Help please in finding
Hi folks, can anybody tell me a few things please. i have a felicia 1.3 gli, MPI, and having problems with it starting all of a sudden, need to locate the fuel pump , and the fuel pump relay , can any body tell me where to find these? only up on vw campers.lol also i plan on changing the fuel filter, do i need to lower the tank to get to it, seems in a stupid place and is the system pressurised, any help much appriciated. Ash
its ok, sorted my prob, was fuel pump relay in fuse box not working, caused a lot of hassle has this little bugger,ta
Hi and welcome to briskoda. Fuel system is pressurised. Fuel pump is hidden under a cover under the carpet under the rear seats somehow.
I believe the filter is located above an exhaust heat shield.
Fuel pump relay I'm not certain on, but will either be under a plastic cover near the ECU, or among the lot in the fusebox under the dash passenger side.
Edit: good to know problem's sorted :thumbup:
the fuel pump is definitely under the rear seat, there's a little circular cover that you take off..
the fuel filter is tucked into the rear axle beam underneath the car on the petrol models, and in the engine bay on the diesels
Hi Ash. A bit of an odd shot, but did we meet in Nottingham at DAR 2007? You answer is probably either yes or WTF? :confused:
Hi, DAR? lol,, i only go to volky shows in my camper, skoda is just for the shops and work, come on then-tell me what this DAR is please :) , Donnington? or some fetish festival ? lol
It's ok; you're clearly someone else.
