Everything posted by Crucian
1.4 tsi cthe charger belt tensioner?
2014 1.4 TSI RS CTHE Hi, The smaller drive belt (17.65x492mm) for the charger does it have a separate tensioner ? Also I can't see an easy way to change the auxiliary drive belt as the tensioner does not remove sufficient tension (when in the pinned position) I'm looking to renew both drive belts can't seem to track down an appropriate exploded parts diagram showing the specifics
North East Garage Recommendations
HR Automotive, Meadowfield
I'm in that area and have used Pulman Skoda Durham but as its dealer its pricey, I'm looking for a good independent as well so will watch this with interest. I have an excellent independent for regular maint. items, services brakes, suspension etc
Cylinder numbering ? 2014 1.4 TSI
Yes Iridium ð
This thread was prompted by a mis fire and what sounded like terminal engine failure, turns out it was a plug and / or coil on No. 1 cyl (only renewed 4 months ago by Skoda dealership) Anyway not confident with the VAG plugs that were in have now replaced with Bosch plugs (96335) and new Delphi coils throughout, all seems good now Anyone have positive experiences with plugs for the 1.4 TSI 180 ?
@Breezy_Pete Cheers
vrs 2014 1.4 TSI 180 I can't seem to find the cylinder layout for my engine is cyl 1 drivers or pass side ?
Your experiences with refurbishing brake calipers (specifically the paint)
Update, Finally got my calipers refurbished to my requirements, Just a final application of C5 wheels armour required prior to fitting. I've probably got 50 hours in these and Circa ÂĢ200 in components Still have caliper mounting bolts to source then repeat for the ones I remove
Update, Managed to dismantle the rear caliper where the piston wasn't unscrewing to find serious rust corrosion, both rears scrapped I spent 11 hours starting to prep front calipers and all carriers, then gave up (probably another 11 hours required) and I'm sending out for refurb and repaint photos to follow
Front calipers seem fine, (rears I'm ordering some refurbished ones as I think it will cost more to salvage the existing ones) Starting to clean and strip / sand blast, will probably opt for Foliatec professional 2 pack red lacquer
@StoreyR will do
Hmm, On initial strip for cleaning one of the rear calipers does not extend with either the lever or rotating it and the one I have stripped shows pitting and scoring on the bore. Is it worth proceeding to refurbish these ?
Hello, I have a spare set of Fabia mk2 vrs calipers and am going to refurbish them, the mechanicals are straightforward and no challenge but I want the paint finish to be as good as possible and long lasting, I know I could send them away to get fully refurbished but don't have ÂĢ500 knocking around spare. Preference would be a two pack epoxy but can't source G2 over here 9USA) and unable to find a UK alternative, plenty of foliatech and E-Tech etc about but wonder about their longevity, realise that its all about the prep and not afraid to do the work (have access to full garage equipment and sand blaster) Any personal experiences / recommendations welcomed ð
Brake bleeders ??
thanks @sepulchrave
- Brake bleeders ??
Brake bleeders ??
There are 2 different bleed nipples shown for my 2014 1.4 vrs anyone know which is the one I require (I'll be taking a wheel off next week" but some knowledgeable soul may already have the answer
First Skoda, Mk2 Scout bought with some issues
hello and welcome
Fabia 2014 dsg vrs, Any issues with re-setting adaption settings
@Mickmartin I have access to VCDS and seen the option as I progress through the settings
As title I feel as if these (various previous owner settings) need resetting to re learn adaptions based on my driving styles, are there any watch outs ?
2014 1.4 dsg vrs gear lever knob and gaiter swap ??
Before I proceed to renew my worn knob and gaiter I'm researching how to remove the existing knob and gaiter, I know how the gaiter un clips around the base what I'm finding difficulty in determining is how the actual knob and chrome lever are removed, Haynes manual is just generic poo on the subject. Anyone have experience or knowledge how to remove it. As ever any assistance welcomed ð
How do I increase the idle speed on 2014 1.4 VRS ?
To draw this to a close. Double checked this with vcds and its correct (850 / 900 rpm)
Checked and increases to 800 rpm in D with foot on brake Being worrisome on my part I think
@toot I'll re-check shortly
Thanks people as always ð
Looking at this again it idles at 650 RPM as @edbostan states @toot Thanks, in drive remains at 650, S increases correctly to 1000 RPM I may be being a bit OTT ðĪŠ
