MoggyTech
Resident Member-
Posts
6,533 -
Joined
Last visited
Content Type
Profiles
Forums
Gallery
Shop
Events
Downloads
Everything posted by MoggyTech
Don't rule out brake pad slap if i'ts more of a dull click, rather than a knocking sounds. Also spray the part of the wishbone where is goes into the console bush with white PTFE grease. No need to dismantle anything, just spray the joint.
Stick with what is known to work. Sikaflex, roof and gutter sealant, Unibond 3 in 1 sealant all good. Silicon sealant, useless, Dum Dum useless.
Caked in gunge at 60k for sure, not worth cleaning cos if the vacuum diaphragm isn't leaking now, it soon will be. Any signs of oil from the small breather hole below the bit that looks like a flying saucer, means the valve is goosed. Don't fit a pattern Chinese part, they fail after a few months, fit OEM, worth the extra dosh.
Fabia vRS - ABS/Electrical Problems
MoggyTech replied to Yohan's topic in Skoda Fabia Mk I (1999-2007)
Looks like the ABS controller is faulty, prepare for wallet shock. -
Glow plugs not stating on long
MoggyTech replied to faboka vrs's topic in Skoda Fabia Mk I (1999-2007)
Sounds normal to me, mine has always gone out within a couple of seconds, even when it's really cold outside. The white/grey smoke will simply be condensation inside the exhaust burning off. Relay is on the right hand side of the battery box. -
Check battery and battery earth cable first. If they are OK, looks like ABS control unit faulty or wiring to the control unit. -
RIP Andrew
Airflow is left to right looking from passenger seat.
Console bushes, or drop links, or ARB bushes. In that order.
+3 can't see video, it's a GIF image for me, not a video link (Firefox)
Alternator load signal wire
MoggyTech replied to theandywaite's topic in Skoda Fabia Mk I (1999-2007)
Battery tray out for access, repair broken wire using bridging wire. All in say an hour, so about £50. DIY it costs about 50p -
Sounds like a Prescot and dumb secretary joke.
That stuff makes me fart like hurricane Katrina
Just covering their bases and doing it by the book. Expect to be charged for new clutch kit, which should really be changed along with the DMF while the gearbox is out.
Yup, disconnect hose from rocker cover to inlet, plug inlet where the original hose was fitted, run new hose from rocker cover into a vented oil catch tank, and no more blow by gases get back into the engine. So no more gunge in the EGR or inlet manifold.
One solution is to have a custom EGR delete made, that will accept the throttle body being bolted back onto it. The EML can then be mapped out by a tuner as part of a remap. I still think it is better to leave the EGR alone, and do the elephant hose mod, to remove the oil vapor from the equation, and turn down EGR as low as possible with VCDS. That way you just get dry soot, and combustion temps will stay normal.
Mileometer not working correctly
MoggyTech replied to sherbolton's topic in Skoda Fabia Mk I (1999-2007)
Sort out the ABS sensor and the speedo will work correctly. -
If only. The BLT engine uses an EGR vacuum operated, but also a separate throttle body/ASV that is controlled by the ECU electronically.
Measure battery voltage first thing in the morning before starting the car. If less than 12.5 volts replace battery.
Fabia VRS - Steering/Tracking - Inspection
MoggyTech replied to Bloitus's topic in Skoda Fabia Mk I (1999-2007)
Simple things first, all tyres same profile and same make on an axle, all at correct pressures. Rear beam axle, not bent due to jacking on axle cross beam. Console housing to subframe, and subframe to chassis alignment correct. Console bushes in good condition. Anti roll bar bushes and drop links OK. Less obvious. Broken spring on drivers side. Can be hard to spot if it breaks near the top at the upper mount bearing. Accident damage, resulting in bent chassis rails. -
1.. Auric Goldfinger.......Train Driver 2.. BillyT1903...............Contract Officer 3. Brianpilman .............transmission assembler for digger maker 4. Babs...........................IT Network Engineer 5. Evil Miyagi...................Business Intelligence Analyst 6. [email protected] Unix Engineer 7. grr666........................Self employed builder/handyman 8. Tech1e.......................Skoda Master Technician 9. Philje123...................Financial Assessor 10. Fikes75.....................Pipe welder 11. mikey vrs...................vehicle examiner/mechanic 12. pee81....................... Retail supervisor 13. Llanigraham.................Railway Signalman 14. disbloke...............Self employed QMS auditor/consultant 15. mannyo ....................Senior Infrastructure Engineer / 3rd line support (IT) 16. devonutopia...............Chartered Accountant (ACA) 17. Fitz323................Senior Weapons Supervisor BAE Systems 18. Baldric313 .............Electromechanical Build and Test Supervisor 19. nigelj.............Management Consultant (cargo shipping safety and security, manufacturing, quality, environment) 20. GrahamVRS...........Airline Cabin Manager 21. MartynVRS.............Website/Database Management and Shop Assistant 22. Trundlenut.............Geologist 23. yeti noob..............Optical Laboratory Manager/Opthalmic Technician 24. Softscoop............IT Administrator & Excel report writer 25. Sharkrider..... Emergency medical technician / driving instructor 26. Jonny5ive.......Hotel Operations Manager 27. Mike B.........Driver, PCV 28. Graeme B..........Production Operator, UK North Sea 29. George512 ..........Computer Games Development Student & Self Employed Web Developer/Consultant/Network Engineer type person 30. VRSETS...........Lincolnshire Police 31. Vrs-waldo.............Bouncer/Doorsupervisor area manager. 32. ChrisRs......Teacher of Physical Education 33. MissPiggy........Supermarket online shopping delivery driver. 34. fabdavrav.......Company Director (self employed/own/run a shop selling specialist walking/climbing equipment)...also a fully qualified Technical Architect...amongst other things!! 35. Prolfe..........................systems engineer 36. AHunterVRS.........Police Officer 37. Boss Fox..................Company Director (Transport) 38. Matt1chelski.............Bus Driver 39. SkodaTC..................Engineer Co-ordinator 40. Raglits..................... Senior Storage Consultant (IT consultant - storage, backup and DR) 41. Sonner.............I sell Private medical Insurance for AXA-PPP 42. Goaty..............Armourer - RAF..... 43. Bencook123........Aerospace Systems Operator - RAF 44. MRTLT.................senior service advisor, Volvo 45. mdk1...................LGV Artic Driver/ at the mo. 46. SimonK24.............Private Jet Pilot 47. Wardy....................IT Systems Manager 48. John T ............Production Operator / Mechanical fitter, UK North Sea (but onshore) 49. TriggerFish. . . University Student (part time shop assistant) 50. D7 GUM.............Electrical Engineer 51. paul007............Town Planner 52. Slider...........Farm Management Consultant and Agricultural Advisor 53. Hannibal....... Management Accountant (ACMA) involved in offshore wimdfarms. 54. Gadgetman.......Field Service engineer (Electro-mechanical) 55. Keystonedriving ....Fleet registered driver trainer (also run speed awareness & driver alertness courses) 56. Flybikeslee....Graphic designer @ sign makers 57. Aspman ..............Information Security Officer 58. Neskud.............Deck Officer [Merchant Navy] 59. DaveI.............. Telecommunications Sales Engineer 60. MoggyTech...........Director/Engineering (Retired)
