Skodacrazy
Everything posted by Skodacrazy
  1. had the cambelt & waterpump changed I know its a mechanical thing but any adaptations required to fine tune the fuel injection etc
  2. The Top picture is now with the used injector fitted into the 3rd injector from the Cam belt However the below picture is of the other day while diagnosing the injector Solenoid Ground Fault problem Does this seem correct? Car feels lumpy at 40mph But also feels faster than just before it went into limp mode with Cylinder 3 Ground Fault problem Does it go 1-3-4-2 Does this mean my number 4 injector needs replacing? They removed Two Injectors have they damaged the other?
  3. Is it solved you ask……. Nearly Steering rack flashed Dataset flashed with relevant file ODIS-S offline can do a partial Calibration that switches both Dash lights off and fixes all relevant Fault Codes But still this issue Status of Basic setting - not active ??? No Straight Line Running No absorption of road & wheel vibration Feel at 70mph like the rack needs more power Only thing i can think is this CAYB car has a none original ECU i think from a CAYC with a different VIN number And ODIS uses this VIN to Identify the car The rest of the car modules are Original car Vin Also this ESP rack requires specific engine Torque to tell it when to give more assist while parking and firmer at high speed Ive just had an injector fitted from a Solenoid Ground Fault now the car is faster & steering feels lighter WTF , have the electrical gremlins had a hand in this all this time lol idk At the beginning of this ordeal i had a Vag garage use Odis online to calibrate it better than my effort however they also corrupted the Dataset to adaptations thus pulled to left severely on acceleration Anyone know how they could have achieved this calibration using Odis Online They stated “i set it up as a new column” But ive tried that also and it doesn’t do the same calibration as they achieved Just too add if you identify the car as a higher BHP aka CAYC in ODIS-S it gives a totally different Steering characteristics better & performs like a spaceship like a rough as F**k re-map lol Gotta ask yourself is it worth it over leasing a brand new car with maintenance and no worries
  4. Fault keeps appearing Installed the OEM maf instead of cheap Ebay one Manual Gears feel slicker & generally feels slightly better to drive however it keeps throwing the following codes and the OEM puts it into limp mode with Air intake Fault code -Maf fault code -Air intake leak fault code Hopefully its a hairline crack on some pipe
  5. Had the car undertray off Tightened a few jubilee clips at the drivers front lower engine bay they were quite loose Not sure if these are coolant or air intake pipes Car seems to drive slightly better Hopefully this is the issue Thanks
  6. Thanks for the reply CAYB 2014 On 60k miles? Egr failing ? I thought maybe because it only seems to happen when the weather temp is approx 20 degrees then it might only be some plastic becoming supple or some metal clip expanding thats not directly connected to the engine The cars temp doesn’t seem to make a difference The cheap maf is obviously less sensitive then the OEM that triggers immediately I have some domestic CO2 smoke alarm spray cannisters used for testing smoke alarms If i give it a vacuum test Could i just spray this into the air-intake after the MAF? Engine ON or OFF? Or is there some other Pipe N75? Etc to test from? TIA
  7. Hi Recently getting the flashing coil icon and the P0101 fault code Changed MAF twice for OEM however doesn’t fix and causes the the fault immediately ( cold or warm weather) Using a cheap Ebay MAF the fault only happens when the outside temperature is really warm weather 20* plus Car still drives okay possibly slightly worse in warm weather Anyone had the same problem? TIA
  8. Also The replacement Maf causes the engine to lose power/miss when setting off Cheap Maf doesn’t cause any noticeable issues apart from not as slick through the gears
  9. Currently has a cheap ebay Maf installed and the P010 fault might appear every 500-1000miles Replacement with a Oem maf triggers The P010 fault immediately after installing within a few miles the p2279 has only triggered once during this replacement install It started when the weather started getting warmer Brand new oem N75 recently installed New Airfilter recently installed 50k miles Hoses look decent but could have hairline cracks, Smoke test? Anything else i should look for? I have Live data diagnostic if needed
