ile7
Everything posted by ile7
  1. Since I bought recently Fabia 2019, and have this sensor, what have to be done to make auto lights. New switch and coding or wiring also?
  2. You have that spot in one of the videos, check for solution
  3. Check this https://youtu.be/8GSfty0tcAs?si=SHUshW5cW0wxfqfL
  4. Yes, everything with Hut/BHsens logo should be OEM! Just got refund for my set since it's fake ( maybe working like a charm, but fake ). The seller has BHsens logo module on advertising pictures, in reality you got module like I post previously... Will try to find genuine module
  5. @Cairus do you have pic of module you bought?
  6. Any links? Pic of module?
  7. This set should support 2 sets of wheels right? Need parameter file for superb 3v5 combi if someone can help
  8. Hello, once again dq381 fail! After 12 months since both pressure sensors changed, new fault code is here. Where to start now?
  9. @JR RS thanks buddy! Xenon should make more heat then leds however or leds in this way make more heat cuz they supply via xenon balast? Don't want to burn the car 😁 Consider to get this one
  10. @JR RS hello, does it worth to go with d3s led instead of OEM osram xenon? My bulbs still work but they are from 2018, recently looking for new bulbs but which way to to... Any good brand for d3s led? Can get AMIO led bulbs in local shop but dunno yet 🤣
  11. Post in Octavia section, this one is for mk3 superb
  12. Im pretty sure the hole is same for any type of camera
  13. This one is from factory. Check the video at 1:20
  14. Assume they produce two or more type of tailgate only because of handle switch..
  15. No need to cut anything for sure
  16. Should be fine, I will take pic of main later
  17. I just found this on AliExpress: €19.15 | Stainless Steel Pedal Cover for Volkswagen VW Golf 7 8 GTi MK7 Polo A05 Passat B8 Skoda Kodiaq Rapid Octavia 5E 5F A7 2014-2023 https://a.aliexpress.com/_EycXeak Fits perfect!
  18. Great for retrofit less pain for the reward, thought all highline version came with washer jet like main from factory
  19. Which OEM kit you will get?
  20. I just found this on AliExpress: €21.75 | Car Air Quality Sensor 5QJ907643 For VW PASSAT B8 Golf 8 MK8 Tiguan For Audi Q4 Q5 For Skoda Seat Kodiaq 5Q0907643D 5QJ 907 643 https://a.aliexpress.com/_Ey3JZ1G Works like a charm, OEM part for chinese market
