Everything posted by defsix
It's installed under the switch, like an extra to the existing loom. It's not very intuitive, you have to tuck it towards the back so the plug is already in position to receive the switch/socket. Otherwise it bunches up. Get the swit4as close as possible before plugging it in.
No, it's a fairly neutral smell. I did it with the windows open to stop the vapor lingering and sticking to unwanted surfaces.
Following onnfrom yesterdays mission... I also had a stuck flap in the HVAC system, it would show a fault in VCDS and make an awful creaking sound when the car would start or when I adjustment the air flow. I turned everything off and sprayed a generous about of SP90 silicone spray down every vent in the car, let it settle, then in turn activated each blower position. I can no confirm, fault.has cleared and no more squeaky vents! I also received my Start/Stop disable cable , fitted this. A bit fiddly to tuck the excess cable away, but done now. Works as expected! AliExpress Start/Stop Disable Cable
Well after nearly 4 months of ownership, O finally found the source of one of the most annoying rattles. It sound a little plastic bag of nuts and bolts sliding along under the carpet behind the drivers seat. I have pulled bench seat, the bolster, the boot carpet ( estate ) rear driver footwell, lower trim the runs from the front to the back. After all my efforts, it was a broken biro on the rear floor air vents ! Even after checking them with an endoscope, I still missed it.tje first time. After 2½ hours over the past 2 days , I eventually removed it. Using my endoscope with a hook, long clear tube connected to my vacuum cleaner! What an ordeal.
280 Front strut components ??
Hi, just a quick question, the C Shape clamps that hold the anti roll bar, are they available as spare parts in there own?
Coasting & ECO Mode
I noticed sometimes the Coasting won't activate when in ECO, when the car is doing a DPF regen. I'm still debating about enabling it via VCDS in Normal D mode.
Wow! I appreciate the advice from everyone! I never thought of the metal reaction. Lesson learned before it's too late 🤯
So I got a bit carried away... Air Valve Caps Fill Cap / Funnel Start Stop Bypass Cable Luggage LED's Cigarette Lighter Upgrade
Merci!
Got a link?
I this scenario I believe they will draw the same current, but will out more light, plus driving the cooling fan. OP should be safe enough
Cylinder 3 pressure glow plug
Same Cylinder I assume. Did you check the wiring loom ?
Whilst I agree with the statement above, is "Gandalf" not originally fitted with D3S HID Lamps ? If it has a Ballast / Driver then it is either LED or HID. I'm assuming this is an upgrade from HID to LED, without bypassing the driver. LED generaly runs at 150% to 200% brighter per watt compared to HID.
The Superb III Picture thread
Coasting & ECO Mode
Seems to be a heated topic ! Pros and cons to this coasting feature! I've had second thoughts about adding coasting to the Normal profile, I'll keep it jist for Eco. But this brings up my next question. How do you get the car to remember which driving profile you used the last time, and to return to this when you restart the car!
Coasting & ECO Mode
The plot thickens! I'm debating whether to add it or not via VCDS. I believe it's an option somewhere. For my daily journey, up 3 gradual hills and down 3 gradual hills I do like it , if I can calculate the optimal speed to crest the top of the hill, the longest I can coast is over 3Km If I remember correctly. This is over a 30km journey one way. I'm definitely coasting for 25% of the journey. What causes problems is other road users either going too slow or speeding up and slowing down all the time. My lowest consumption on a daily journey was 57.65MPG or 4.9L/100KM. What are others thoughts on this? Do many of you use the coasting? Would you like it on the Normal profile too, not just the Eco?
Coasting & ECO Mode
Interesting, in mine in ECO mode I can have ACC activated , but the car won't coast. Unless I tap the stalk back a bit, same as tapping the breaks.
Coasting & ECO Mode
Hi All, In my recently acquired 2019 ,2020 model 190BHP DSG Superb, the only time I can avail of coasting is when I am in ECO mode and when I don't use ACC. Would this be correct ? My colleague that recently sold his 2016 version of the same car swears he could do something similar but in Normal mode also? He is also convinced that he could drive it in coasting mode, but the clutch would be engaged and still powering the car slightly. Can anyone confirm what mine is doing is correct ? And that my colleague was imagining that the clutch was engaged and powering his car whilst coasting ?
I admit I could have done similar, but I wanted the more premium feeling metal key, the original was in poor shape. I'm surprised that they are supplied with one metal and 2 plastic keys.
Not to out do your fine work, but I went down the simple route and purchased 3 spare shell's. YIQIXIN Smart Car Key Shell Case 3 Button Fob Simple enough to swap over the electronics and key. Now I have 3 shiny new metal cases keys. Previously it was one metal and 2 plastic. And the metal one was covered in super glue 😂
Turbo Charger Under boost error 19225 & 25720
Hi, Looking for a bit of guidance with these errors. They do clear on restart, with no issues. Basic OBD2: P0299 (Pending) - Turbocharger/Supercharger "A" Underboost Condition Engine: 19225 - Turbo/Super Charger Underboost 25710 - Turbo/Super Charger Underboost On investigation the Turbo Actuator socket was damaged, believing this, I replaced it and did the adaption. We believe the one we replaced wasn't original, due to the fact the circlips were missing off the end of the sjadt. However went for a spin today and error comes back. It appears to happen on a return journey after the engine has warmed up a second time, usually when I'm about to overtake. But, if I try to replicate I have no luck ever ! Next plan of action was testing the vacuum lines, maybe they're losing pressure. We had a look and they appear okay. Following that, pressure sensor. Any ideas what else to check? 3 different readers come back with the games issues.
IV/GTE suspension
Have you pictures of the finished setup?
Service book replacement?
I find it a handy place to get the VIN number 😁 . But at the moment for me, the app is broken. It logs in, shows me my car, but no details in any screen. Web site works fine.
Did you sell your old HEX-CAN ? I'm in the same boat now, I looked at the price of the new ones and noticed there was a trade in value. A €100 towards a new one as a trade in. The supplier actually said I'd be better off selling it online! I jist sold old HEX-CAN Unlimited VIN cable for nearly €400! That makes it a cheap and easily justified purchase of the HEX-V2!
Virtual Cockpit Screen Scratches
It's ok, mine is not as bad as that. Jist have some marks where a phone has been placed a number of time's. The example picture I used was from a Golf 😉