  10. That’s the problem I’m struggling to find a decent repair mechanic who is proficient in Odis & this problem
  11. Got a little further with this after picking up OBDeleven pro I’m thinking this could be the problem How can this corrupt from changing the complete tie rods???? possibly the garage stole & replaced the steering rack with another, with the way my life seems to be going the pan it wouldn’t surprise me haha feels like an episode of the truman show Can ODIS automatically rectify this online or do i have scroll the web & find the correct firmware flash file from erwin then give to the mechanic with odis Is there anyone in UK who fixes this type of problem regularly? I can’t seem to find any garages local to me apart from the dealers I’m guessing the last garage who used ODIS wasn’t savvy enough to fix this issue thats why the steering was nearly 100% fixed apart from no end stops & veered to left slightly on accelerating
  12. I believe mine is front lower left standing at the bonnet Can just see it through the gap
  13. After i cleared the fault codes from the above scan after ODIS All the faults cleared including ABS apart from steering assist then when I’ve gone to try set steering angle again in -44 using VCDS it immediately brought the dash lights back on Re-flash steering module? Not sure if i need a garage who specialise in fixing accident damaged vehicles what with the none original ECM cluster etc If anyone in blighty can fix this please do get in contact, I can pay a modest amount of shekels
  14. Good & bad news lol Car EPS/ABS was fixed using ODIS Steering was stronger less road vibration through steering wheel, ABS & traction control working, slight veering to left though? Steering Torque? However Driving back the car felt not great checking the autoscan it had faults everywhere nearly every module (as the photo) So I cleared the DTC’s and back to square one dash lights back on Lucky i saved auto-scan before clearing anything, nothing seems different apart from an extra fault code B200500 & WS number
  15. But it drives fine now the power steering works near enough perfect, caster? it was febi lower arms probably not oem quality they were half the price of lemforder Somehow the steering assist setting was corrupt displaying “unknown” instead of comfort/Auto/Dynamic ~ no idea why this happened There was no fault codes or dash lights until i reset the steering assist module in VCDS I’ll try and double check the vin/coding to the module’s if i get the chance however if ODIS can do this easily then i’ve had enough these new 2000’s cars are terrible bring back mk2 golfs
  16. Yeah I’ll probably take it to someone with ODIS to fix Could also be this copy of VCDS not sure if its original @nta16 The vis4vag.com does contain correct procedures, Coding information i just thought it would store a fault code for incorrect vin/long code
  17. original car was steering perfectly, decided to fit new arb bushes & while on the ramp renew tie rods lower arms etc alignment done yes, previous to me resetting the steering angle would move from 0* + & - no fault codes or lights However i reset because when i looked at VCDS the steering assist was set to Unknown instead of auto comfort or dynamic And the steering was still somewhat heavy, after reset the steering assist is set to dynamic however now the steering angle doesnt move from 0* & fault codes / amber lights Thursday,13,March,2025,23:02:56:00009 VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86 VCDS Version: 24.7.0.0 Data version: 20240715 DS356.3 www.Ross-Tech.com VIN: TMBFJ6NH1F4503739 License Plate: 2014 TDI 1.6 Mileage: 87270km-54227mi Repair Order: full autoscan -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: NH-SK25 (6N0) Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56 77 VIN: TMBFJ6NH1F4503739 Mileage: 87270km-54227miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb Part No SW: 03L 906 023 LL HW: 03L 906 023 LK Component: 1,6l R4 CR td H33 9972 Revision: --H33--- Serial number: CVN: 1F642B7C Coding: 00114016002500080000 Shop #: WSC 73430 031 00046 ASAM Dataset: EV_ECM16TDI02103L906023LL 003010 ROD: EV_ECM16TDI02103L906023LK_SK25.rod VCID: 7BF542EBF2E5694E96-802E VINID: 91D4966867980561050031C324EEC2AE61 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 