Doors lock on their own (and open at night)
Very spooky...I will be sat in my octavia if its moving or not and the back driver side rear passenger door locks on its own and it gets even wierder...
I lock the car up at night double check it and in the morning its opened all the doors by itself :eek: :eek: :eek:
How does this happen! I for the last 2 weeks have been thinking it was me but it unlocks itself at night and locks one rear door when you are in it.
Anyone else had this, My kids say ...dad this car is strange lol :)
Any pointers would be great.
Check the carpets for dampness, its possible you have a leak and the convienience ECU is getting wet.
The carpets are dry but saying that i had to replace my door membranes as these were letting in water and getting the carpets wet on drivers front and passenger side.
What is the conveniance unit and where is it and is it easy to find
forgot to mention how can i stop it from unlocking itself its not very secure!.
Could i take a fuse out somewhere to stop this.
As long as you have found the leak, once everythings dried out it should be ok.
I am sure someone will be along with the fuse number, I no longer have a mk1 and therefore no manual.
I have a manual but dont know what fuse to take out for this ecu conveniance unit thing.
Where is this unit located.
Thanks for the help
I have managed to locate the conveniance control unit and it appears ok, no signs of dry joints or water etc.
When it is disconnected i dont have and electric windows in the car
are the windows connected to this conveniance unit. Thanks
Yes; one of the configurable options is to get the windows to close themselves when the car is locked, and indeed to go back to where they were when it's unlocked.
I had the same problem. Wet dirt got stucked in mye luggage lock and shortcutted my lock.
It opened my doors and windows at night, locked the doors while driving.
Found a fuse, think it's a 30A almost at top second column from left.
My dad had a similar problem with his old octavia and it turned to be a fault with the connector from the rear door to the car, it also caused the window to open and close on it's own and the internal light kept coming on as well as locking and unlocking the door.
rather spooky when you were driving along.
Your right insecure, wierd and highly annoying!
My old Golf V5 and my Audi A6 did. Its easier just to get it plugged into a Bosch service computer that can overwrite the fault code
  • 4 weeks later...
I had a similar problem which I think is fixed. I'm holding onto lots of wood here!! I'd come back to the car and all the doors on which the winder mechanisms still work (that would be 2 :-) had opened themselves and the car was unlocked.
It simply needed a door lock repair kit from the main dealer.
I did have an extra clue in that my drivers door lock didn't work properly, basically the door lock was not returning to the centre position correctly therefore the door was unlocked.
Hope this info is helpful to somebody.
Andy
Not a problem I've got ATM (esp as I always use the remote), but how obvious was the failure to re-centre?
