who's octy II vRS WAS this then?????
Nothing there that VCDS can't clear tho' ;)
I thought you couldn't take that one out?
000537 - Maximum Engine Speed Exceeded: Engine Warranty VOID! :-)
P0219 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 8
Mileage: 66095 km
Time Indication: 0
Date: 2000.00.00
Time: 17:54:02
Freeze Frame:
RPM: 7265 /min
Load: 9.4 %
Speed: 221.0 km/h
Temperature: 90.0°C
Temperature: 33.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
Need I say more.:(
Quiet a common one and can be removed by VCDS, had it removed from my previous vRS quiet a few times. To generate it, you just need to hold it on the rev limiter for a short period of time.
221kmh = 137.3mph :eek:
Someone might assume that it was in 5th and not 6th gear??
Hence the phrase drive it like you stole it. :o
Does this code come up as a fault on the maxidot or only when its hooked up. 7k rpm is a bit high, but when doing the run-in as suggested after the first 1000km on mine it says to take it up to almost the redline which is 6.5k. I don't think I ever quite hit it, but I have seen a light flash up in the higher revs briefly but no idea what it was.....shift light?
It will only come up via diagnostics.
Hmm well does anyone know what that light was then that flicked on briefly?
could have been traction control
I didnt think that fault could be cleared once it was logged.
