Benja77
Joined
Last visited
Currently
Viewing Topic: Front windows opening slightly automatically on entry ???
Everything posted by Benja77
Karoq VCDS coding
Can You please write in English?
Heated seats, the return!
Hello everybody! I appear again (but only because car is in workshop) for some infos about heated seats! Given that I bough kits (for front and rear seats) from Aliexpress and according to the mechanic (official Skoda) they're very good: Do the front ones connect in BCM? When the Blind spot has been retrofitted, in fact, the mechanic (the secon one for those who remember how many troubles I had), connected the harness, putting in parallel (the work together) and using a switch that allowed from "OFF" to "HIGH HEATING" without the intermediate tempertues. When I went to Skoda, their mechanic asked me if I needed the temperature sensors, where do I purchase them/are alocated them? Consider I bought a main harness spare kit (https://www.aliexpress.com/item/1005009645427157.html), that means I can preplace the ifthe previous one doesn't work properly! About the rears, I bought a full kit, that means resistences and harness (https://www.aliexpress.com/item/1005009420254784.html), the switch for turning them on/off and set the temprature (https://ovoko.it/parte/ipj173847-565963107-skoda-Karoq-interruttore-di-controllo-del-sedile/a), relè (https://ovoko.it/parte/dfp7084-skoda-octavia-mk2-1z-altre-centraline-moduli/a) with plug (bought directly from Skoda), but even here it looks like I cannot make them work for the same reason! Is there anybody who can help me?
VIN with Sleep Package
I’d like to fit them in my Karoq! I have leather and alcantara grey/black heated seats! Indeed the’re not properly cheap but I really like them!
Thank You
Hi there! I'm looking for a VIN of a Kodiaq (or an Octavia, this is why You can see the same post in the other section) equipped with the sleep package OR at least if the owner can provide me the part number of the rear side headrest with side support for the head! thanks in advance! Ben Your two other posts have been removed. Cross-posting is not allowed and can result in the deletion of one or both posts. Cross-posting is defined as posting the same information in two or more separate forums. We understand that some topics might fit into more than one forum. Please try to pick the most appropriate one and stick with it. Briskoda admin.
Karoq VCDS coding
Do You suggest to write down original coding so I can return to it in case the new doesn’t work/restore it? You coded this menu via VCDS? Which voices can You visualize? Can You post an image of the Off-road Menu?
Karoq VCDS coding
Which year is Your Karoq? May I code the off-road menu on my 22 FL?
- Facelift model front pdc.
MY17 Superb Retrofitted with Direct TPMS
Mine too
- Park Assist retrofit: car doesn'r appear on screen
Retrofits update
Hi have MIB3 High
Retrofits update
CCS?? You mean normal Cruise Control (the 3rd type)? If this, I will! Hope the screen swap will be possible!
Retrofits update
New update: After a couple of replacements of the spiral rings and the steering column (both purchased separately, the steering column switch), the third attempt (with the steering column and steering column from another Karoq) worked flawlessly, and I restored EVERYTHING, and still EVERYTHING works even better than before! I also replaced the understeer control unit, the one that controls the Travel Assist, because from what I've read around/seen on YouTube, it's due to the sporadic TA malfunction, and so far I'm not experiencing any problems. I also purchased another chip on Aliexpress that allows semi-autonomous driving (level 2, like the one I already have) for a longer duration of up to 8 minutes, if not unlimited, but I preferred not to install it for two reasons: 1) If it works now, I didn't want to disassemble everything again if the new one didn't work; 2) The new chip is for the MQB Evo: the guy in the video who recommended it has a Golf 8 GTI and, according to him, there are no incompatibilities. This chip comes, as mentioned, from AE, and the reviews are still very favorable! Seeing BS working is awesome too! Seeing all the ADAS active (third photo) is certainly impressive...!
Help on retrofit of front/rear heated seats
Nothing?
Hi there! I’m going to retrofit the heated seats on my car, or better I already did on the front ones and with new year I’m going to install the resistances in the rear ones. About the front ones, they initially didn’t work than I realized the first mechanic connected them on J519 (in BCM) but don’t know to which pin without putting the 25A fuse on position 26 of the fuse box; I also discovered (thanks to the second mechanic? he didn’t put any relay (it should be the one with part number 3T0959772B, see the first pic) which controls how much the seats must be warm. Always the second mechanic, the one who make the blind spot retrofit working, cut out the harness (in a point where he can eventually weld it again easily) and make them work thanks to a temporary relay (it was the end of the day and he want me to test them), as he told me the OEM relay has no connector for the harness coming from BCM, seats and climatronic panel and that goes on the relay of the first pic: this means I now have front heated seats which are just hot or cold, fine for these cold days but not for after them. So my questions are: does anyone know the part number for the small connector (the one one circled on the second pic) and which is it the right harness color/order to connect all the interested parts? Or is it the relay When I’ll connect the harness for the rear seats on the J786 with another 25A on position 51 of the fuse box, do I need a second relay with part number 3T0959772B or the first one is enough? I in fact noticed the relay has (see third pic): 4 big connectors and, in my opinion, they’re 2 positives and 2 negatives to connect harness to BCM/fuse box) which turn on/off the heating 12 small connectors for the heating levels of the seats, and since they (the levels) are 3 they’re exactly for 4 seats, and the central rear one is not heated. Can anyone help/correct me? Meanwhile happy 2026
- Mib3 Map Updates 2025.02-06
I unzipped the file using Windows explorer, so it looks like is NOT the right program to build the right “tree-line” in the root; even if I use a reversible USB C/A pen drive formatted as ex-fat. I’ll try to build the right tree-line based on the linked post. Attached is how I see actual tree-line So I need to make folders named MIB31_EUFB11 — MIB31_EUFB11001 — MIB31_EUFB11002 … — MIB31_EUFB11901 MIB31_EUFB12 — MIB31_EUFB12001 — MIB31_EUFB12002 … — MIB31_EUFB12901 etc. right?
Hi and merry X-mas everybody! What I don't get if I have to copy the main folder with all the subfolder inside OR all the subfolder in the main root; last but not least: if I enter in the Engineering menu (pressing and holding MENU button) system asks me to update the maps but nothing changes, except I saw the firmware version to be updated only when car is parked (but it didnt' change anything after a 2h trip) otherwise, while moving nothing chjanges
- Automatic door protectors retrofit: is it possible?
- Front sequential side turns
Is it possible to cide dynamic/sequential front turns?
