Highest HP numbers
What's the highes HP anyone's gotten out of an Octavia?
Speedy G
Speedy G
There is one Octavia Combi 4x4 turbo over here with an estimated 360bhp and 580nm:eek: I have heard rumours a 911 gt3 had some problems leaving it behind :D Hopefully I will get some pictures of it soon.
I believe the highest so far is 550bhp, not wonderfully reliable though. Needs a rebuild every 1,000km and is dead by 10,000km
Highest with full TUV approval is 420bhp with 442lb/ft. It includes New E-proms in ECU, optimization of flow to intercooler, new turbo, exhaust manifold, wastegate, intercooler, injectors, fuel pump, fuel pressure regulator, camshafts, crankshaft, piston rods, pistons, oil cooler, clutch, flywheel, air filter, modification of air filter housing and charge air hoses and pipes, extra engine mounts, modification of crank case breather, porting of cylinder head, 2 x race cats, stainless steel exhaust (turbo-back).
:D
:eek: :eek:
So not as much an Octavia, but "a car" with an Octavia bodyshell :D
If I had my car uprated to the same spec as above, do you think that my local dealer would notice on the roadtest and would it invalidate the warranty. :eyecrazy:
Hmmm... So the Dahlbach stuff in other words. What about DIY setups?
Speedy G
