vRS Flat spot from 1500-2200 rpm
Very bad from cold, better when warm, super unleaded helps as well.....jeky has hell in the mornings.
5 Year old, just serviced (Was like it before) 45,000 miles.
Mike
Is it in the first couple of minutes? If so it's normal while the secondary air pump is working. Wait a minute for the revs to drop and drive off and it should be smoother.
Ian
Mine is exactly the same first thing, especially recently during the cold spell. Clears up after a minute or so and have got used to it, I believe its perfectly normal.
Mine also dumps boost between 3-4k when cold which I also assume is normal. it must be a protection system I guess??
