Forty45
Finding my way
Everything posted by Forty45
  1. If you want to remove the white inside A trim, then just prise it away gently so you can get your fingers under it and then pull firmly. It's clipped in place, but unlikely to break unless you go stupid with it.
  2. Having the light in the "on" position helps when pushing the metal clip in to release it from the socket.
  3. The AliExpress one I've linked to above arrived within a week from China. I fitted it today and now have sat nav again.😀 A couple of issues encountered; 1 - the leads were shorter than on the original one. To overcome this I had to free the cables from the 2 clips holding them to the body. This was straightforward with the one behind the plastic internal trim panel on the passenger side of the car by the tailgate (you have to remove it to get between the headlining and roof). The other cable clip is on the roof and not easy to pull out. You have to grasp the cables either side of the clip and push the cables away from the roof to get it released, taking care to not damage the headlining. 2 - the cables (4 - only needed 3 as GSM not installed on my car) only have 1 cable which has a connector matching the colour of the car's connectors. Not a big issue as the cables are labelled with what they are for. So for £24 - half the cost of a used one on eBay (which because of their age is likely to be well on it's way to failing) - I've got a new one, which from a dealer would be around £200!
  4. https://a.aliexpress.com/_EwzRfSI Has anyone bought one of these? I need to do something about ours - the sat nav has been telling me I'm in the sea for a long time, and having just removed the unit from the car and taken it apart there is corrosion on the circuit boards. I've been using a TomTom, so getting the sat nav back isn't a major issue, but when I undid the 6 screws holding the underside plate to the upper plastic I found 3 of them were no longer doing anything as the screw hole turrets had broken off. I doubt it won't will be long before it all falls apart and there will be water ingress etc.
  5. I want to fit mesh in the lower grille as is shown in this post I asked one of the posters who'd done it how he got the grille off and got this; 'I'll try to help, but my recollection of what I did is all a bit hazy, its a while ago, and I no longer have my Yeti to look at and check (only sold it three months ago, as it happens). As far as the barbs go, I reckon that I would have used a thin flat bladed screwdriver to press the barbed section of the clip down, to allow it to slip backwards through the hole. I'm fairly sure I would have done this one at a time, working from one end. Anything further than that, I'm sorry, but I doubt I will be able to help." Which was no help really. When it is warmer I'm going to take the wheelarch liners off and see if I can dismantle from behind the bumper. I suspect the car needs to be on front jacks or ramps to get enough access, or the whole front end needs to be removed 🤷
  6. I tried again recently but didn't manage it. I have concluded the bottom doesn't come off until the top is removed with it. There is no way the bottom prises off - there are just too many overlapping clips there to keep released at the same time. I managed to get the push pins out, but that didn't make a huge difference to how clipped together the assembly felt.
  7. Thread revival time. Did you manage to remove the lower bumper, and if so can you explain how please?
  8. https://www.yetiownersclub.co.uk/threads/amundsen-infotainment-repair.14382/post-177911 There is a list of repairers in this post at #31.
  9. Surely if the armrest came forward more it would prevent getting hold of the handbrake? I find with it fully pushed back the padding still contacts my wrist/forearm when using the handbrake. I think it should have been made to be higher.
  10. The kits (or individual pieces ) are no longer available. Not been made for many years.
  11. I've checked it and everything is tight and no play. I'll just see how it goes and if it gets worse investigate further. Leaving the a/c on isn't a problem in this weather 🌞
  12. Thanks for the suggestion. The noise is on the driver's side and sounds to be coming from the pedal box area or where the fuse box is - and I've checked in that.
  13. Cheers. Mine is on 40k. The noise is like a slowish tapping of a bolt on a hollow panel on the underside of the car - as if the exhaust was knocking something. As soon as you move off it goes until you stop when it returns. It also takes a little while to start up when the engine is cold. So it doesn't sound like what you have, but once I'm able to get to the pulley area I'll report further. Is yours a PXE14 with the same part number as mine?
