scanner. Rail holding pressure within parameters and both lpfp and hpfp showing requested and actual pressures where they should be. Checked the plugs again this morning on a cold engine for damp, and they were dry and showing no signs for concern. And now for the culprit. On a stone cold engine, the engine coolant temp sensor was showing 80c while the radiator outlet sensor showed about 1c within ambient air temp. A new coolant temp sensor now fitted and all showing back within normal tolerance levels and no more extended crank issue. Just thought this might be useful for anyone with the same problem now or in future and hopefully it saves them time and money.
- Error code help required, please
- 2.0l TSI engines: what should I be looking out for AWD vehicles approaching 100k?
Check the expansion tank for Mit Silikat on the top. If it’s on it then it has a bag in the tank. They were prone to failing and blocking the system, taking the matrix with them. There is an official VAG flush but the matrix is normally in need of replacement when this happens. I and others here have removed the tank and replaced it with a silikat free tank, and some without the double skinned inner chamber have been lucky enough to remove the bag with long nose pliers or something similar.
- Tyres and grip
Air Care won't activate
In the interests of science, I tested this today while changing my carbon activated filter. Air Care will activate and set with no filter present in the car at all. It also runs with a standard pollen filter, as I have one that was supplied incorrectly and I was told to keep it while they sent out the correct filter that was ordered. I’d say a fault is likely due to whatever mixer flap they use to isolate the system through the pollen filter while the setting is activated. Never had to look into it, so that’s just a best guess scenario.
ODB eleven
- ODB eleven
There’s one on you tube for the VC as well. Think it’s on a seat version, but basically the same sequence to reset the service interval without using the obd11 app.- ODB eleven
It’s the VAG version. I have a pro lifetime account and it’s running on an iPhone.- ODB eleven
- Superb 280 stage 2 remap done
Pull those plugs out after a couple of thousand miles and check to make sure they are not covered in carbon. Seems to be an issue with some tunes as the step colder is not really needed over the OEM plug. I’m sure the car feels completely different now. Mine did. Makes them such a useful daily tool, and a much more pleasant experience for safe overtaking and general driving.- The 280PS Thread
Merc, possibly a CLK maybe?- The 280PS Thread
I always have with turbo charged engines and always will. The fast idle is perfect timing from start to allow time to spool up before driving. I then always spool back down again for about the same time before turning the engine off again. I also have a pedal box in mine and have done from basically new. Transforms the response of the car. Removes the lag which I found made the car feel gutless when trying to merge into traffic or negotiate junctions etc.- The 280PS Thread
Mines set for 97 Ron fuel.- Leaking boot skoda superb Mk3 estate
Pop the quarter panel trim off on both sides and check the quarters while hosing the tail light. I would suspect the passenger side rear tail light is leaking. I’ve had to silicone the entire light back in to fix leaks. New gaskets made no difference. Will just make changing a bulb eventually a bit of a chore but at least tue car will be dry in the meantime- 2023 280ps L&K replaced 2016 220ps Style
- Servicing
Every 2yrs- Servicing
Make sure whoever does the haldex takes the pump out and cleans the gauze and doesn’t just change the oil.- Servicing
First thing is if he is a specialist, what belt is he replacing on a 2.0tsi? The Haldex should have been done by now, and I would change the dsg oil and filter if it was my own car. I do mine haldex 2yrs and dsg 4 regardless of the low mileage. The rest seems fine. I’d be checking my air filter before 6yrs as well.- High Beam Light Assist
Above 30 and out of street lighting the high beam is supposed to stay on even with oncoming traffic. It adjusts the position of the beam so as to light the road ahead with maximum effect, but while controlling the position of the focus away from the oncoming vehicle. You should see the light drop along with the oncoming vehicle, and then raise again once it has passed. I find mine to be of great value during the dark winter months, and it works flawlessly.- Strange Steering
Sometimes worn or loose drop links can cause a bit of sway as well.- Strange Steering
Bushes maybe causing slight wander ?- Front passenger door deadlocked
Sometimes if you thump (carefully) the door handle on the outside of the vehicle at the same time as you unlock the vehicle, it can be enough to free the lock and allow you to open the door and gain access to replace the lock.- advice needed on gearbox
Is it when cold or warm or both? Does it still not change smoothly when the box is in sport mode? What service history do you have with the vehicle? What year and mileage does it have on it now? May be in need of a service/oil change rather than an issue with the box. - ODB eleven
