Everything posted by Scrounger
Thinking about an Elroq, but...
We use this as we used to have a Tesl. It's very useful and the Tesla app will show you which chargers you can use but be mindful that not all Tesla charging locations are available to non-Tesla users.
Elroq: Who else has ordered?
Just piggyback a constant and battery live with a hardwire kit that you can adjust the auto shutoff function. My Viofo dashcam hardwire kit has 4 low voltage setting that when it reaches the set point the camera shuts down, so protecting the 12v battery. I also have the camera set to parking mode.
Skoda Elroq pedal vibration
Sounds like something is out of balance. Have you had a tyre changed or have you hit a pothole or mounted the kerb at some point? Also check your wheel bolts are tight. If none of the above I'd get it booked in.
Standard kit
If you scroll down you can select which variant you want and its standard equipment.
Lane guidance Vs keeping
Lane assist is just that, it keeps you from going over the line however, IIRC, if you're using ACC then it will keep you in lane. Personally I turn off most of the nanny devices as they drive me nuts
- Actual v estimated mileage and charger anxiety
New Elroq - Just arrived at Dealers! Tips?
I've no idea what the paddles do either so I just leave them alone and just drive in 'B' for max regen.
As already mentioned, check your tyre pressures when you get home. Before you leave the dealership, check for any damage to bodywork or interior trim. Take someone with you that can go over the car whilst you're doing the paperwork. The excitement of collecting a new car can give you rose tinted glasses so let someone else check it. Also be sure to check under the car as well especially side sills (rocker panels) for damage.
Just charge it to 100%. We nuke ours each time to max and we are currently seeing 284 miles range on a full charge. For clarity, ours is a company car so if the battery is toast after 4 years it's not our problem however, our previous car (Tesla M3) we always charged to full and in 4 years and almost 70k miles it only lost about 10 miles in range.
Granny Charging
Crikey, at that rate it'll take you a week to charge the car. I take it you're waiting for the 7KWh wall charger to be installed? If not then you should get one or charge it at a public charging site.
Question from a Karoq owner
They adjust the regen but I've yet to figure out how. I just put ours in B and let the car do the rest.
vRS built and sat at Emden - Roughly how long?
You should have rejected the car and got them to order you another.
Enroq vRS question
We charged it yesterday adding 39kwh and it took 12hrs 51mins. It was also charged on the 23rd adding 61 kwh and took 10hrs 13 mins.
Enroq vRS question
I'm in the Manchester area. If the car is plugged in then it is preconditioned when cold. If it isn't then I don't precondition it.
Enroq vRS question
I can only report what the car tells me I'm afraid.
Enroq vRS question
Shows anything from 3kwh to 3.4kwh on the dash depending on the driving situation. The car is pretty much driven down to 60 miles in range before charging up to 100% mainly at home on a 7kwh charger however when needs must it's charged using public charging. Not sure what you mean by not that cold. We've had the car since October '25 so have only driven during the Autumn/Winter months. Short trips using the cabin pre-heat and heated windscreen will also reduce the battery range obviously.
Enroq vRS question
Just to give an update on the mileage. We are now at 5000 miles and 3 months of ownership and when the battery is fully charged it shows ~240 mile range. Admittedly we are in the depths of winter and short days so the likes of heated seats, steering wheel, cab heater, headlights etc are on pretty much all the time so I'm hoping the range will improve once the weather does. We also run in individual mode so sport suspension and steering as the normal suspension is too wallowy imo. I suppose if you drive in Eco you could attain 300 miles from 100% battery. One thing we have found though is that the Elroq will charge very quickly when charging from a Tesla super charger... and yes you can use them by downloading the Tesla app (if you want more info as to how to do it let me know). The battery charged from 10% to 100% in 35 mins. It is a bit of a PITA when charging with Tesla as you'll need to straddle 2 bays so think and choose wisely when using them. The Tesla app will also tell you which super chargers will accept none Teslas. There are some parts of the infotainment I'd like to see improved on such as changing from one primary phone to another and hanging up from a call (we found you can answer by pressing the right scroll button on the steering wheel) and the comfort access is a pain the the backside but apart from that the car is great.
- Replacement tyres
Aftermarket Boot net?
You can buy the official one from Skoda SKODA Parts DirectEnyaq/Elroq 2021-Present Parcel Shelf (With Netting) | 57...SKODA Parts Direct Škoda Karoq 2017-Present Parcel Shelf | 57A867871A 9B9| Genuine SEAT Parts & Accessories Delievered Straight To Your Door
Noise when turning steering wheel
Picked up early October. Mileage is currently at 3198.
18 inch Tires Elroq 50
The link you've posted is for a space saver wheel and tyre. Even though this is available in an 18 inche size the offset will allow for clearance of brake discs/calipers/drums whereas the alloy wheels may not. Looking at the Skoda accessories catalogue, winters aren't available in 18 inches anyway unless you go after market. IMO you have 3 options Buy a set of winter wheels and tyres and swap them over when needed Buy a set of winter tyres for your current set of alloys and change them over each year Buy a set of all season tyres which will get you decent all round motoring here in the UK however, if you're planning on going into Europe during the winter, several countries require you to change to a full winter tyre.
Nope. Ours doesn't do that. If you're not happy with the diagnosis of your dealership then go to another for a second opinion or ask your service guy to go to another Elroq and see if that one does it.
Auto Full Beam Control
Our VRS has auto full beam as standard. Just push forwards on the 'flash' stalk and the 'Auto' sign comes on. Works great. Can't believe you have to pay for it though.
Should we buy an Elroq?
https://www.marinetraffic.com/en/ais/home/centerx:-12.0/centery:25.0/zoom:4 https://www.vesselfinder.com/ I use these 2 websites to follow marine traffic. Just ask your dealership for the name of the vessel and you can search and follow it's journey. If you live in the South then most vehicles will be delivered to Sheerness. In the North it's Grimsby. Unfortunately once it's in the country you are in the hands of the logistics company and there isn't any tracking available for that. Dealerships usually get notification of delivery a couple of days before it arrives. Something to bear in mind is that car transporters will not leave unless they are full and only with deliveries to multiple dealerships in that particular area, it's not logistically viable to have a transporter travelling all over the country dropping 1 car off at a time. Hope it helps