  14. Would I need the belt off when doing that?
  15. Thanks for confirming what I thought might be the case.
  16. I haven't, but just took this and they don't look loose.
  17. The rattle (sounds like piece of metal tapping against the car underbody) is on a 2012 Yeti 1.2. The noise starts when the air con is turned off and engine is idling. The aircon has been recharged recently and works fine otherwise The compressor is a Sanden PXE14 (part 5N0820803G). When I searched for I found the data sheet identifying different Sanden compressors, and the diagram of PXE14 refers to "no clutch" on the pulley. I've read posts where the compressor clutch pulley has been identified as the source of a rattle and either a new clutch hub or complete clutch pulley has cured it. However these aren't for the "G" model compressor. The clutch hub or complete clutch pulley for my model is not listed on eBay or Amazon etc - it's here, https://shop.acauto.pl/product-eng-49488-Clutch-Hubs-AC-5SD02-CH.html https://shop.acauto.pl/product-eng-49654-Clutch-kit-AC-6SD10-CH.html and more expensive than what other people have paid for the parts for their repair. I don't want to buy a part if it might not be the cause of the noise - any views please? If the pulley is "no clutch", can it have a rattling clutch? Also, does anyone know how to remove this pulley? I've watched a YouTube of one being stripped on a bench, but the nuts and bolts had already been undone and it was in German. The part number can be found with many different letters at the end, but some letters are much less common despite the pulleys looking very similar. Can the pulley be held in place with a Boa strap wrench while undoing the nut? Is a flywheel puller needed? OEM_Data_Sheets_Combined-1 (1).pdf
  18. Yes, I have this now and it has happened before, but mine is the Amundsen+. I don't know what causes it, but I think it could be due to the quality of the map software used not being very good. My map is V12.
  19. Forty45 replied to DensYeti's topic in Skoda Yeti
    That doesn't sound good. The flexi looks a pain to move. You may have to remove to tailgate plastic and/or the roof lining to get to the wires. Good luck.
  20. Forty45 replied to DensYeti's topic in Skoda Yeti
    Interesting you say that. Electrics isn't something I know much about, but some of the car diagnostic guys on you tube make it look so easy.
  21. Forty45 replied to DensYeti's topic in Skoda Yeti
    My car doesn't have the removable lamp. I concluded the boot latch had failed (not from any sound diagnosis as I couldn't get consistent readings) and replaced it. After I ordered it (AliExpress) I noticed the light would come on some times, that seemed due to the lamp connector not making the best connection, so that could have been the cause all along. Anyway, new latch and it all works again. I replaced the lamp with a 6 LED unit which makes a huge difference. Getting the plastic off to replace the latch is a real challenge though. Had to get the special VW plastic wedge to assist doing that.
  22. https://youtu.be/y5PuC9TeHfA Sorry if I've misinformed, or maybe I'm remembering the wrong end! Anyway, here is a video of how to do it.
  23. Rear interior lamps are removed by prising from the bonnet end. Use a plastic tool and don't dig too deep into it. Keep trying until you find it lifting out
  24. Front https://www.ebay.co.uk/itm/T10-Led-501-Side-Light-White-Bulbs-Car-Error-Free-Canbus-Xenon-W5w-Sidelight-UK/174629442013?var=473832270982&pageci=db9fd295-b655-43bd-bf98-d524a1e23047&redirect=mobile Rear (36mm) https://www.ebay.co.uk/itm/Car-Festoon-White-LED-COB-SMD-Light-Bulbs-Lamps-Interior-C5W-Bulb-12v-31-41mm/185038601127?var=692814964095&pageci=9451d274-dbfb-4242-a482-ceec39d2d29c&redirect=mobile Glove is as Rear, but 31mm. For the boot, this is way brighter https://www.aliexpress.com/item/1005001883251655.html?spm=a2g0s.9042311.0.0.74ef4c4dze5Z3Z you do need to file/shave a little plastic off the trim opening to fit. I've used these on a 2012 fine.
  25. Forty45 replied to DensYeti's topic in Skoda Yeti
    I also have a non working boot light. I've read this and the post on Briskoda and carried out some tests. 1- removed the bulb light and checked it lit. 2- confirmed the glove box light illuminates. 3 - found there is almost 12v on the red/blue wire side of the bulb holder and nearly 0v on the other (brown/blue) side. This is not by probing the wire into the socket, but touching the metal in the bulb holder. I assume this confirms the diode is OK. 4 - the Maxidot does not show the tailgate as "open". I attached a wire to the brown/blue side of the holder and grounded it. This caused the Maxidot to show the tailgate as "open" regardless of it being open or shut. Am I correct in thinking the results above point to the tailgate lock being open circuit (possibly due to a microswitch failing)?
