Everything posted by tombee
Steel Pedal Covers for DSG
Is yours a VRs? What year is yours? Hoping to get the part numbers to confirm, rather go genuine if possible rather than alternative routes
Does anyone know which will fit for a DSG 220PS, can you use any of the VAG steel pedal covers? Going back to when I had my Bora and fitted the R32 Steering wheel and Pedals to it, before then removing to then buy a R32 Golf only a few months later
Just collected the Alcantara Steering wheel with Flat bottom and paddles from the dealership this afternoon, along with a new nut. Will fit tomorrow, was too good a price not to do it in the end. Was able to get the dull door inserts back to gloss after getting the Meguairs Compound on them, picture of half way to see what the difference was
Reverse Camera which one
Thought I had seen the line movement on ones with and ones without the washer, my Tarraco did the lines but didn't have the washer. The Amazon based ones looked to be an easy install but not factory which is something I am not sure I could get over...
Will be one from Skoda which has no washer jet for the lens but the highline version
About to pull the trigger on a OEM kit but just wish to know is this better than an Amazon based one
Suspension options
Thanks, it seems to come down to do it once and right rather than keep doing other things to then revert to what you should do at the start, but I have a steep drive hence why would only go as low as a Sportline on the SE L Executive
Suspension options
This seems the best option with having a steep drive to the road
Suspension options
I don’t have DCC, so I could run the Sportline springs with B6 which should give me the right lowered approach with out the car being 30mm plus lowered
Suspension options
@logiclee thanks for the reply, I was hoping you wouldn't say that. So could you run B6/8 struts with Sportline springs?
Suspension options
Thanks for the replies. Does the 4x4 version suffer with the same suspension issues, drove it on a long distance this week and really noticed how the car is a little bouncy with now compliance when at high speed, so really looking into doing this. As I could upgrade to the Sportline suspension to get the slightly lower look and better feel or do they suffer also?
Suspension options
Just been looking into KW Suspension V2 Comfort
Suspension options
Was that with upgrade struts? Bilsteins?
Suspension options
Thanks for the reply @MartiniB mines a fWD 220ps
Suspension options
Hi all, Reading a few threads of suspension changes and was thinking of doing the same Does anyone know of any spring kits which go with the Bilstien B6 non adaptive to only lower the car 15-20mm, not wanting 30mm plus lowering. Just so that car sits a bit lower on the Trinity alloys it has, you used to be able to get top caps which did similar but not sure if this is still a thing. Thanks
Morning
Thanks for the welcome, great tip
Hi all, Just collected the Superb yesterday although a 2018 SE L Executive it seems to be a SE Business so didn’t come with the rear camera among others. But what I am wondering is there any benefit going for the OEM wiring and camera over others that have been discussed on here? I have the newer style touchscreen head unit Other than having OEM camera etc is there any real benefit? Thanks
Morning
Morning all Been a lurker for a few weeks now I have the car, Superb Mk3 I need to get some questions answered ha Tom
