Cisco Exam Advice
Lo all, planning on doing my Cisco exam prematurly before I finish the Net Acadamy as its dragging abit.
I have read all the material for ICND1 + & ICND2 and Im very confident with it all (got a distinction in semester 1 and 2 with grades of 98%) so I think I should stand a chance of passing.
Im wondering though, should I do ICND1 and ICND2 exams (640-816 and 640-822) OR do the CCNA exam (640-802)?
My thinking is that if I pass the ICND1, I should get a voucher for ICND2 which makes it cheaper to do that route as opposed to the CCNA.
Any suggestions or comments?
Thanks,
Mike:thumbup:
[update: Passed CCNA 640-802 and there was no supprise questions on there that wernt covered in the ICND modules]
Edited by PEMBO
CCNA is VERY unforgiving.....
my collegue at work failed it by a point because of one mistake with an incorrect syntax.
not for the faint hearted! :eek:
Might bite the bullet and go for the CCNA instead, just thinking about the ICND1+2 means I need to do 2 exams which is a pain
A work colleague is about to start on the CCNA course, his ultimate goal is to get to CCDE although I am not sure how realistic that target is.
One can only dream:D
CCDE Jobs, Average Salary for CCDE Qualifications
I think there are a limited number of CCDE's in this country -one agency mentioned 60-ish? I've only ever met one, a friend of a friend who's a contractor, and he had his own switch rack in his study. And a 911 on the drive.
Phil
CCNA's pretty easy , though past that they get quite a bit harder.
One tip is every time they give you an example config , write it all down.
Quite often you'll get questions later in the exam where you can get the answer from the notes you've just made.
Phil
IIRC its 15000 world wide, so 60 is about right
I'm wanting to do the CCNA - I've a certain amount of hands on 'fiddling' type experience but while I can replicate the most basic of configs in work situations I far too often have to say "I don't know" and we get a consultant at £1700 per day...the business case shouldn't be TOO hard to write :D
We can do you CCNPs and CCIEs for a lot less than that :)
just get a load of books, a couple of switches and routers and jobs a good un
My kit consists of 2x 1900 switches, and 3x 1600 routers - not state of the art but enough to practice with.
Looking at your sig you should be totally fine with it:thumbup:
