rit
Everything posted by rit
  1. I've got this PDF manual but none of that text appears anywhere in it
  2. Thanks the only option I can find in the menus though is on or off. Can't find anything else
  3. the only ones i can see are on line are the vrs with red stitching. i'm after the one you you could upgrade to in se l. thanks
  4. I found out from this site that the 3V0 035 020 mib2 supports the columbus 8" screen and has car play. I looked online and found someone selling this head unit with athe display screen for the suberb. Will this head unit work in octavia 3 and even if it does work will it have the superb in all the onscreen car images when you hit the vehicle button? If it does have the superb image can it be loaded with the image of the octavia? only a small gripe but it would bother me. thanks
  5. Had an Octavia in 2016 which I specced to include lane assist. Replaced it with 2015 L&K which also has lane assist as standard. But on the L&K all the lane assist does is activate warning lights in the instrument cluster. It doesn't affect the steering like it did on my previous Octavia. Is there since option I need to select for it to control steering. Thanks
  6. These seem crazy prices for something that is second hand. The Columbus option was only £750 when I bought car in 2016
  7. How do I find out which of these units were in my 2016 MK3 Octavia? 3G0 035 021 - MIB2 VW Discover Pro 3G0 035 043 - MIB2 VW Discover Pro 3G0 035 045 - MIB2 VW Discover Pro 3Q0 035 043 - MIB2 VW Discover Pro 3Q0 035 824 C - MIB2 VW Composition Media 3Q0 035 819 - MIB2 VW Composition Media 3Q0 035 846 - MIB2 VW Discover Media (MQB) 3Q0 035 864 - MIB2.5 VW Discover Media (MQB) 3Q0 035 874 - MIB2 VW Discover Media (MQB) 3V0 035 020 - MIB2 Skoda Columbus 3V0 035 021 - MIB2 Skoda Columbus 3V0 035 043 - MIB2 Skoda Columbus 3V0 035 045 - MIB2 Skoda Columbus 3V0 035 046 - MIB2 Skoda Columbus 5C0 035 680 - MIB2 VW Discover Media (PQ)
  8. Do those units have car play thought. Thought I'd heard only the mib2 unit has car play
  9. Thanks but I think the unit that goes in the glove box is called the 'main' unit. The unit with the screen is the head unit
  10. Thanks - how do I find the part number for my car of the unit that goes in the glovebox
  11. bought part no 81A 035 044. this is an mib2 and i assumed any mib2 was interchangable between all vag cars. it appears i was wrong. installer says this won't run the columbus head unit i've bought separately (5E0 919 606) after much research i think i need either of these two main units 3v0 035 020 3v0 035 021 but can work out the difference between them. can anyone help out?
  12. The list that the up and down buttons on the steering wheel traverses - is just the stations as they appear according to their frequency. If you are on radio 1 and click the right button you go to radio 2, then radio 3 etc. I want to switch between favourites
  13. My 1.8 coasts but disengages at much higher speeds than my 1.4 used to disengage at - but then reengages and stays engaged if I just tap the accelerator again So it can coast in ECO at the lower speed but it's a two step process
  14. The buttons on the steering wheel go to the next radio station - but not to your next favourite. Is there any way to change this?
  15. Why would the car need to break if you haven't asked it to?
  16. I've gone from 1.4tsi 7 speed dry clutch to 1.8tsi 7 speed dry clutch. One thing I've noticed is that when coasting in ECO mode it often disengages and selects a low gear (3 or 4). I don't remember this happening in the 1.4 If when it disengages I tap the accelerator again - it will go back into ECO mode and then stay there. Is this just a case of a bigger engine needing to rev higher until I override by tapping accelerator again?
  17. Thanks I can see the difference now. Really did think the one I was looking at was the 8"
  18. But it also looks identical to the Columbus in my previous Octavia
  19. Communicating with a company that retrofits infotainment systems. They are saying this is an Amundson but did they make an 8" Amundson? I'm thinking this is a Columbus because of the larger screen
  20. Hoping to get this fitted for £750
  21. I have the Amundsun with the 6.5" screen I think it is. I want the bigger 8" screen but vw-retrofit only have the mib2.5 not the mib2 I know the mib2.5 has better screen resolution but I like the tactile feel of actually pushing the buttons. Also concerned that the glass on the mib 2.5 will be a lot easier to scratch than the matt effect screen on the mib2 Anyone miss the mib2 after swapping. Thanks in advance
  22. Mine came with dunlop sport maxx RT and I've stuck with that brand and type. They tend to get cracks on the walls after about two years. Why suggestion for longer lasting tyres without breaking the bank. Thanks
  23. occasionally (1 every 10 times) the passenger mirror doesn't unfold. I have to close the driver mirror and then reopen again which then opens both of them. How long would you put up with this before getting it fixed? I'm thinking it could be expensive to find an intetrmittant fault like this. thanks
  24. bit annoyed because I've told the dealer what I think the problem is and mentioned the thread on here but they say they will still need to diagnose the problem becaudse they dont know if they have the gear selector that can have the alteration - so that we priobably cost me £90
