Rear Brakes
only had my car for 2 weeks but ive noticed the rear pads dont seem to be making full contact with the rear discs, just before i bought it new rear pads had been fitted
ive got a band in the middle of the disc going around, rust on the inner and rust on the outer, a bit strange really
im gonna wait and see how the pads bed in over the next few hundred miles, but do you think its anything to worry about, car stops fine IMO
needs new rear discs , and soon or the new pads will be worn unevenly on the old rusty discs
LOL !!!
ordered some, they are cheap as foooooooook !
my new rear discs have been on for 2 weeks now, and have developed the same band as the old ones, i was hoping the pads would have bedded to the new discs by now, basically the outer 1cm of disc isnt being touched by the pads, the pads were fitted before i bought it, shouldnt they have worn flat by now to the new discs ?.......ive applied the hand brake a few times whilst driving to try and wear them down a bit
you should only fit new disk with new pad and never new disk with old pads
the pads are only a few weeks old though, thought it would be ok
depends how much driving you do, lots of driving = lots of wear
I think it might be how you use your brakes, rather than the mileage you do! The rear brakes don't contribute an awful lot to the braking force anyway.
It seems you've done it in the wrong order BRUN, as DigitalDwarf above is right; I think you'll have to go to square one again, and fit a new set of pads to your new disks. Sorry...
Steve
grrrr i was hoping not as the pads were fitted a few weeks ago by the dealer i got the car from, however the discs were a bit **** poor and for the price i thought id replace them
bet the pads cost more than the discs did !
The rear pads don't go right to the outer edge of the discs, unlike the fronts. It's normal to have a band of rust around the edge.
just done my front pads today and the bolts holding the caliper on were a swine to get off, just so soft its unreal on a newish car. Gald they are done, although they will be a bit spongy for a while till they bed in :S
neily how come nobody else has mentioned it though ... Surely with the amount of replies ive had everyone would have just said theirs is the same
Mine aren't like that, and they do need changing soon. Where did you buy yours from BRUN?
Steve
discs are OE, pads were fitted before i bought it, they are Bosch pads
My rears have a small band of rust around the outer edge too, like yours, about a 1cm band all the way round. It's not worried me, i just figured it was the norm....... :rubchin:
so this is normal ???
that band looks a bit too big for my liking
but if your old disks were badly coroded on the outer rim it will have removed a significant amount of material from the pad
then putting that same pad on a new disk means there is the same band now not being touched by the worn pad
ps excuse the spelling as i have dyslexia and it get worse as i get tired
and i havent reinstalled my spellchecker
both my front and rear disks have a small rust lip around the outside, probably about 1-2 mm. Will need replacing soon but my pads have loads left so not worrying too much atm.
Sorry but the rust marks on yours do not look normal mate. The pads should be making more contact than that
do the pads on the rear have wear indicators or not ?
Not
The rear brakes do very little when moving so it will take ages for any bedding in to get rid of the line. Drive a bit with the HB on to see if it goes.
we had a Polo in work today so once the wheels were off i had a look, and thats exactly the same as mine
pics of the Polo, not my Fabia
^^^ bump
anyone elses look like mine or the Polo pics above ?
The pics above look very similar to mine, now on 38k miles with original discs and pads all round.
cheers for the info
Hello,
Fabia VRS 2005.
Mine just the same, the original and replacement discs and pads.
29/01/2009
