Lutz_91
Everything posted by Lutz_91
  1. Yes, it is not coding. It works automatically, it turns on the turn signal when opening/closing, everything is controlled by the light. You don't need to code that.
  2. What do you mean exactly? You have to code the indicators and possibly the reversing light, i.e. change the dimming value to 127.
  3. It's already great. I'm concerned about the running light when opening/closing. In your video, it only works when you open it. The taillights slowly dim - that's the way it should be. When closing, however, it should be the other way around. It doesn't do that to you, the taillights just go out. I have exactly the same thing.
  4. Has anyone found anything here for the purpose of light animation? Unfortunately, the colleagues from CZ only want to do something for €€ and don't tell anything. I think the BCM would have to be faked. Is there anyone who had theirs converted in CZ and has a before/after scan of the car? So far, it's only possible for me to open it, which dims the lights. Thanks
  5. Which version of the BCm would I need? At the moment I have installed 5Q0937084CG.
  6. Does anyone else here have any new insights into animation? I wrote to the company from CZ but of course they don't give out any information. Costs 200€ and only there. Doing it yourself is not. I still suspect it is due to the BCM. Has anyone already flashed it?
  7. Coding of the start-stop function is no longer possible from MY 20. Regardless of whether you use the app or manually. It's only possible by module.
  8. Use a plastic wedge to carefully pry out the key unit. Pull out carefully upwards. The cable is relatively short and everything is a bit fiddly. For my start-stop module, I cut a plastic bar inside so that there is more space under the switch unit.
  9. So front and rear conversion are nothing new anymore. It's all older. If you have the right STG and adapt the cabling, this can also be done at the front. Of course, a few more parts are then required, which makes them significantly more expensive. Whether the animation then runs 100% at the front and rear is also questionable.
  10. Okay, so it's the same as mine. So far only works when opening the animation.
  11. Is the light animation functional? So that is dimmed when opening and closing!
  12. Yes, everyone has to decide for themselves what it is worth to them. I converted to facelift lights myself, so I know the effort and the costs. I also retrofitted the chrome strips on my L&K. These China adhesive strips are good, but look like they were stuck on the door. OEM this is let into the bar so that the edge is flush with the chrome bar. I like it better. In the end, it's always a question of money. And for others, it's nice to see that things are also different from OEMs.
  13. OEM is expensive, right, but looks better. And the facelift lights are 100% LED and not, as with the vFL, with incandescent lamps. Dynamic blinker is also nicer. But everyone has to know it himself. I prefer the FL OEM look.
  14. From Index B flashing to C or E is no Problem with ODIS E.
  15. Fake Chrom Heck 😅 ... Original from the Facelift is better.
  16. Is there any animation news here? Has anyone ever flashed the BCM? For me it is only possible to open it so far, otherwise all functions are fully available. The dynamic indicator also works correctly. Only the animation when locking is not available and the light simply goes out.
  17. So with the Octavia it fits and since the plastic lining is the same on the Superb, it should also fit there. If necessary, adjust the cutout with a file. In your picture, you want to mount the button in the sheet metal, that can't work either.
  18. Ja, geht durch den Kunststoff durch.
  19. The picture with the number 22 does not belong to the EasyOpen, even if it is shown there. As you found out, the part is unusable. The part is just painted wrong. Take a look at the repair manual, they only say that the lines are glued in. There is no question of a holder. There just isn't any !!! Of course you can search if you want. But it won't lead to anything. Counter: 4G0959831B Plug: 8K0973754A
  20. For me it was the case that one line had the clips and the other line had double-sided 3M adhesive tape. There is no need for a bracket. Both lines are laid parallel to each other and glued. As in my picture, I ordered the line and installed it. Without additional brackets.
  21. What are you looking for exactly? The part number for the sensor (encoder cable) is 3V0962239 this line is glued directly in the diffuser.
  22. I upgraded EasyOpen from Kufatec. Everything was there and well described. Unfortunately the whole set is a bit expensive.
  23. So far, the animation only works when I open the car. When locking, the light just goes out. The blinker is dynamic while driving and also acts as a hazard warning light. So for now a partial success.
