varooom
Everything posted by varooom
  1. You should let us know your distance driven in the car, as the DPF lifespan might be getting towards end of life.
  2. I will send you over a PM with link/instructions
  3. Welcome to the forum, your best bet would be to create an account on erWin Skoda, there, armed with the VIN in a text file, you can download the list of build codes (PR codes) for the car (helpful to people in indentifiying parts) and then you can get all the repair/wiring diagrams for the car. It will be in the documents the full removal process.
  4. Welcome, what a fine looking vessel 🤝
  5. Welcome to the forum 🤝
  6. I test mine quickly and get a nice healthy 12.3V (60%) after one week... higher if tested after 2hrs.
  7. 1. 0369 2. No 2a. To load 0369, it has emergency recovery 3. Yes, via PM
  8. AFAIK any car with the naff fake sound actuator, and VCDS/OBDeleven that can address module A9 will be OK. I have only older VCDS that failed to find A9 (as you need newer interface)
  9. That's low 30% State of Charge, not very healthy value at all. It should be 12.5V or close too after such a short time 80% SoC.
  10. Try to use this map to locate someone with VCDS who can read fault codes and do a live data log of the car when driving etc. Save you waiting a while for a dealer
  11. I have sent it, but please note that the FEC codes are what give you functions as your firmware has it already inside.
  12. They never are the best to see in the manuals, but here is the part in question removed. So take a look at these images provided to see the "male" parts that will push into the dashboard, you might need more force than you realise, but you can see 3x points of contact in image and the photo below. https://www.shrot.pl/oferta/skoda-kamiq-boczek-oslona-deski-lewa-654857503-164452#pid=4
  13. As replied in PM, no dice... as the car has no electronic service history entered. Though a dealer or Skoda UK webchat might send you all the details on your car, in reality here is the basic... The gearbox itself is 99% mechanical, and any electrical wires going to it should be 1 or max 2 (reverse sender or starter motor electrics for example) so not too hard to locate sender. Instructions are like this roughly speaking. 200%
  14. You really need to know the gearbox code, but the workshop manuals are not going to be crystal clear. PM your VIN if you don't know your code.
  15. Yes, via PM to you... wait 2 minutes.
  16. Then they should survive the firmware update process 🤝
  17. There is update to 0369 version, not sure it will cure your problem. You may also loose the FEC codes if they have been hacked into the system, won't know until you try update.
  18. Welcome Nathan 🤝
  19. SW: MHI2_ER_SKG11_K3343 MU: 1433 Will send PM
  20. You might be onto something there, I was wondering if there's a region block like Bluray & DVD'S used to have.
  21. Welcome, hope you can add some nice input to the forum with your knowledge 🤝
  22. Welcome John, let's hope we can help you with your troubles.
