TrevorB33
Everything posted by TrevorB33
  1. A few of you might, know but I won a car and of course it’s a Skoda, started another build thread, at the moment I’m keeping both
  2. So I won a Fabia vrs off darkside developments, Big spec diesel Power Figures 332.7bhp & 445Ft/lbs - With Nitrous (50 Jet) 307.1bhp & 400Ft/lbs - Diesel Only Engine GTD2872VRK Billet Hybrid with Vacuum Conversion Darkside Developments Turbo Kit with Tubular Stainless Manifold/Downpipe Darkside Straight through Stainless Exhaust System Darkside Ported + Dimpled Head with bigger valves Rosten H-Beam Rods ARP Mains Studs Darkside Race Camshaft 1.9 8v Headstud Kit Uprated valve springs Firad PD Race 120% Injectors Universal Front Mount Intercooler Custom Darkside Hardpipe Kit Darkside 57mm EGR Delete Darkside Front Mount Oil Cooler AEM Cone Filter Darkside Custom TIP Pipe 6 BAR MAP Sensor Darkside Custom Remap + Hardcut Limiter Wizards of NOS Dry Nitrous Kit (50 Jet) Performance Aluminium Radiator HyperKuhl Super Coolant Fass Lift Pump Snow Performance Water Methanol Kit Snow Performance Solenoid Machined Pistons Coated Pistons Transmission 02M 6 Speed Gearbox Darkside Single Mass Conversion with Sachs SRE Clutch Quaife 02M Limited Slip Differential 4th Gear Support short shifter Chassis Vibratechnic Engine and Gearbox Mounts KW Variant 3 Fully Adjustable Coilovers Adjustable Drop Links Powerflex Bushes with Black Race Series on Wishbone Brakes Porsche Caliper Upgrade Brembo 312mm Front Brake Discs & Track Pads Brembo 256mm Rear Brake Upgrade RBF600 Brake Fluid Wheels and Tyres 17" 2Forge ZF1 Wheels in Gloss Black 215/40/17 Yokohama A052 Tyres Exterior Bumper opened for Air Flow Custom Headlights Plans are afoot mainly to clean it up to my standards, bodywork is pretty good both side sills were done a couple of years back, just a bit of rust coming through on bootlid. Nitrous is going to come off (scares me a little haha) and I’m in the process of tiding all the masses of wiring, as it’s had many additions over the years, nitrous wiring, water meth, boost gauge, sub in its past, some pics before I started my bits and pieces
  3. Got bored so thought I’d see how the dv looks and sounds. There’s a clip on my Instagram @citigovrs for sound as it’s abit of a big file to fit on here
  4. A bit of an update, Had a bit of time off from posting but I’m now back citigos had a little done to it now back on oem Gti suspension 15” Auriga Monte Carlo alloys I changed the fuel tank for a later facelift tank and a new gti fuel pump as ever since I did the conversion I had a fuel pump error code as i was using the original car head and internals from the gti pump and even though it caused me no issues, I didn’t want anything to crop up when it’s eventually remapped. Mk4 Fabia Monte Carlo steering wheel fitted and stainless pedals, just waiting on a new gear knob and interiors pretty much how I want. Also fitted another Brazilian part I imported which is a stainless charge pipe and dv, although you can choose to blank of the dv which is how I’m running it currently. It’s so comfy on 15” with the oem suspension 😁 Some pictures!!
  5. Yes updates soon cheers for reading
  6. Thanks and Cheers for reading
  7. Great stuff and the best colour, very underrated silver
  8. Thanks for taking time to look through thread 👍🏼 are you in York yourself then? I’m normally up and down a64 to Leeds and back in it
  9. I’ve pm’d dont know how often you check in on here
  10. Did a little fitting vid of the intake if anyones bored and has 20mins to spare 😂 https://youtu.be/joe7bzH-yJI
  11. Yes it’s certainly handy to have,
  12. Also fitted a new intake imported from Brazil slight problem with original air filter fitting as the citigo bonnet is slightly steeped where the slam panel is but luckily I had a slimmer one here I can use rest of kit is lovely and incoperates the turbo elbow too
  13. Been busy last couple of days, traction control button wired in as it cannot be disabled on these from factory and coded to work.
  14. No not plug and play runners need modding slightly at front and new holes drilled in rear, they are physically same width as originals then airbags rewiring and passenger occupancy sensor swapping in passenger seat. I made mine plug and play
  15. My new steering wheel arrived hopefully I can get the buttons operating the mfd, watching a couple of airbags just have to wait a month or so
  16. I do like the octy style twin exhaust, god know how to make that work 😂
  17. Cheers I’ve got one in the post as we speak 😂
  18. Still got these if any interest they are really good looking alloys can’t believe I’ve not sold them yet
  19. Just fitted facelift rear lights so now I’m in cool down mode for abit, just needs a service soonish
  20. Alright bud haha, doesn’t get the traffic on here it used too but good to see some familier names still about though
  21. Got my last switch for dash I was waiting for, got some facelift rear lights coming tomorrow and I’ve fitted vrs badges now . Overall other then the steering wheel I’m pretty damn happy atm
  22. Thanks for reading. Yes I would like rear discs in the future as for the seats You do sit quite low with the TT seats although it suited me I’m 1.88m someone on the up owners clubs forum did fit them too but his daughter struggled to reach the pedals properly
  23. Some new bits - Swapped the Eibach springs out for h&r so should be around 10mm down front and rear - EBC Yellowstuff pads to go with the Ebc slotted discs I already have - Powerflex arb bushes - Various genuine new bolts and rear top mounts
