Haldex problem ????
Hi all, sorry my eng. When i scan Octavia1 because on bord ligh for ESP is on in 22AWD was this
Thursday,05,June,2008,08:09:54:59303
VAG-COM Version: Release 704.1
Address 22: AWD
Control Module Part Number: 02D 900 554 B
Component and/or Version: HALDEX LSC ECC 0006
Software Coding:
Work Shop Code:
3 Faults Found:
01312 - Powertrain Data Bus
37-00 - Faulty
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01314 - Engine Control Module
and
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-A.LBL
Part No: 1C0 907 379 F
Component: ESP ALLRAD MK60 0103
Coding: 0023174
Shop #: WSC 31480
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
004 - No Signal/Communication
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
1 Fault Found:
49-00 - No Communications
I check the wiring but all is ok and 22 awd was read with vagcom -> CAN signal is ok.....
Sounds like the Cu is faulty, done quite a few for non communication faults.
My 4X4's Haledex ECU was changed under warranty 4 years ago with the revised part number 02D 900 554 D. A number of other 4X4 owners here have had Haldex ECUs showing checksum errors.
Snap.
I've got that one too.. :(
Thanks, now car is on my local dealer in service and wait results...
