Lost My Auto-Windows !!!
Was installing an interface on saturday,
I had to put in a new circuit on the fusebox, so i disconnected the negative on the battery and removed all the fuses, connected the new circuit, replaced all the fuses and reconnected the negative terminal..
I had to drive it for a few yards to turn off the powersteering light and traction control light..
Everything was fine until i pressed the window button.. I lost the auto function on all four windows. I have to hold the button pressed the whole time..
Has anyone come across this before, will i have to go looking for someone with Vag-com.
I was going to look at all the fuses, but surely if the windows are working, the fuses is fine..
Now all i can think about is "What else have i lost ???? !!! "
Any help appreciated lads,
Tom
Just do full open and full close for every window, and "auto" function will come back.
As above, there's a thread on this somewhere if you do a search. Something along the lines of doing the windows up and holding the switch in the closed position for a few seconds iirc.
I think Lummox posted it :thumbup:
Same kind of thing on the Fabia (Mk1) as well :)
Window down, hold it for a bit after it has fully come down, then do the same closing it, hold it for a bit once closed.
After that, let go and try the auto-down etc. If it does not work, just try again and hold for a tad longer :)
