cig lighter/accessory port problem
hey :) i would attempt to sort this myself but i dont want to brake anything and the manuel is in the post.
i have a felicia 1996 p reg, doesnt have all the fancy stuff like power steering and electric windows. (only had it a day now)
basically there doesnt seem to be any power going to the cig lighter at the moment, im guessing that it is a fuse problem? i would have a look at the fuses but i cant seem to get the fuse box open (in the passenger side foot well?) i dont want to force it too much and brake it.
also while im here, as standard what does this car normally come with? ive looked on a thread and the person mentions that it doesnt come with a radio and doesnt have the speakers etc, my car has a cd player fitted and the speakers look like theyre meant to be there, possible they were standard?
thanks people :)
The fusebox should be held at the front of it with something that unscrews (it's usually a big round plastic thing you can easily grab hold of) it should then flap down.
What the car ordinarily came with depends on trim level.
Could be wrong but I think (from lowest to highest spec) there's LXi, GLXi, and SLXi.
iirc the cig lighter and radio come off the same fuse :rubchin:
Fusebox is on the left hand side with a round thing you need you turn then that will pop the fusebox down.
Speakers are 13cm in the doors.
Mine came with a sunroof, PAS and elec mirrors. I had my own fitted anyway.
I think there's L, LXi and GLXi then SLXi might have been a GL with the 1.9D engine.
Welcome to club Felica btw!! I think the day after I got mine I spun it. Oops.
this may be a stupid question, but is there a guide anywhere that tells you which fuse goes to what?
and after getting behind the cig lighter i found that it isnt even connected, i cant find the connector anywhere behind there, any ideas on what next?
im guessing i will have to buy a connector for the lighter and wire it up into any 12v round there?
thanks
Also there are some Lauren & Klemens, and Blackline, Silverline, Flairline... special editions which may have different kit.
