need a little favour from someone...
would somebody please kindly upload an image of the felicia (non power steering) steering wheel in full right lock position.
i was replacing my rack when an unfortunate tool slippage caused my carefully aligned wheel to move when putting the new pinion in the pinch grip.
If someone could kindly post a picture i can then "best guess" the max right position so when it returns to centre i am actually at the centre point of the rack. that would make it much safer to get the tracking done.
thanks in advance!
all i actually need to do is take off the steering wheel when i have rotated it to max right and place it back on so it matches the picture! easy peasy. tracking can take up th difference then no prob
gav
Can't help with a pic but if you put the st.wheel on with the rack at full lock count the number of turns to go to full lock the other way and turn the wheel back after halving this figure and this will give you roughly the half way point then reposition the st,wheel on the column :thumbup:
