Anyone know what this is for?
As above. Found it amongst the cars paperwork:confused:
26373.attach
looks like a chip... the
performance enhancing kind
it's a plug-in switchable remap. it plugs into the OBD port. If the paperwork for it is not in with the rest, contact Star Performance about it and they should give you the instructions on how to do it properly.
Yep, its a remap in a box. :)
Thought it was.
Cheers guys.
Lucky bastid :D
Speed in a box :D
my car has one of these switchable maps.... only problem is the controller (pictured) was kept by the previous owner
So I could put the standard map back on the car using this device?
I know it has a stage 1 map on it but I never knew it was swichable!
Yep. Have a play around with it, just make sure you don't spend too long with the ignition on as you don't want to drain the battery when you are messing around with ECUs :)
Instructions for that box:
Instructions for DPT when using the FIRST time.
Plug in the unit to port and turn on ignition
The amber light will come on, now push and hold till the light flashes , then release the button.
The amber light will flash, leave it until it stops flashing, about 3 mins, when the green light is constant it means it has coded itself to the ECU box and stored the standard map.
Instructions for switching between maps
A light tap on the button will allow you to switch between software, (Green light = Standard software, Red light = Modified) If you select the red light just hold the button in for a moment until it starts to flash, release the button and wait a few minutes for flashing to stop and Green & Red lights to stay on constantly, Turn ignition off and remove unit.
To reload standard software, plug unit back into Diag port and turn ignition on, select green light and press and hold till green light flashes, wait 3 mins for constant green light, turn off ignition and remove unit.
WARNING: DO NOT REMOVE UNIT WHILE LIGHT IS FLASHING
I've got one you can have, that Star could get re-flashed for you, with your standard and performance map :)
Steve
I've got one too, if you ever see a Black vRS reg SP54 xxx let me know as they can have it. :)
