Everything posted by Benja77
- vRS Heated leather seat retrofit
- Blind spot assist retrofit
When my mechanic connected harness, I saw the hitch icon even if I don’t have it too, but at the same time, I got many errors the my virtual cockpit seemed a Xmas Tree… 😂 That’s why I replaced with the H as there’s no dataset installed it (on the B I have to overwrite it with the Karoq one but dunno how doing it)! Schema should be the same, even if a person I know fitted BS and direct TPMS on the same connector of TUIL (but she didn’t clarify me what the TUIL is)! However, does the BS work on Your car @Vincent_83 ?
I tried B (taken off from a Kamiq with AliExpress harness) but mechanic wasn’t able to configure them! Now i asked him to fit a set of brand new H and once the job will see if they work or not! Otherwise I’ll put back the B @Vincent_83 : did You make a retrofit too? If YES, where did You connect harness on the BCM? Does trailer assist turn on as well?
Do Superbs have heated seats?
Yes, I have Karoq: how can I do?
Is there a specific coding to see heated seats and/or heated steering wheel to visualize on Amundsen/Columbus? And if YES, Which is it?
How to: Travel Assist and Heated Steering Wheel Retrofit
Ok thanks! I got the resistences over AE, putting inside the seats and today (or tomorrow) with the mechanic we'll connect pins in BCM; they should work without any coding BUT I just want to to make visible on infotainment screen as OEM. If anybody can help, I'll be more than grateful!
Dash cam port C on rear view mirror
I don't think adding a fuse, especially if You have the slot free and available con ruin the electrical system
USB-C port on the mirror works only with car turned on; if You wanna constant power on a dashcam best way is using it with the fuse box or with an external power bank
Does the aircon coding allow me to turn on the heated steering will from infotainment display too, and eventually turning it on automatically? Do You also have the coding for the heated seats?
MY17 Superb Retrofitted with Direct TPMS
Thank You!
Yes I have the same, now have to codify it; any suggestion?
