Alloys for 1998 Felicia 1.3L
I've resently bought a felicia and really think its image would be helped by a nice set of alloys. i've heard from some people that some of the old VW wheels fit them but i am unsure which exact models these are...anyone shed some light
i'm open to altenate suggestions if anyone has any idea's
i reckon the 6n2 polo gti wheels would look good on a felicia
I think the old VW 4 studs are 4x100 the same stud pattern as the Felly.
It's finding a decent set of alloys at a good price then getting the right tyre profile to make sure the speedo/odometer isnt thrown wild (if you go for the 14" size)
Theres quite a few 13" ones too.
If you go for 14" wheel , you will want a 185/60 14 tyre to keep the speedo anything like
cheers guys this has been mega helpfull, i think the best option is to keep my eyes on ebay etc to see if anything pops up
It's finding a decent set of alloys at a good price then getting the right tyre profile to make sure the speedo/odometer isnt thrown wild.
Exactly. :thumbup: The tyre size takes a bit of number crunching, but it's possible to go for a whole range of different rim sizes, from the original 13" all the way up to 16" or 17", without freaking out the speedo. Take the total diameter of your original wheel (rim + tyre), determine the size of your new rim and subtract that from the original (total) wheel diameter. Divide the number your left with by two and then you'll know the height of the tyre sidewall you'll need.
Basically it's just fitting a bigger circle into the same outer circle.
This site is pretty neat:
Visual Tyre Size Calculator | Kouki Tech
This is my Felicia fitted with 14" Opel Manta Alloys, a straight fit
Only rear wheel drive vauxhall wheels will go on as the fwd ones hole in the middle is too small. also early BMW 3 series 4 stud wheels fit
some rover wheels will fit too if you get a spigot adaptor.
Those Manta wheels look smart
yo can increase or decrease the total circumference of the wheel by 3%, if you do it more than that the spedometer, final drive, brakes, steering etc will change or be afected, that being said this are the wheels / rims size you can use on a Skoda Felicia;
165/70R13 <- Original Size
For 13" Rims For 14" Rims For 15" Rims For 16" Rims For 17" Rims
175/70R13 165/65R14 165/60R15 165/50R16 165/40R17
185/65R13 175/60R14 175/55R15 175/45R16 175/40R17
195/60R13 185/60R14 185/50R15 185/45R16 185/35R17
205/55R13 195/55R14 195/50R15 195/40R16 195/35R17
