Heater flaps
Hi all
I have this problem with the heater flaps. Is there anybody in the Dorset area that has the softwear to adjust the settings? The problem is when I switch to recirculating and then switch back and the motor opens the flap (which I can see if I open the bonnet and remove the filter) it goes so far then gets sort of semi stuck. It will free itself after I while or if I genty push the flap from under the bonnet it opens completely. It wants to open fully it just gets so far and then can't seem to make up its mind.
I have vagcom and I am Weymouth..... not sure what quite the needs to be done - maybe someone else can advise.
Hi all can any body help with what needs to be done with vag com that a fellow member has offered to help or is it a service centre job only (hope not).
Cheers mbames If it is ok and it can do the job I will come on down I am in Bournemouth.
Hi,
Yep no problem, although I won't be able to do anything till next weekend I am afriad, so that should give plenty of time to track down what needs to be done.
Cheers,
Matt
Any of you tech guys out there know if this can be done with I presume with the ross tech softwear and a laptop ?
If you can see the flap pivots, how about using the straw to get a fix of Servisol into them? Then exercise the flap and motor by repeatedly switching in and out of recirc.
