skoda1982
Everything posted by skoda1982
  1. KAMIQ OWNER'S MANUAL About the Owner's Manual Video tutorials Explanations Instructions in infotainment Vehicle overviews Warning lights Correct and safe Keys, locks and alarm system Doors, windows and boot lid Seats, steering wheel and mirror Restraint systems and airbags Lighting, windscreen wipers and washers Heating and air conditioning system Driver information system Analogue instrument cluster Digital instrument cluster Driving data Overview Operation Settings Speed limit warning Vehicle status Infotainment Swing Infotainment Bolero Infotainment Amundsen Online Services Starting and driving Driver assist systems Park Assist systems Engine, exhaust system and fuel 12 volt vehicle battery and fuses Wheels Storage space and interior equipment Roof rack and hitch Maintaining and cleaning Technical data and specifications Engine specifications Operation Display driving data in the display of the instrument cluster via the operating lever Select the menu item for the driving data in the main menu in the instrument cluster display. A Press: Press - Select information/Set values B Press: Confirm information Display driving data in the display of the instrument cluster via the multi-functional steering wheel Select the menu item for the driving data in the main menu in the instrument cluster display. A Turn: Press - Select information/Set values Press: Confirm information
  2. press CAR then settings Virtual cockpit. Or press folder right side buttons then scroll
  3. I no it's gone from suspension to engine but this youtube video explains the 1.5 act tsi https://youtu.be/yoohR8sar5g
  4. Them 4 settings are driving style not engine ECO
  5. Normal holding the boot on that's a blue line marker from factory as checked
  6. Go to settings you can adjust voice announcements
  7. When eco comes on its running on to cylinders. 2 are shut off exhausted gasses are left in the 2 none running ones as to create pressure too force them down in rotation. If you go on the motorway and eco activities accelerate you will get a type of turbo boost. eco is always there it just gets brighter
  8. Might be your winter tyres rims
  9. Some people had there’s changed if it was excessive like water droplets
  10. Normal it’s listed in your manual
  11. Because it doesn’t sound manly enough
  12. Anytime you get an update do a reset. Press on button till speakers thump. The informant uses a sd card eMMC that loads all the information same as a computer
  13. No as they are not sealed units
  14. They do Comfort and multimediaWinter pack Winter package comprises heated front seats and heated windscreen washer nozzles. £485 ADD
  15. I have never turned mine off you get used to it you don’t have to fight with it just turn like you would if a car was coming towards you it turns off. If you are going in a straight line and it reads a white or tar line hold in opposite direction it turns off a second or just indicate as that turns it off as well I like it on motorways as it reminds you to indicate
  16. The seats in the kamiq are the same as the scala so adjust to the same height so feels lower in the kamiq
  17. They will be 16” as you don’t want low profile if you want you can get the wheel spacing of the back of your alloys
  18. Have you got any messages in the circle top of screen press it that will tell you if updated. And do a reboot press on button till you hear a pop. Some updates can take hours sometimes more than 8 hours
  19. Have you linked your car with vin number. Did you have to pay a fee for the year. On your informant do you have a circle with numbers in top of screen if so press it
  20. They are done automatically go to skoda-connect.com and register
  21. You won't now about update only app updates it does it automatically if you have skoda-connect in the UK you get it free for the first year with a new car then its £44 per year
  22. https://www.skoda-connect.com
  23. Done by skodaconnect.com register
  24. I have the 1.5 manual never had kangaroo jumping so don’t think it’s a characteristic probably dealer fobbing you off have you had the update to stop it
