MikeTheThinker
Everything posted by MikeTheThinker
  1. Most likely from a flat battery where the supply voltage has dropped below the Octy "comfort" level. Octy 2s are noted for this problem. Having charged the battery run the car on the road for a couple of miles and if it's the battery voltage problem your problems should go away. Note that if the battery is at all weak you will keep having such problems.
  2. I think it's 8L0 133 837 B which seems to fit lots of VAG cars. Parts diagram here.
  3. What year is your VRS and what motor is in it?
  4. My first instinct would be to check for the quality of your earth connections. If you have one, try checking the resistance from the earth connection from the boot lock to a good chassis contact. It should be zero or thereabouts but if not check the earthing points where the wiring harness is earthed at the rear of the vehicle. IIRC this is below the CD mulltiplayer deck behind the cover on the left of the boot area.
  5. I'd hoped these two might help but I can't drag up any more detsil than you have :(
  6. I've found details of the fuel filter here but as yet no sign of the bracketry. I did note, however, that the part number above (1k0201051k) does not match the one from the 7zap parts diagram.
  7. Do you know the PR codes for what is fitted to your car (the 3-character codes printed on the sticker in your handbook or boot area)?
  8. I'm assuming your VRS is a petrol motor? If so, the parts diagram for an '08 petrol fuel filter is here.
  9. Also these, and they look a bit cheaper: https://www.tjmotorsport.co.uk/products.php?cat=16
  10. These guys look as though they offer what you asked for : https://www.carbodypanels4u.co.uk/ford/cortina/ford-cortina-4-door-saloon-1979-1982-mkv
  11. Is that just for the painting work or does it cover drive-in/drive-out?
  12. Drone piccies by Chris Gorman; interesting article on a deserted UK under lockdown - https://www.bbc.co.uk/news/in-pictures-54181848
  13. My situation exactly! Although having read this thread so far I'm beginning also to wonder about the economics of the situation ...
  14. There used to be an active Dutch forum - worth looking to see if it's still alive.
  15. @DeanVRS20VT I also have a library of mk1 files - mostly 1.8 T IIRC. I'm happy to hang onto them here but if you would like a copy for your library PM me an email address - I can send you a Google{tm} Drive{tm} link
  16. Mark me "interested" too, please.
  17. That's pretty scary ...
  18. WHT 000 229A M16x1.5x70 shouldered bolt.
  19. "WHT 002 795 dodecagonal head bolt M16X1,5X70" As far as I can see this is the same for all gearboxes - manual/auto/5 speed/6 speed - for a MY08 Octy. If the hub nut follows the metric standards then for an M16 bolt you need a 24mm 12-sided socket - one of which is included in that kit I linked to. I believe you're looking for a bi-hex 24mm socket, ideally deep and impact. Here's one from from China if you don't mind waiting: https://www.ebay.co.uk/itm/24mm-3-4-DRIVE-DEEP-IMPACT-WRENCH-SOCKET-12-POINT-SINGLE-HEX-HUB-NUTS/254452281776?hash=item3b3e89b1b0:g:U2IAAOSw-zxd85pt
  20. Here's a kit for several options: https://www.ebay.co.uk/itm/Heavy-Duty-Impact-Hub-Nut-Socket-For-Seat-Skoda-VW-Audi-VAG-TBS0195/184225890487?_trkparms=aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D225114%26meid%3D47210fc9b88b4519ab2cd597272aafcb%26pid%3D100005%26rk%3D3%26rkt%3D12%26mehot%3Dlo%26sd%3D160654740315%26itm%3D184225890487%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv5PairwiseWebWithBBEV2bDemotion%26brand%3DUnbranded&_trksid=p2047675.c100005.m1851 BTW the VAG part number for the hub boly (dodeconal head) is WHT002795.
  21. It looks like the hub centre bolt but I'll have to dig further to confirm that. What model year is your car, and does it have original wheels or aftermarket ones?
  22. Looks like #55 - 10 point. https://www.ebay.co.uk/itm/New-Audi-Volkswagen-VW-Seat-Skoda-Locking-Wheel-Nut-Key-55-10pt-Spline-Rib/123981071363?hash=item1cddd90403:g:NAQAAOSwnw5eNzy2 https://www.ebay.co.uk/itm/Vw-Seat-Skoda-Locking-Wheel-Nut-Key-No-55-with-10-Flat-splines/132600684652?hash=item1edf9de06c:g:~gUAAOSwFxJbt6SD
  23. OK, update time. Attempted camboxectomy yesterday afternoon whilst looking over my shoulder at the advancing rain clouds. Bolts are both hex and torx (t25) so my Indy gets a limited apology. The rear cambox bolts, however, proved almost impossible to access (auto-seeking Torx bit on a spaghetti-like socket extension seems appropriate) and the one I was able to reach with my conventional socket set (after removing all possible obstructions) had clearly not been touched - hence the limited indy apology. Shame, as I've trusted them with our vehicles for 30 years but can no longer :( Spoke with a local and well-trusted VW parts house (Dub Haus) who recommended "without reservation" a local mechanic who is going to take an initial look in a week or so to see if it's camshaft+buckets or recon head time. Fingers crossed! I know we're heading towards "is the car worth it" territory but the rest of it is in pretty good shape - one owner from new, full service history, DMF/clutch done, only one query on VCDS which general opinion points to connectors (will be sorted). It had four new branded tyres a couple of hundred miles before I got it and I've replaced the battery and one rear hub bearing. Shocks are still OK but I have them on a list to replace next year. I bought the car as a "5 year car"; one year left before a cambelt was needed then four more years before the next decision point. At that point I'll be into my '70s and the market is likely to have shifted far enough away from weasels that next time will be petrol or hybrid. Just to complete the picture my wife's car is a 1.9tdi Octy which gets stunning fuel mileage - round trip (200 miles) mainly M6 - to Walsall t'other day 69.7mpg! The plan is to keep that one for local running around and the Scout for some travelling once Pat retires next year. Fingers crossed, eh?
