Crucian
Everything posted by Crucian
  1. cheers @roottoot 85,000 miles Services and service inspection up to date yes spark plugs been done (by dealer in my ownership) this is why I want to keep an eye on the service history
  2. I just want to ensure the work is correctly recorded, all servicing up to date as far as I know ???
  3. @roottoot Thanks I'll check the spare wheel well, I believe I have a full print out from the dealers but I still want to see it / keep updated, I'm looking for a Skoda indi in my area (co Durham)
  4. It's the dealership info I'd like to access, I currently have a print out but would like to keep an eye on it
  5. Is it possible for me to view my Skoda service record as stamps in your book are a thing of the past ?
  6. You may find that they will not fit customer supplied parts
  7. Still a lot better than the average 14 mpg from the RR V8
  8. Another how to question, how do I secure the door loom bellows into the door, the two clips at the top don't seem to grip the sides of the aperture ??
  9. Addendum to this, if you change or disconnect you window switches they will need to send a re-learn signal to the BCM, hold the switch in the down position for 1/2 second after the window is fully open and again when it has fully closed
  10. Push the top of it down and ease it off
  11. Following on from this, how easy is it to add a rear parking camera to my Amundsen retro fit ?
  12. @Breezy_Pete I can many thanks (that's a resource I will utilise in future) Job now completed, I was too reluctant to apply the correct amount of force 😕
  13. As the title I can't seem to get the a post inside trim off (to run a couple of wires) does it pull out of clips (it seems to be held very tight), what is the correct method, looked at the haynes manual, searched these forums nothing apparent. Stuck !!!!
  14. Engine is 1.4 TSI
  15. But I do seem to get over 50 smiles per gallon
  16. I can't seem to get the AVG MPG above 35 MPG
  17. thanks
  18. @thomasaspin thanks
  19. Thank you Hmm are they easy to replace ??
  20. 2014 Fabia hatch, Looking around it today it appears my Pass window switch isn't working, common Issue ?
  21. Crucian replied to Crucian's topic in Hellos and Goodbyes
    Thanks I'll try that
  22. Crucian replied to Crucian's topic in Hellos and Goodbyes
    Sorry a MK2 (2014) Thanks for the responses people, am I not posting in the correct forum ??
  23. Crucian posted a topic in Hellos and Goodbyes
    Hello, Taking ownership of a mk3 fabia Tomorrow, looking forward to finding my way around it. Doubtless I'll have loads of questions (I'll use the search function before posting)
