sparky2
Everything posted by sparky2
  1. Hi, I managed to fix it at the weekend, disconnected the neg lead on the battery (airbag), removed the 4 torx screws, tipped the seat back unplugged the black seat belt sensor and the yellow connector for the seat airbag, took the whole seat into the house to have a look, the back of the seat base cloth goes round the back and is held in place with plastic hooks onto the springs so unclipped the cloth and pulled it back through the gap between the seat back, managed to pull enough forward to be able to work on the split, cut a small piece of black cloth and used some fabric glue to fix it down over the gap let it set and sewed it to the good side and it seems to be OK. The split was about an inch wide see pics -
  2. Scott I have just removed the EGR and cooler on the 1.6 CAYB engine and I am just about to put a guide on Briskoda.
  3. Hi All, anybody know if the seat base on the drivers seat comes apart to repair the cloth ?
  4. Hi PipH, sorry for the late reply, yes I did look into the plastic inlet manifold and it didnt look too bad, I have stripped out the EGR and cooler cleaned it and am about to refit it back, took plenty of pics and listed how the parts come out so will do a guide to show others. cheers Stuart
  5. Removed it to clean and check and its the throttle body !
  6. Hi Piph, I wasn't going to block it off completely (CAYB) just fit a gasket that had a smaller hole so the build up was slower, I have seen some looms that cancel/emulate the EGR when you fit a total blank but I don't fancy that, It looks like I will remove the EGR and cooler, split and clean it and look at fitting a separate crankcase/oil filter again to reduce the build up, It looks as though some of the gaskets are the same as my Scout (BMM) so I could buy one with a reduced hole size, I will give TPS a bell and see what they can offer, for clarification what's the device at the front of the engine just before the metal pipe from the EGR enters the inlet manifold -
  7. Thanks for that wino, I didn't know it would cause problems on the CR engine so thanks for the warning, I did start having a look on a website for manuals that's linked at the start of this forum but it stopped working as I was trying to download a guide, cheers Stuart
  8. Thanks Wino, I will have a look on you tube, are there any official guides for removing it, I did it on my Scout a few years ago and it was in the same place, do you know if there's any gaskets available with smaller holes in to restrict the flow ? Cheers Stuart
  9. Hi All, Our 1.6TDi CR Spaceback has pinged up P0403 intermittant malfunction 3 times over the last 3 years so I normally clear the faults with VCDS, so I am thinking of trying to sort it out, I know its at the back of the engine under the turbo so can I get to it by removing the intake ducting or will I have to get to it from underneath/back of the engine ? I have done a search but I carn't find anybody thats done it, are there any common faults that ping up with this fault code like blocked pipes ? and while i'm near there will anything else need cleaning ? cheers Stuart
  10. Check the scuttle under the windscreen wipers to make sure that leaves havent blocked the drain holes !
  11. Hi All, update-we manage to do a reset on the throttle body and its started working normally
  12. Hi All, I am having trouble with my dads kangoo disabled van, I put VCDS on it in OBD2 mode and it came up with P0638 'throttle body actuator bank 1 J338 implausible signal' so we removed the throttle body inlet valve and cleaned it up, drilled out the rivets holding the cover and checked inside as there's a motor and a hall effect sensor, hopefully reset its home position and it tan for a bit but then flagged up with a MIL with the same fault, again I checked it out inside the TB and it looks fine, trouble is renault have an extra letter on the end of the fault code to narrow it down to an actual component which VCDS doesn't show. Anybody worked on this fault ? Cheers Stuart
  13. Hi All, We have a 2014 spaceback SE and I have noticed at the back corner of the drivers seat the stitching is coming apart, is it hard to remove the seat and stitch it up from behind or easier to use a curved needle from the top ? Anybody had the same problem ? Cheers Stuart
  14. Does the car reach normal temp as in gauge in the middle ? It could be one of the flap motors in the dash and if so you need to run diagnostics on the car, see if anybody near you has VCDS.
  15. Hi All, I am cleaning my scouts EGR and inlets, can the inlet manifold come off without taking off the turbo ? and its at the back of the engine ! acording to some instructions I have to remove the turbo and a driveshaft ! it looks as though one of the manifold bolts is hard to get at ? cheers Stuart
