can you help?
Having a few problems starting my car every so often. It's an X ref felicia.
Does anyone know of any common traits to Skoda's i.e electrical problems. I only recently had a new starter motor as they was soo bad it couldn't even be reconditioned!!!!
Any help would be greatly appreciated!!!!
in my feli a carburator glx, the problem was the coil module or ignition module, it fried, i now know the reason, the coil did not have a balast resistor and voltage was getting back to the module until it fried it.
if the car turns on run it for a while, check the module if its hot, there is no mistaking it... on the days that it did not start i bridge the module over the two top pins and let it sit, then unbridge and started, also check the ground, it could be a sorce of headackes