6R0-614-517-TRW460.clb Part No SW: 6R0 614 517 BD HW: 6R0 614 517 BD Component: EBC 460 ESP H08 0004 Serial number: A00HVBC Coding: 4229481489B200BD424712D591A10080480900 Shop #: WSC 73430 031 00051 ASAM Dataset: EV_Brake1ESPAEntryTRW 002011 ROD: EV_Brake1ESPAEntryTRW.rod VCID: 76E353DFC9C73426E9-8022 2 Faults Found: 0360 - Steering angle sensor B1168 54 [10001001] - Missing Calibration / Basic Setting MIL ON - Confirmed - Tested Since Memory Clear 0349 - Steering Angle Sensor B1168 F2 [10001001] - Not Initialized MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 3 Fault Frequency: 1 Reset counter: 59 Mileage: 87269 km Date: 2025.03.13. Time: 10:42:03 DTC: 00 01 5D ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl Part No SW: 5JA 907 044 HW: 5JA 907 044 Component: Climatronic H04 0104 Revision: A1001000 Serial number: 1310232A-0453 VCID: 78FF5DE7CBD34256FB-802C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb Part No SW: 6R0 937 087 P HW: 6R0 937 087 Component: BCM PQ25 H+4 H34 0411 Revision: BF034001 Serial number: 0581 340131030 Coding: 3C980B0000C92400920808306C0B0CC00E80400F608E0000020000004000 Shop #: WSC 73430 790 00051 VCID: 4A9BD72FE5BF00C65D-801E Subsystem 1 - Part No: 5J0 951 172 Component: DWA-Sensor H0 H03 1211 Coding: 000000 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Coding: 000000 Subsystem 3 - Part No: 5J0 951 172 Component: DWA-Sensor H0 H03 1211 Coding: 000000 Subsystem 4 - Part No SW: 5E0 919 719 F HW: 5E0 919 719 F Component: E221__MFL-PR6 H04 0130 Serial number: 000000000A1562111213 Coding: 820000 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:| 5JA-919-475.clb Part No SW: 5JA 919 475 A HW: 5J0 919 475 A Component: PARKHILFE 3K H11 0005 Revision: -------- Serial number: 32931335001844 Coding: 100003 Shop #: WSC 73430 031 00051 ASAM Dataset: EV_EPHVA14SK25X0000 001002 ROD: EV_EPHVA14SK25X0000.rod VCID: 4487F917CF9BD6B6A7-8010 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 34D 959 655 B HW: 34D 959 655 B Component: AirbagVW20 004 0365 Serial number: 003K7R02G5GA Dataset Number: 5JA003t____ 0013 Coding: 88CCC00000000000540000C8008000000065 Shop #: WSC 73430 790 00051 ASAM Dataset: EV_AirbaVW20SMEVW253 001108 ROD: EV_AirbaVW20SMEVW253.rod VCID: 3467A9D79F3B663617-8060 Crash sensor for side airbag: driver side: Subsystem 1 - Part No SW: ----------- HW: 480 410 412 13 Component: SideSensor_Df 003 0148 Serial number: 349650A25E3BFE059CFD Coding: 2D2D2D Front Passenger's Side Airbag Crash Sensor: Subsystem 2 - Part No SW: ----------- HW: 480 410 412 13 Component: SideSensor_Pf 003 0148 Serial number: 350650A25C5530A28E5E Coding: 2D2D2D Rear Side Airbag Crash Sensor (on driver's side): Subsystem 3 - Part No SW: ----------- HW: 480 411 212 13 Component: SideSensor_Dr 003 0148 Serial number: 351651A011334F32CFFJ Coding: 2D2D2D Passenger side rear thorax airbag crash sensor: Subsystem 4 - Part No SW: ----------- HW: 480 410 412 13 Component: SideSensor_Pr 003 0148 Serial number: 352650A25E35F8A52D6X Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1 Part No SW: 5JA 920 940 E HW: 5JA 920 940 E Component: KOMBI H04 0709 Serial number: 00000000000000 Coding: 411A00 Shop #: WSC 73430 031 00051 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723 ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod VCID: 3D718CF3AC71A77EE8-8068 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb Part No SW: 6N0 909 901 HW: 6R0 937 087 Component: GW-K-CAN TP20 H34 0411 Revision: BF034001 Coding: 932300 Shop #: WSC 73430 790 00051 VCID: 70EF65C7A3A31A1633-8024 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H04 0709 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: 6ADB77AF8D7FE0C67D-803E No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7665586601 Coding: 030100 Shop #: WSC 73430 790 00051 VCID: 2B55B2AB4A0539CE46-807E No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb Part No SW: 6R2 909 144 R HW: 6R2 909 144 E Component: EPS_TRW_ALow 321 3111 Serial number: CDCH0861 Dataset Number: 5JJ074t____ 0014 Coding: 0003 Shop #: WSC 46635 001 1048576 ASAM Dataset: EV_SteerAssisUDSTRW 011021 ROD: EV_SteerAssisUDSTRW_011.rod VCID: 479DEE1BFEADFDAE42-8012 3 Faults Found: 1094656 - Steering angle sensor B1168 54 [10001001] - Missing Calibration / Basic Setting MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 59 Mileage: 87269 km Date: 2025.03.13. Time: 10:39:31 1073664 - Steering End Stops Not Learned C10AC F0 [10001001] - Unknown Error Elaboration [New feature! Extended UDS fault detail is only supported by current gen. interfaces] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 59 Mileage: 87269 km Date: 2025.03.13. Time: 10:39:31 1073920 - Steering End Stops Not Learned C10AC F0 [10001001] - Unknown Error Elaboration [New feature! Extended UDS fault detail is only supported by current gen. interfaces] MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 4 Fault Frequency: 1 Reset counter: 59 Mileage: 87269 km Date: 2025.03.13. Time: 10:39:31 ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 5J0 035 161 E HW: 5J0 035 161 E Component: Radio-SWING 004 0001 Revision: -----04S Serial number: SKZ4Z2N1366436 Coding: 090004000007 Shop #: WSC 73430 790 00051 VCID: 2447599727DBF6B687-8070 2 Faults Found: 00856 - Radio Antenna 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 57 Mileage: 87198 km Time Indication: 0 Date: 2019.08.03. Time: 19:07:50 00821 - Antenna 2 for Radio (R93) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 57 Mileage: 87198 km Time Indication: 0 Date: 2019.08.03. Time: 19:07:50 ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels:| 7P6-035-730.clb Part No SW: 7P6 035 730 K HW: 7P6 035 730 K Component: TELEFON H15 3200 Revision: 1B001001 Serial number: 00007665610250 Dataset Number: 7P6035730K 0001 Coding: 0200000000010110 Shop #: WSC 73430 031 00051 ASAM Dataset: EV_UHVNA 002720 ROD: EV_UHVNA_002.rod VCID: 3A7B87EFBD5F9046CD-806E No fault code found. End-------------------------(Elapsed Time: 05:15)-------------------------- tia
  18. Its wrote in marker pen on the unit under the bonnet
  19. Hi all so this car has a donor ECU none original to this vehicle would the VIN or Coding changed when i reset to steering -44 to factory ? There is no other fault codes related to lost coding Is this something VCDS can fix?
  20. Nearly solved this On this occasion the steering required VCDS resetting unsure if moving the rack & wheels while stationary for the replacement inner tie rods or a mischievous mechanic has done something to clear the codes When i looked at VCDS the steering assist was set to Unknown instead of auto comfort or dynamic Possibly the other values where stored in-correct while setting the SA manually
  21. they do have software controlled end stops to say otherwise is either uneducated or ignorant Just wondering if VCDS requires timeout changing/prolonging for measured values maybe the steering angle is looking for abs wheel sensor values but the car is stationary idk Tbh pal idgaf if you want to help or not with the tone of your replies i’d hazard a guess your gatekeeping information or just thread bombing with no added value When i find the resolution i’ll post it on here for everyone to learn from
  22. It drives better than previously from the mechanics Just hope no damage has been caused while the steering was heavy putting stress on the rack etc I have a failing laptop battery thats not helping the situation either that should be resolved Monday or Tuesday I’ll take it to an empty carpark and try again also could disconnect battery see if i can manually set the angle Tla
  23. “not to play with settings” How are we supposed to fix things It shouldn’t be this difficult to adapt the steering system, ABS speed sensors are working correctly, no fault codes where present before i reset However The car steering wasn’t driving as it left factory Now ive reset all settings the power steering is working better than before and it’s possible to change assist parameters however the yellow dash lights are illuminated When trying to set steering angle VCDS state malfunction or error in 03 -ABS or 44- steering Ive just took it for a drive, it feels like the drivers side end stop is software controlled now but the passengers still feels like the tie rod end is taking the brunt of it Assisted steering seems working fine on dynamic Obviously feels unstable while driving as the Electronic stability fault light is still illuminated Steering angle is still not set and stays at 0* while monitoring values
  24. Previous to this car had no faults or warning lights Reset to factory settings now i can’t set steering angle or enter measuring blocks etc Fault codes are Steering Angle not set end stops not learned However VCDS states error or malfunction when trying to calibrate in Basic settings?
