Everything posted by pinkpanther
Glitch rear LED lights
Hope you get this resolved under warranty 👍
Anyone running on CrossClimate 2 225/50R18 MICHELIN CROSSCLIMATE 2 SUV ?
Think 215 are OEM for 2WD, whereas 225 are OEM for 4WD?
I have 18" Cross Climate 2 on our 2023 1.5 TSi Karoq and older versions are fitted to both our SEAT Mii & FIAT 500. I'm yet to experience much in the way of snow and understand they are now bettered by other options, but nonetheless remain a sold choice for year round use👍
1.5 Tsi Power Cutting Out
The only occasion I had an Automatic (conventional or DSG) stall was as a result of a fault (idle control valve). Not sure how an automatic would stall otherwise?
Comfort mode or eco (but not both!)
There is an individual mode where steering, engine, AC and suspension (assuming you have DCC?) can be configured independently. The car can only be in a single mode at any given time.
What is it?
I have the same car and despite taking seats out many times have never come across anything resembling this. Google image search suggests it might be an upholstery washer? https://upholsterywarehouse.co.uk/products/washers-50mm-diameter
Cars with nice backdrops...
- Photography Thread
And the closest I'll get to a Bonfire this week 🔥 😀 20241103_170436.mp4- Photography Thread
- 1.5 Tsi Power Cutting Out
Yes - still stalls if the revs drop too low - suspect that aspect is a characteristic of this engine, which seems to not tolerate 'lugging' at lower revs? The throttle does however feel more positive and I find it easier to modulate, especially at lower speeds👍- Noise from both LHS (? top mount area) and steering motor
The supplying dealer took a look at the car yesterday and said they've seen similar issues with other Karoq's and now plan to change the front antiroll bar - car booked in shortly and I'll report back regarding any improvement 👍- Buying Skoda Karoq - (noob) questions
Good to hear 👍- Skoda Australia - 7 year warranty?
Thanks for that - I must get around to test driving a 2.0 TSi 👍- 1.5 Tsi Power Cutting Out
Not had that problem for a while as I think I've got used to the engines tendency to stall at lower revs, so tend to drive around the he issue and use more revs. Car feels more positive to drive with the alternate throttle setting though.- Power Steering is rather stiff
Yes - these were the options displayed for my 2023 1.5 TSi Karoq 👍 I'm running the latest Carista Beta.- Throttle Adaption now available in Carista
A few hundred miles now covered with 'direct' and the car is noticeably easier to drive and less prone to stalling 👍- Buying Skoda Karoq - (noob) questions
Blimey - not a box to own out of warranty! Certainly agree regarding ZF torque converter boxes, based on my experience of 6, 7 & 8 speed iterations.- 1.5 Tsi Power Cutting Out
Car is now more positive to drive in traffic and the throttle is easier to modulate a lower speeds - I've covered a few hundred miles with the new throttle setting and will stick with 'direct'👍- Power Steering is rather stiff
I'll check when I'm next in the car and will report back 👍- Noise from both LHS (? top mount area) and steering motor
Same for me - hoping to take mine in for a further attempt at rectification shortly- Photography Thread
Which VAG cars have the DQ381 transmission?- 1.5 Tsi Power Cutting Out
Early indications are this (https://www.briskoda.net/forums/topic/527560-throttle-adaption-now-available-in-carista/) alteration to throttle mapping has made a positive difference to the cars drivability👍- Throttle Adaption now available in Carista
Initial thoughts are this is a positive👍 - Photography Thread
