Pictures/measures of Felicia lower arms
I am changing lower arms of my rally-Felly to group A brace welded ones, but problem is that they are made from 1.3 arms without ARB mounting point. Does anyone have arms that could be photographed and measured so I could make ARB points before assemblimg my arms? ARB is coming to car later but mounting points should be made now :)
Thanks.
Seems that nobody have these?
i've got a pair, i'll dig them out and get some photees...
tbh you are better off buying them new, they are only about £30
Thanks Tom. You' re right, arms are not expensive (~50 euros/each in Finland) parts but I don´t need new ones if I can get good pictures and widhts for ARB points. It is still easier to make those points than weld new braced arms when I already have a pair :)
true, but welding it will add a stress point which is more likely to crack
That is right too, but still I think I'll do it this way this time. Thanks anyway for the advices and if you could take fotos and measure arms during couple of next days, I'd really appreciate that.
Measures could be taken from the center of two balljoint bolt holes to the ceter of ARB mountig hole in millimetres. Then point should be exactly in right place :). BTW, what is the size of ARB-mount hole and how wide is plate for rubber washer around the hole, these would be useful informations too.
25206.attach
ok, sorry for the delay but i've been very busy at work, i think sunday might be the earliest chance i get to measure them up
Sunday is fine, thanks TOm. Let´s continue this by PMs, let me know when you have found some new information about arms.
But dont forget to update us with your progress felrace, especially those poly/nylonbushes!
