Everything posted by HappySam
Mk3 Rear seats folding
Mine lays flat when opened. Looks like it might be catching on the seat belt buckle to me.
Carlinkit - AA \ Carplay Wireless dongle
This is the one I bought after the last time you posted it. Best £20 I could have spent. It works flawlessly other than it occasionally forgets to connect but manually connecting bluetooth normally jumps it back into life again.
Air vent part number
There's a couple of sites where you can look up part numbers; Octavia Parts Catalog - 7zap Octavia Parts Catalog - LLLParts Links probably go to the 2019 model year so you might need to go up a level first.
VRS front diff question
They are reasonably rare compared to the DSG boxes but they do exist (several on auto trader at the moment). I personally don’t see the point of a manual Octavia though… if a more connected driving experience is what you’re after, buy a GTI? I was simply pointing out that the manual also has a VAQ diff. No-one buys any Octavia for "a more connected driving experience".
Battery symbol on infotainment system
Next to signal strength? Its the phone battery charge.
It also comes in a manual with the VAQ diff.
Rear wiper parks in the centre of the screen
Yes. That's what I said - or at least what I meant. It takes another activation (or 2 or more) to get it to park itself in the correct place.
They're a bit **** aren't they. I had mine replaced a little over 2½ years ago under warranty. The new one is now occasionally stopping mid sweep. I didn't renew the service package / warranty as I was thinking of selling so I just avoid using the rear wiper. I might take it out as some point and see if I can clean it up as suggested in the thread below
Looking for a definitive answer about the VAG part number for my rear nearside light fitting
I'm not sure how definitive these part catalogues are (I can't find my fully LED rear light for example) but that's not a part number listed here or here. You're probably going to have to take the old light out again and double check.
Parcel shelf Scout vs normal
Best thing to do is look on something like 7zap or LLL parts for the part numbers https://skoda.7zap.com/en/cz/octavia/oct/ https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT
vRS 225/40 18 or 235/40 18?
My Assy 6s did an excellent job of protecting my wheels from an errant kerb yesterday. Was expecting the worst but there's just a black rubber mark on the rim.
Rear wiper 'pausing' mid sweep
I also had mine replaced at just over 3 years old under the approved used warranty. Annoyingly, I decided not to renew the warranty when it ran out earlier this year and its just started happening again. At the moment its only if I turn it off mid-sweep but I'm sure it'll get worse. I need to take a look at it before it gets any worse.
SD card 2 problem
You still haven't given an example of exactly what the problem is 🤷♂️ ETA; a pic of the windows folder in Details view (so it shows the track number) and infotainment screen showing the problem would help.
SD card 2 problem
For example? Looking at the screenshot you've posted above you have both the band name and album name as the folder name. This is not how you'd ordinarily do it. Under Music (on Windows), you'd have a band subfolder, then in that subfolders you'd have one subfolder for each album. E.g.: Music | +-> The Who | +-> Live in Amsterdam | +-> Woodstock 1969 | +-> The Rolling Stones | +-> Sticky Fingers etc...
Hole at threshold
Not quite picturing where it is but could it not be the drain holes for the scuttle?
Hello
Hello. Welcome to the fold 👋
Jacking Points on my Octavia VRS 230? Newbie help please
The jacking points are on the seal seam directly below the arrows. You can see where they're reinforced so probably have a few cm either way. You need a slotted jacking puck to go on top of the jack. Something like these: https://www.ebay.co.uk/itm/273453837723
Software Update
Navigation to the station list and click the refresh button top right.
Spare wheel
Mine fits directly into the wheel well. There's then a foam insert that contains the jack etc. https://www.theskodashop.co.uk/products/copy-of-spare-wheel-kit-octavia-iii-vrs
Cruise Control doesn't work. Computer shows 0 error codes.
I had a similar issue when I first got my Octavia. When turning on cruise I would sometimes get the orange light. Eventually figured out that it was the switch on the stalk. If I flicked it quickly cruise engaged, if I flicked it slowly, it didn't. Took it to the dealer expecting a new stalk. They tried the same thing on another car (never even bothered checking for codes) and got exactly the same result so it became a case of "they all do that sir". So, one of two things; flick the switch faster or possibly replace the stalk.
It might help if you explained how it doesn't work. What happens when you flick the switch? Does the odometer display flip over to cruise? Does the Cruise Control light light? What colour is it? Do you get any error messages in the display? Stealers 🙄 What do you suggest they do? Randomly prod things and charge the OP for their time?
Steering Subframe bolts
They'll be in here somewhere: https://skoda.7zap.com/en/cz/octavia/oct/
Octavia mk3 change rear brakes - Do I need new bolts?
Ah, yes. I misread the lines. Reused the mounting bolts.
When I did mine new bolts were supplied with the pads.
Octavia mk3 vrs indicator brightness
LED bulbs are generally not dimmable unless specifically designed to be. Can't see why car bulbs would be. You need to buy lower lumen bulbs.
