Everything posted by gareth71
Assistance services suddenly become unavailable during journey
Out of interest, what were the weather conditions at the time? I've found that the sensors/cameras which provide the input to all the 'assist' systems are far more susceptible than they ought to be to moisture, condensation, etc.
Range Rover Velar D300 V6 to Superb L&K - Guidance, Advice and Opinions
Nice colour!
Tire pressure value can not be seen on central infotainment display
Passive TPMS only (pressure loss determined by ABS sensors, not direct measurement of pressure) on the Superb. Bit of a let-down on a supposedly top-of-the-range car, really.
rattle centre consul
Little-known fact - "Skoda" is Czech for "rattle". The trim build quality (along with the software) is the big thing which lets down what should be a great car. I've had mine a year, and I'm still chasing rattles and buzzes in the trim and plastics.
Superb Estate
Any Youtube video which starts with that patronising "wagging finger" gesture gets stopped instantly! 🤣
- Windscreen cracking
- Superb Mk4, L&K - ACC Disappear from assistant systems
Cleaning Veritate wheels
The same stupid 'gutter' arrangement exists on my Belatrix wheels too. Following with interest!
- Start stop issues Superb L&K 2025
Seat ventilation?
The first question has to be - does this still happen when you have the key in the front with you? Either in a pocket, or in the centre-console cupholder which has the key logo on the base of it?
Ghost speed limits
As far as I can tell, it's a combination of sign recognition via the front-facing camera, and map data. The sign recognition seems pretty reliable. The map data, though, is of wildly variable quality - in some areas near me (northeast Wales), the data is wrong more than it's right. And unfortunately, when there's a discrepancy between what the car 'sees' and the data it's pulling from the onboard maps, it seems to give preference to the map data a lot of the time, so the correctly-detected limits from roadside signage are overridden by the incorrect speed limit data from the map.
Potential new owner
2L diesel in a 4x4 L&K.... since I've owned it (almost exactly a year), average is 48.92mpg across all the fill-ups in that time. Best tank-full was 57.21mpg (mainly motorway miles), worst was 41.35mpg (almost exclusively stop-start local journeys). Common issues? Well, a trawl through this section of the forum will reveal most of them. Mainly software related...
Rear wiper blade part no.
As you predicted - reply from Parts In Motion saying that they'll refund for the A335H, and to not bother sending it back. Can't argue with that!
A384H blade (Bosch part no. 33970160F2) fitted to rear wiper - sweeps the window perfectly. Parts In Motion are advising incorrectly on their website - they say the A335H is the right blade (it has the right fitting, but is shorter than the replacement) ; and they advise that the A384H is not the correct part (Bosch say otherwise, and it works perfectly when fitted). I've asked them to initiate a return for the A335H, with them paying the postage seeing as it was bought based on incorrect advice given by them...
Latest software update - changes to ACC
Nope, diesel 4x4. Don't know which version I'm now on - not near the car to look - but it updated a couple of days ago which is when the new and unwanted ACC behaviour began.
Looks like there's been an OTA software update of some sort in the last couple of days. I noticed the behaviour of my ACC changed, and it started responding to the detected speed limits. Luckily, there's an option to turn that off (go into the Driver Assitance menu, go to ACC, and turn off Speed Limit Response) - the 'off' setting of which persists through a shutdown and restart. The main reason I pretty quickly turned off Travel Assist when I first got the car is that the speed limit data on the in-built mapping is so woefully bad, and so keen to override what the car is actually 'seeing' on roadside signage, that it's almost dangerous. Around my part of the UK, at least, the mapped speed limit data is dreadful - to the extent that, if Travel Assist had its way, there are locations where the car would think a limit had dropped from 60 to 40, or 50 to 30 (or even 20) and would slam the anchors on in response even though the actual limit was nowhere near what the map data thinks it is. Borderline dangerous, if someone's driving too close behind.
Just had a response to the e-mail I sent to Bosch (asking why they appeared to make a blade which is too long, and a blade which is too short, but not one which is just right - maybe they read Goldilocks too often as kids!). Their response - "We also make a A384H blade, which is a few mil longer than the original fit but pretty much the right length". So I've ordered one of those from PartsInMotion too, to see what the fit is like. If it's a better replacement than the A335H, they'll be getting a request for a return of that one, with postage at their own cost on the basis that the advice given by the 'fit checker' on their website is wrong.
I've just ordered one of the Bosch A335H blades too. Like yours, the one fitted to mine is 355mm along the rubber - the Bosch options with the right fitting are either 330mm or 400mm. Looking at how close the sweep of the blade currently gets to the top of the glass, I suspect the longer one might be too long - so sacrificing a few mil either end seemed like the best way to go. It's bizarre that either Skoda have fitted something which isn't a standard off-the-shelf blade length - or if it is, why it's seemingly almost impossible to find a direct replacement without paying silly money for a genuine Skoda part.
Thanks, Foster91 - but that looks to be a kit of all three blades, I just need the rear. Also the clip shown on the rear blade in the photo is completely different to the one fitted to the mk.4 - it looks like the clip which fitted the rear wiper on the mk.3 before Skoda changed the design of the wiper arm in, I believe, 2022.
Yeah, as I said, I've Googled it. That's the problem. Contradictory results suggest either the Bosch A335H (blade length 330mm) or A405H (blade length 400mm), depending on who you're inclined to believe. The blade currently fitted measures 355mm, so doesn't really match either. So I was kind of hoping for an answer from someone who's actually bought a blade and can tell me what they bought and whether or not it fitted.
Can anyone confirm that 3V9955425A is the correct part number for a rear wiper blade for a 2024 mkIV Superb rear wiper please? I'm fairly sure it is, but Google seems to suggest that there might be two different part numbers depending on build year...
- Dashcam installation
Tailgate closing with me inside!
For this very reason, I've turned off the "virtual pedal" foot sensor which opens/closes the boot. Don't miss that particular function in the slightest, and can now lean into the boot without it trying to eat me.
L & K Superb 2025 Hybrid. Chimes.L & K Superb 2025 Hybrid.
As above. The sound you're hearing is likely the overspeed warning (exceeding what the car thinks is the speed limit). It can be turned off easily (right-hand thumb-wheel on steering wheel) - it's become a habit for me now, first thing I do after starting the car, takes a second or two to do. As far as I know, there's no audible warning for a change of speed limit. And yes, the car's onboard mapping of speed limits is woefully bad - so many errors around where I am (north Wales). Even recognition of a clearly-posted speed limit sign can be overridden a few yards further along the road by the map data's incorrect speed limit - followed by a correction as you pass a repeater, followed almost immediately by the car again reverting to the incorrect mapped data 😂
Dashcam recommendations for Superb 4
Nextbase are indeed bull****ing you - just as they've been bull****ing me for the last 10 months about the fatal bug in their MacOS viewer software. My Nextbase is mounted on the windscreen of my Superb, next to the rear view mirror, and locks onto GPS with no problem.
