Posts
603 -
Joined
Last visited
Days Won
5
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by Winston_Woof
will be all sorted once they move production to China ;o)
Just come back from dropping it off at the dealers over in The Wirral I bought her from end of Feb. They're going to sort it tomorrow. In the meantime I have an Audi A3, don't like it lol
Are there any wireless adaptors that don’t require a wired connection to plug into?
Tried clearing but won’t go away
Car spat a wobbly on way to work today. Spat an ACC error then an EPC light. runs but seems down on power. quick scan has the following highlights P0222 [0x0222] Throttle position (TP) sensor B/accelerator pedal position (APP) sensor B - low input APP Sensor 2 Circuit Low Voltage ——————— 01. Engine control unit01. Engine control unit DTCs: 1 ---------------------------- 02674 [0x000A72] P022200: Throttle/Pedal Position Sensor/Switch B Low Input Status bits: 1 Priority: 2 Frequency: 1 Unlearning index: 255 Odometer: 203670 km Date, time: 2024.05.07 11:35:32 Engine RPM: 0 rpm Calculated engine load value: 0.00 % Vehicle speed: 0 km/h Engine coolant temperature: 93 ℃ Engine oil temperature: 55 ℃ Barometric pressure: 102 kPa Klemme 30 voltage: 11 Paramteric values: 20 96 28 F4 46 41 F4 0B 66 10 10 00 00 14 B4 19 C8 11 99 10 00 17 46 00 00 43 21 00 Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear, Warning indicator requested ————————————- 22276 [0x005704] U112300: Databus error value received KFC_MOTOR_11 Botschaft - SNA-Check Status bits: 1 Priority: 6 Frequency: 255 Unlearning index: 194 Odometer: 203670 km Date, time: 2024.05.07 11:36:07 Paramteric values: 20 2F 79 57 00 04 7F 72 78 00 00 02 F8 01 DB 00 00 00 Status: Test failed, Confirmed ——————————— 02068 [0x000814] U112300: Databus error value received FAULT_TSK_IRREV_FAIL Status bits: 1 Priority: 6 Frequency: 1 Unlearning index: 194 Odometer: 203670 km Date, time: 2024.05.07 11:35:43 Paramteric values: 02 8D 61 02 85 75 10 11 00 00 10 12 00 00 10 2E 07 Status: Test failed, Confirmed
Does the "P" in "PHEV" stand for "Pointless" ;o)
Door pillar black stickers - I think they look ok
Winston_Woof replied to Prezafab's topic in Skoda Yeti
Its odd they left the factory with the A & C Pillars and rear blacked out to give the illusion of a floating roof but left the B pillars body coloured which then destroys the illusion. -
curious. It has RFID which is shortrange so must have had a fob or a phone app ah here we go https://www.transportengineer.org.uk/transport-engineer-news/masternaut-releases-telematics-hub-for-improved-connectivity/62552 Its a GPS tracker Edit , that looks to be just one part of it, you may have some other bits hidden away https://www.ebay.co.uk/itm/266376374775
Size was never a problem back when I smoked rollies lol
Fuglier than a fugly thing in a place full of fugly things
But if a long watch but really intersting. Toyotas hydrogen approach
It’s just fugly
I use one of these https://www.amazon.co.uk/dp/B0CD1GP7TV?th=1 Does what it says on the lid
when you find it take a piccy cos they do seem to be lacking ;o)
it's a pity smoking isn't so fashionable these days. Used to have a collection of tins like this that would be suitable
I'ld be surprised if it wasnt in the same place (or very close).
in reality how big is the "risk"? Yes we all know that there are various relay techniques available but equally there are techniques to get you in without need ing remote access to the key fob. I would say personally that for the majority of people with an average car then the biggest risk is a scrote with a brick or broken spark plug cap. Faraday pouch ain't going to help there (and yes I am of the opinion a lot of these things are marketing hype preying on irrational fears)
Retrofit phone cooling whilst using Android Auto
Winston_Woof replied to jensbakker's topic in Skoda Fabia Mk III (2014-2021)
I just have a phone holder mounted on the cooling vent so it gets "some" coolish air (yes Im aware that if i turn the heating up that will warm it but as I typically leave the temp set at 18c all year around then meh -
https://www.youtube.com/watch?v=BxXDrwnGVJM
Is this navigation symbol normal?...
Winston_Woof replied to JFrankMiller's topic in Skoda Fabia Mk IV (2021 > )
I didn't think Waze (or other IOS/Android nav apps) output to the screen shown, was under the impression that was the built in **** nav only -
idle curiosity here. How difficult a process is it to import cars from the UK mainland onto the IOM?
This is also true
I've no idea if that works on my Superb 1.4TSi as I dont have the Eco|Normal|Sport selector option ;o)
